#21
![]() "Rich S." wrote in message ... "karel adams" wrote in message ... Nothing new about this idea. There is such a powerplant in French Britanny (Bretagne) And only a few miles from here there's a grain mill on the same principle - several centuries old... So if the Sky falls on us, it's the fault of the French? ;-p Rich "I knew they were up to no good!" S. Next thing the French will short out the electricity that powers "the lamps in the Stars", to Earth.:-), this will signal the end to space travel and there will be no starlight to navagate by. -- .. -- Cheers, Jonathan Lowe whatever at antispam dot net No email address given because of spam. Antispam trap in place |
Roger
I think you might be right as I recall. I didn't throw out those facts because it was so long ago I might have forgotten the details??? Big John On Fri, 12 Sep 2003 06:12:00 GMT, Roger Halstead wrote: On Wed, 10 Sep 2003 16:33:33 -0500, Big John wrote: terra Do you remember the Shuttle test where they unrolled a long wire and let it fall down toward the earth with gravity. First test the drum stuck and they couldn't unroll the wire. Second try they got a lot of wire out but experiment didn't produce what they expected. Don't remember the data published in AW&S. Think the Italians provided the hardware and after the second failure no more tries that were published. I thought they fried the wore on the second try, or possibly it was on some tethered experiment where the cable fried from the induced voltage. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Is this similar to what you propose? If so ,you might want to contact NASA to get any papers they wrote on these experiments. |
It worked well but there was an arc from the line to the craft which
burned through the cable and the conductor was lost. Big John wrote: Roger I think you might be right as I recall. I didn't throw out those facts because it was so long ago I might have forgotten the details??? Big John On Fri, 12 Sep 2003 06:12:00 GMT, Roger Halstead wrote: On Wed, 10 Sep 2003 16:33:33 -0500, Big John wrote: terra Do you remember the Shuttle test where they unrolled a long wire and let it fall down toward the earth with gravity. First test the drum stuck and they couldn't unroll the wire. Second try they got a lot of wire out but experiment didn't produce what they expected. Don't remember the data published in AW&S. Think the Italians provided the hardware and after the second failure no more tries that were published. I thought they fried the wore on the second try, or possibly it was on some tethered experiment where the cable fried from the induced voltage. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Is this similar to what you propose? If so ,you might want to contact NASA to get any papers they wrote on these experiments. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
#24
"Bruce A. Frank" wrote in message
... It worked well but there was an arc from the line to the craft which burned through the cable and the conductor was lost. So what you're saying is those NASA boys didn't read the relevant Advisory Circular regarding gauging wire for current ![]() Eric |
#25
Eric
You need to address this to the Italians. They made the test article and it was their experiment. Big John On Sat, 13 Sep 2003 13:08:48 GMT, "Eric Miller" wrote: "Bruce A. Frank" wrote in message ... It worked well but there was an arc from the line to the craft which burned through the cable and the conductor was lost. So what you're saying is those NASA boys didn't read the relevant Advisory Circular regarding gauging wire for current ![]() Eric |
