Myth: 1 G barrel rolls are impossible.
Old June 12th 07, 12:48 AM posted to rec.aviation.piloting,rec.aviation.student
Bob Moore
Default Myth: 1 G barrel rolls are impossible.
Jim Logajan wrote
Most everyone agrees that keeping the coffee in the cup is possible.
What some people don't seem to believe is possible is that the force
felt by the pilot (or tea/coffee) can be 1 gee during the entire roll.
They believe it has to vary during the roll. I'm hesitant to name
names. ;-)
My name is Bob Moore :-)
Just what is a barrel roll has been debated between "Big John", Dudley,
and myself at least twice in the past. It IS difficult to describe
without having a model airplane in one's hand and flying it through the
maneuver.
How come you don't seem to belive the following from Wikipedia?
Barrel roll
From Wikipedia, the free encyclopedia
This article is about the aerial sport. For the military operation, see
Operation Barrel Roll.
A barrel roll occurs when an object (usually an airplane or roller coaster)
makes a complete rotation on its longitudinal axis while following a
helical path, approximately maintaining its original direction. The G load
is kept positive (but not constant) on the aircraft throughout the
maneuver, commonly not more than 2-3 G.
In aviation, the maneuver includes a constant variation of attitude in all
three axes, and at the midpoint (top) of the roll, the aircraft is flying
inverted, with the nose pointing at a 90-degree angle ("sideways") to the
general path of flight. The term "barrel roll" is frequently used,
incorrectly, to refer to any roll by an airplane (see aileron roll), or to
a helical roll in which the nose remains pointed generally along the flight
path. In fact, the barrel roll is a specific and difficult maneuver; a
combination of a roll and a loop. It is not used in aerobatic competition.
http://acro.harvard.edu
The Barrel Roll is a not competition maneuver. The barrel roll is a
combination between
a loop and a roll. You complete one loop while completing one roll at the
same time.
The flight path during a barrel roll has the shape of a horizontal cork
screw. Imagine a big
barrel, with the airplanes wheels rolling along the inside of the barrel in
a cork screw path.
During a barrel roll, the pilot experiences always positive G's. The
maximum is about 2.5 to
3 G, the minimum about 0.5 G.
Old June 12th 07, 01:10 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
"mike regish" wrote:
The few that I've done, and it is only a few, the g forces were
noticeably less at the top of the roll. I was still pressing into the
seat, but not as much. Just as in a loop, the g forces are lower at
the top of the loop.
That seems reasonable. I should try to clarify that the maneuver I
described is what I believe is theoretically possible.
Old June 12th 07, 01:15 AM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques
On 2007-06-11 18:41:50 -0400, "mike regish" said:
The few that I've done, and it is only a few, the g forces were noticeably
less at the top of the roll. I was still pressing into the seat, but not as
much. Just as in a loop, the g forces are lower at the top of the loop.
mike
"Jim Logajan" wrote in message
Mxsmanic wrote:
Jim Logajan writes:
roll. They believe it has to vary during the roll. I'm hesitant to
name names. ;-)
It has to vary during the roll, because the constant 1 G acceleration
due to gravity does not change. The net acceleration of the aircraft
must always be at least one G in consequence, and if the aircraft
begins a climb or ends a descent, it _must_ be greater than +1.0 G.
Sigh. Yes, the force that is felt is greater then one g-force at the
beginning and end of the maneuver. But that is not the case "during the
roll" itself. Again, as in the other post of yours I responded to, you
appear to be confusing force and acceleration.
Easing off the g through the apex is called "the float". You do this
because as soon as the lift vector goes below the horizon you pick up 1
extra +g available. In other words, you can easily tighten up the
maneuver losing the constant arc of the roll if you don't ease off the
g. Same for going over the top in a loop or any maneuver where a
constant arc is desired over the top.
Since the theoretical objective anyway :-) is to keep the roll arc
constant in a barrel roll, you ease off the g through the apex to avoid
picking up that extra 1 positive g available and by doing so tightening
up the roll arc.
So the bottom line is that the positive g does indeed vary through a
barrel roll and it is always at some positive g value with the 1
exception being flying through the float with the wings unloaded. I
should note that in the true sense of explaining a barrel roll, going
to 0 g through the float would be out of the context of a true classic
barrel roll which must remain constant throughout the roll.
Dudley Henriques
Old June 12th 07, 01:33 AM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Bob Moore" wrote in message
46.128...
maneuver.
Barrel roll
coaster)
flight
combination between
same time.
in
a cork screw path.
Then would you label the roll that Jim has described here as a form of
aileron roll, instead of a barrel roll? Or do you think it is possible to
do a 1g aileron roll?
Jim Logajan
name names. ;-)
Hi Bob. Glad you could make it to B.R.A. (Barrel Rollers Anonymous.) :-)
Dudley, and myself at least twice in the past. It IS difficult to
describe without having a model airplane in one's hand and flying it
through the maneuver.
You know what is odd? The flight path of the maneuver I wrote about
appears to violate the Harvard definition you quote (it can't be done in
a straight horizontal path - my corkscrew/helical path must follow a
parabolic arc) but oddly the Wikipedia definition leaves me a big "out."
Straight down. ;-)
Drop the nose straight down so as to make the plane & pilot weightless.
Then start doing horizontal loops so the centrifugal force yields the
equivalent of one gravity of weight. At least the longitudinal axis of
the helical path will maintain a constant direction - but the pilot will
quickly be screwed. :-)
Barrel roll
see Operation Barrel Roll.
coaster) makes a complete rotation on its longitudinal axis while
following a helical path, approximately maintaining its original
direction. The G load is kept positive (but not constant) on the
aircraft throughout the maneuver, commonly not more than 2-3 G.
all three axes, and at the midpoint (top) of the roll, the aircraft is
flying inverted, with the nose pointing at a 90-degree angle
("sideways") to the general path of flight. The term "barrel roll" is
frequently used, incorrectly, to refer to any roll by an airplane (see
aileron roll), or to a helical roll in which the nose remains pointed
generally along the flight path. In fact, the barrel roll is a
specific and difficult maneuver; a combination of a roll and a loop.
combination between
the same time.
cork screw. Imagine a big
barrel in a cork screw path.
Old June 12th 07, 01:58 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Jim Logajan writes:
Myth:
It is impossible to perform a barrel roll such that the pilot feels
exactly 1 gee of force perpendicular to the floor of the cockpit.
No maneuver that involves a change in altitude can maintain exactly 1
G along the net acceleration vector (including perpendicular to the
cockpit floor). This is not a myth, it's a fact.
Shut up fjukkwit.
You don't even know why you're right, monkey boi. .
Bertei
Old June 12th 07, 02:00 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Jim Logajan writes:
name names. ;-)
You're an idiot and you will never ever do a barrel roll.
Bertie
  #29
Old June 12th 07, 02:11 AM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_3_]
"No maneuver that involves a change in altitude can maintain exactly 1 G
along
the net acceleration vector (including perpendicular to the cockpit floor)."
Hey, asshole- how about rolls on the vertical, either up or down? The plane
is climbing or descending, while maintaining one g througout. There is no
change in the g forces associated with the roll.
  #30
Old June 12th 07, 02:16 AM posted to rec.aviation.piloting
"Maxwell" wrote in
46.128...
Barrel roll
coaster)
load is kept positive (but not constant) on the aircraft throughout
in all three axes, and at the midpoint (top) of the roll, the
aircraft is flying inverted, with the nose pointing at a 90-degree
angle ("sideways") to the general path of flight. The term "barrel
roll" is frequently used, incorrectly, to refer to any roll by an
airplane (see aileron roll), or to a helical roll in which the nose
a combination of a roll and a loop. It is not used in aerobatic
competition.
combination between
the same time.
barrel in
a cork screw path.
possible to do a 1g aileron roll?
It's less of a roll than it is a loop.
In fact, that's how I used to teach it. Get a hula hoop, cut it and pull
the ends apart. you are now looking at the path of a barrel roll. A
skewed loop
Bertie
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 06:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 12th 04 12:45 AM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 05:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 10:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 07:15 PM
