cad-plated stainless steel?
Old June 19th 07, 11:07 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
Default cad-plated stainless steel?
hi, guys,
I just ordered some stainless piano-hingepins (pn#03-49000). What Aircraft
Spruce delivered were some cad-plated rods. I previously got some stainless
and these were silvery-shiny. I complained at AS and they responded that
their stainless 302 pins truely were cad-plated (?) I never heared about
such. What should cad-plating of stainless be good for?
Old June 19th 07, 11:36 PM posted to rec.aviation.homebuilt
Blueskies
"oilsardine" wrote in message ...
hi, guys,
I just ordered some stainless piano-hingepins (pn#03-49000). What Aircraft Spruce delivered were some cad-plated rods.
I previously got some stainless and these were silvery-shiny. I complained at AS and they responded that their
stainless 302 pins truely were cad-plated (?) I never heared about such. What should cad-plating of stainless be good
for?
Hydrogen embrittlement?
Old June 19th 07, 11:46 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Beats me. But I've bought .089" wire for MS 20001 and MS 20257 piano
hinges from a couple different suppliers, and all of it had that
yellow-colored plating.
Old June 20th 07, 12:26 AM posted to rec.aviation.homebuilt
Charles Vincent
oilsardine wrote:
hi, guys,
Assuming that you are going to attach the hinges with standard cadmium
plated AN hardware, it could be there to prevent the stainless steel
using the cad plated attachment hardware as a sacrificial anode.
Stainless and cadmium fasteners do not necessarily mix well looking at
their relative placements on a galvanic series.
Charles
Old June 20th 07, 01:15 PM posted to rec.aviation.homebuilt
El Maximo
hi, guys,
responded that their stainless 302 pins truely were cad-plated (?) I never
heared about such. What should cad-plating of stainless be good for?
I work at a place that sells a bunch of stainless and cad-plated parts. I
asked one of the engineers if it was possible to cad-plate stainless steel.
He replied it makes no sense at all. Cad plating is used for corrosion
resistance. Stainless steel is corrosion resistant.
Stick a magnet to the part and see if it sticks. Magnets don't stick to
stainless steel.
Old June 20th 07, 01:48 PM posted to rec.aviation.homebuilt
Dan[_2_]
hi, guys,
stainless steel.
Some stainless alloys are magnetic.
Dan, U.S. Air Force, retired
Old June 20th 07, 04:17 PM posted to rec.aviation.homebuilt
Doug Palmer
Stainless tends to chew through aluminum pretty quickly (galvinac corrosion)
Perhaps the cad plating is to help protect the aluminum of the hinge
extrusion more so than the stainless.
hi, guys,
Old June 20th 07, 09:44 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
"Dan" schrieb im Newsbeitrag
stainless steel.
small neodym magnet sticks to stainless as well as to steel pins, can't tell
and difference. What is a recommended test for stainless (besids leaving it
outside half a year and watch rusting)?
Old June 20th 07, 10:48 PM posted to rec.aviation.homebuilt
Charles Vincent
stainless steel.
If a magnet sticks to it, then it is 4xx series stainless I expect. The
traditional homeshop or blacksmith test for various metals is the spark
test, but is not that useful unless you:
A) Frequently perform spark tests and can judge it by eye, which is only
developed by ...........
B) Making up a set of test coupons of various common metals with good
provenance that you can spark test and compare.
There are some tests that can be done with acids, but also take
familiarity, and don't think work as well with the 4xx series.
I think there are perfectly good reasons to cad plate stainless, but you
should verify on your own:
1) Reduce galvanic corrosion when using stainless with aluminum,
magnesium or cadmium plated parts.
2) Cadmium plating acts as a lubricant and will prevent galling which is
a problem with both aluminum and stainless.
Charles
Old June 22nd 07, 02:32 PM posted to rec.aviation.homebuilt
On Jun 20, 11:48 am, Dan wrote:
hi, guys,
stainless steel.
Some (or all) of the 400 series are ferromagnetic.
Stainless steel bolts typically are 18-8 (300 series)
and are not. However the 300 series are not heat-treatable
and some of the 400 series are.
Back when I worked in the nuclear industry we used
stainless steel bolts that were cad plated for lubricity.
Sometimes we used some that were silver plated on the
threads only for the same reason. We pretty much
only used 316 SS bolts and nuts.
It is not likely that plating would be done to prevent
hydrogen embrittlement as electroplating is one CAUSE
of hydrogen embrittlement. However, hydrogen diffuses
poorly through nickel so if a bolt were intended for an
environment where hydrogen could diffuse into it, nickel
plating might help. Never heard of that being done--that
part is just speculation.
FF
Stainless steel exhaust headwind Home Built 5 February 14th 07 04:30 AM
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 05:09 PM
Working Stainless Steel Bob Babcock Home Built 7 February 14th 04 05:12 PM
OK, all you limeys: 4 beautiful chromium-plated valve covers for Continental O-200 jls Home Built 5 February 10th 04 06:36 PM
structural stainless steel tank screws needed for PA-32-300 Dave Owning 11 October 1st 03 11:14 PM
