Cessna's new LSA: "Skycatcher"
Old July 23rd 07, 10:00 PM posted to rec.aviation.piloting,rec.aviation.owning
Al G[_2_]
Default Cessna's new LSA: "Skycatcher"
"Phil" wrote in message
On Jul 22, 4:42 pm, Jim Logajan wrote:
For those who haven't seen this, Cessna has provided lots more detail on
its LSA entry:
http://www.cessnaskycatcher.com/
Fancy brochu
http://www.cessnaskycatcher.com/imag...ni_bro_web.pdf
Order form with pricing (for first 1000):
http://www.cessnaskycatcher.com/imag...final_0721.pdf
I'm sorry, but SkyCatcher?? I think they should have just stuck with
Cessna 162 and left it at that.
I guess it's better than "Ground Finder".
Al G
Old July 23rd 07, 10:12 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
detail on its LSA entry:
Fancy brochu
Al G
THe thing is 100 lbs over the empty weight it should be. Maybe "SkyPiggy"
would have been a good name.
Old July 23rd 07, 10:23 PM posted to rec.aviation.piloting,rec.aviation.owning
Larry Dighera
On Mon, 23 Jul 2007 19:46:01 +0000 (UTC),
wrote in
I think it's unfortunate that it uses the O-200 engine.
IIRC, the Cont O-200 has a TBO of 1,800 hours. Have you checked the
TBO on the Rotax?
Old July 23rd 07, 10:27 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Stewart
wrote in
TBO on the Rotax?
912ULS - 1500 hours
Old July 24th 07, 01:41 AM posted to rec.aviation.piloting,rec.aviation.owning
Morgans[_2_]
"Phil" wrote
On the plus side, I think it looks great. Although I think it would
look better without those wing struts. Low-wing planes have been
flying without struts for years. Why is it that high-wing planes
still use them? They cause drag and they spoil the view.
Because you can make the wing structure and mounting lighter.
I gotta wonder though; why is the dang thing so heavy? It is probably at least
75 pounds heavier than others of the class.
It is going to make full tanks with two people impossible to do and still be
legal, (and no luggage) unless they are really lightweights.
I will go out on a limb and say that Cessna had better put it on a diet, or it
will not sell as well as they would like.
Jim in NC
Old July 24th 07, 02:13 AM posted to rec.aviation.piloting,rec.aviation.owning
Morgans[_2_]
"Scott Skylane" wrote
Don't knock the O-200 quite so fast. The 162 is getting the "D" model engine,
the Type Spec of which hasn't even been issued, yet. I would be surprised if
Continental doesn't incorporate some improvements to the cylinder design. As
a rugged, easy-to-maintain light aircraft powerplant, I personally think they
made a good choice.
I agree, most completely!
The fact that it has the O-200 would make me buy it, rather than the Rotax
powered LSA's.
Anyone know what a weight comparison would be for a firewall forward
installation of a 200 vs. a 912?
Jim in NC
  #28
Old July 24th 07, 03:05 AM posted to rec.aviation.piloting,rec.aviation.owning
: Don't knock the O-200 quite so fast. The 162 is getting the "D" model
: engine, the Type Spec of which hasn't even been issued, yet. I would be
: surprised if Continental doesn't incorporate some improvements to the
: cylinder design. As a rugged, easy-to-maintain light aircraft
: powerplant, I personally think they made a good choice.
I'm not "knocking" it so much as I lament a brand new aircraft not using new technology. TBO doesn't take into account
cylinder overhauls, which are routinely required on old-school air-cooled aircraft engines. I'm been plagued with sticking
valves on my O-360 since I got my Cherokee and taking a step *backwards* from that (WRT cooling, compression ratio, etc) seems
silly.
If the "D" models has the improvements you suggest, then it's a good compromise. If not, it's a rather disappointing
choice. Perhaps with 110 HP it'd go faster than allowed in a LSA?
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
  #29
Old July 24th 07, 03:35 AM posted to rec.aviation.piloting,rec.aviation.owning
C J Campbell[_1_]
On 2007-07-23 07:31:11 -0700, Phil said:
On Jul 23, 4:00 am, Thomas Borchert
Phil,
You seem to forget that the other Cessnas all have silly names, too.
Thomas Borchert (EDDH)
No, I knew that. But in silliness, this one goes to eleven. It
sounds like a name an eight year old would pick for the airplane he
just made out of scrap wood.
I don't think it is as bad as 'Stationair.' Sounds like something slow
and ugly, which it is, but they didn't need to call it that . :-)
Waddling Eagle
World Famous Flight Instructor
  #30
Old July 24th 07, 03:37 AM posted to rec.aviation.piloting,rec.aviation.owning
C J Campbell[_1_]
its LSA entry:
Fancy brochu
I like the cute little Garmin panels. The thing has all the wiring
harness you need to convert it to IFR, by the way. Mike Pickett got to
sit in it at the dealers meeting and said he liked how comfortable it
was and the layout of the controls. He liked the stick, too, which is
an angle under the dash instead of attached to the floor, so it doesn't
get in the way of your dress.
Everybody made fun of the cupholders, though. FOUR cupholders in a two
place plane. Count 'em.
Waddling Eagle
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 08:48 AM
More on Cessna's new "Cirrus Killer" [email protected] Piloting 49 November 13th 05 03:29 PM
