Raise your useful load without an STC...
Old August 2nd 07, 09:34 AM posted to rec.aviation.piloting
Hilton
Default Raise your useful load without an STC...
1. Go on a diet
2. Define a gallon of 100LL as weighing 5.82 lbs instead of the usual 6
lbs - Mooney did it.
Is this legal/valid? If so, why don't all manufacturers do it?
Hilton
Old August 2nd 07, 11:23 AM posted to rec.aviation.piloting
Tom L.
On Thu, 02 Aug 2007 07:34:53 GMT, "Hilton" wrote:
1. Go on a diet
Hilton
It's valid, or at least more accurate that the traditional 6 lbs/gal.
Fuel specific density probably varies between manufacturers, but is
usually specified as 0.7 or 0.71, which is about 5.84 lbs/gal.
You need to carry a lot of fuel for this difference to amount to
anything useful.
I'll keep using the more conservative "6", ... and start dieting
- Tom
Old August 2nd 07, 12:57 PM posted to rec.aviation.piloting
Matt Whiting
Hilton wrote:
1. Go on a diet
Yes, diets are completely legal and valid and most of us should do so.
Mooney didn't "define" a gallon of 100LL to weight 5.82 lbs, that is
what it DOES weigh. Someone else "defined" it as 6 lbs many moons ago
to simplify calculations. If Mooney is doing as you say (I didn't take
time to verify), then they are just being more precisely correct, if
more impractical for their pilots.
Matt
Old August 2nd 07, 02:29 PM posted to rec.aviation.piloting
John Theune
Matt Whiting wrote:
Hilton wrote:
1. Go on a diet
6 lbs - Mooney did it.
Matt
For 50 gallons of fuel the difference is 9 pounds. Not much of a
difference as most peoples weight can change 4 pounds in a day based on
time of day and water in/out
Old August 2nd 07, 02:54 PM posted to rec.aviation.piloting
Hilton
Matt,
According to Wikipedia: "Avgas has a density of 6.02 lb/US gallon at 15 °C".
Not sure how 'correct' this is.
Hilton
"Matt Whiting" wrote in message
news
Hilton wrote:
1. Go on a diet
Mooney didn't "define" a gallon of 100LL to weight 5.82 lbs, that is what
it DOES weigh. Someone else "defined" it as 6 lbs many moons ago to
simplify calculations. If Mooney is doing as you say (I didn't take time
to verify), then they are just being more precisely correct, if more
Matt
Old August 2nd 07, 06:09 PM posted to rec.aviation.piloting
Doug Semler
On Aug 2, 8:54 am, "Hilton" wrote:
Matt,
One of the material data sheets at Shell's website says their 100LL is
0.718 kg/L at 15 C.
http://www.shell.com/static/au-en/do..._100ll_pds.pdf
0.72 kg/L is 6.02 lb/US gallon.
I guess it depends on how "exact" you want your calcs to be. I mean,
come on, do you actually weigh yourself before you do each and every
w&b calc?
Old August 2nd 07, 11:08 PM posted to rec.aviation.piloting
Cubdriver
On Thu, 02 Aug 2007 09:23:23 GMT, Tom L.
anything useful.
In the Cub, it would allow me to gain 2 pounds, or not to lose 2
pounds, as the case might be.
Every little bit helps!
Blue skies! -- Dan Ford
Claire Chennault and His American Volunteers, 1941-1942
from HarperCollins on August 21 www.flyingtigersbook.com
Old August 3rd 07, 12:08 AM posted to rec.aviation.piloting
Matt Whiting
John Theune wrote:
Matt Whiting wrote:
Hilton wrote:
1. Go on a diet
usual 6 lbs - Mooney did it.
take time to verify), then they are just being more precisely correct,
if more impractical for their pilots.
Matt
I didn't say it made much of a difference, just that it is valid.
Matt
Old August 3rd 07, 12:15 AM posted to rec.aviation.piloting
Matt Whiting
Hilton wrote:
Matt,
I've seen several different values, but most are less than 6.00 lbs/gal.
According to this site, the specific gravity of ConocoPhillips 100LL is 0.7.
http://www.conocophillips.co.uk/NR/r...D7/0/msds6.pdf
According to this site, the density of water at 15.5C is 8.33727 lbs/gal.
http://antoine.frostburg.edu/chem/se...r-density.html
Multiplying that by 0.7 yields: 5.836 lb/gal for the 100LL.
I can't vouch for the calculator site, but I trust the ConocoPhillips
MSDS much more than anything on Wikipedia, which is about the least
reliable source on the internet in my experience.
Matt
Old August 3rd 07, 01:49 AM posted to rec.aviation.piloting
B A R R Y
On Thu, 02 Aug 2007 17:08:46 -0400, Cubdriver usenet AT danford DOT
That's why most FBOs have public bathrooms.
"All passengers must "evacuate" before boarding." G
Server over-load Jim Macklin Instrument Flight Rules 6 August 17th 06 02:48 AM
New 182T, where's the useful load?? Robert M. Gary Piloting 10 April 27th 06 07:48 PM
Bush went to war to raise oil prices. Garamondextended Military Aviation 6 May 29th 04 03:24 AM
Load supervisers jfp Piloting 0 April 13th 04 05:25 PM
Load supervisers jfp General Aviation 0 April 13th 04 05:22 PM
