props: tractor v pusher, q tip, ducted?
Old August 9th 07, 11:28 PM posted to rec.aviation.piloting
Big John
Default props: tractor v pusher, q tip, ducted?
I flew the 0-2 in VN. Single engine performance, either front or rear,
was not very good. That being said, the rear engine gave better SE
performance. We were told in ground school that the rear prop sucked
air over the wing center section at a higher velocity and gave more
lift than the front engine could push it up and over the center of
wing.
No matter the reason, the bird flew better SE on rear engine. SE on
either engine, the machine turned into a donut making device or worse
if you were not careful.
Big John
****************************************888
On Sun, 5 Aug 2007 22:15:55 -0400, "Kyle Boatright"
"Kingfish" wrote in message
roups.com...
On Aug 5, 8:27 pm, Tony wrote:
If one uses the Cessna 377 Skymaster as an example, it's pretty clear
a pusher prop is more efficient than one pulling.
It is? How do you figure, seeing as the 337 has a tractor AND a pusher
prop?
The single engine climb performance is pitiful regardless of which engine is
caged, but the aircraft has more performance on the back engine than the
front. That may or may not be due to prop efficiency. It could also be due
to reduced fuselage drag. The tractor prop blows a high speed stream of air
across the fuselage, creating its own source of drag. This isn't as much of
a factor with the pusher.
KB
  #32
Old August 10th 07, 01:36 AM posted to rec.aviation.piloting
Tina
I would have thought the gain for the rear engine was because the air
stream was not hitting the windscreen and losing energy that way. The
air coming into the prop comes from all directions (just flowing into
a low pressure area) but the stream leaving is directed.
But if in the newer Skymasters both engines give the same single
engine performance my idea has to be wrong
wing.
Big John
roups.com...
prop?
KB- Hide quoted text -
- Show quoted text -
  #33
Old August 10th 07, 02:40 AM posted to rec.aviation.piloting
Big John
Tina
I can only tell you what Air Force ground school said when checking us
out in 0-2. Know from experience that SE rear was better than SE front
engine. Not much, but better.
Big John
On Thu, 09 Aug 2007 16:36:56 -0700, Tina
wing.
Big John
roups.com...
prop?
monitoring pusher props Ernest Christley Home Built 11 May 17th 06 12:53 AM
Pusher props for WW I fighters John Bailey Military Aviation 3 September 11th 04 11:18 AM
Interested in Tractor vs. Pusher Gyroplane Dunewood Truglia, Esq. Rotorcraft 1 July 2nd 04 05:26 PM
1/2 VW and a shrouded/ducted propeller? BllFs6 Home Built 9 May 6th 04 06:33 AM
Ducted Fan Design David Home Built 5 February 7th 04 07:15 AM
