Windows into the Class A airspace
Old August 10th 07, 05:12 PM posted to rec.aviation.soaring
Default Windows into the Class A airspace
I know that several glider operations in the US have negotiated "wave
windows" to allow gliders to fly in wave above 18,000 feet. At Jean,
we sometimes get thermals (near Mt. Charleston) that extend well into
the Class A. (though how far, I don't know, since I can't go there!)
What is the process to get a waiver from the FAA, and how difficult
is it? I'd like to get my diamond altitude, but have limited
opportunity to travel.
TIA
Old August 10th 07, 10:12 PM posted to rec.aviation.soaring
Frank Whiteley
TIA
Negotiate with your local ARTCC
Sample doc
http://www.soarcsa.org/wave_agreement.htm
Old August 10th 07, 10:18 PM posted to rec.aviation.soaring
TIA
This link describes the LOA we set up in the Northwest:
http://www.nwi.net/~blanikam/css/lift.htm
Tom
Old August 10th 07, 10:46 PM posted to rec.aviation.soaring
On Aug 10, 1:44 pm, Ian Cant
Do any existing LOAs for wave windows allow for non-transponder
flights ?
Absolutely. The ones I am aware of in the Sierras don't require a
transponder.
Not that I don't fly without a transponder.
Darryl
Ian
negotiated 'wave
windows' to allow gliders to fly in wave above 18,000
feet. At Jean,
extend well into
I can't go there!)
and how difficult
limited
TIA
Tom
Old August 11th 07, 11:32 AM posted to rec.aviation.soaring
CindyB
It is easier to travel "All the Way" to California City, and use our
window.
But sure, you can call your FSDO and start the process.
Better that you discuss the process with the Jean club first, since
they
have gone through LOA creation for your local windows through the
Class B.
SSA Regional Director Jay McDaniel would be a good place to start.
Windows at Cal City and at Minden both allow flying Class A without
transponders, and others may as well. Cal City has a couple different
LOAs
depending on whether the military is flying here or not. We can joint
use WITH the
TXPs, or fly without when the Dept of Defense boys are standing down.
To prevent confusing glider pilots, or ATC, the Region 12 LOAs require
pilots to
have a ground briefing from the FBO, and that the windows are only
opened/closed
by the FBO from the ground.
Two pilots flew Sierra wave here last Sunday during XC flights from
Cal City.
Wave let Gary Ittner get home, and Marty Eiler post a pile of OLC
miles.
Soar safely,
Cindy B
TIA
Transponders Above Class C Airspace Jim Vincent Soaring 20 May 15th 07 05:36 PM
Class A airspace flying_monkey Soaring 66 October 22nd 06 04:38 PM
Class C Airspace Discussion Mike Granby Piloting 48 April 18th 06 01:25 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 03:53 PM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 10:53 PM
