Plating 4130 parts
Old August 11th 07, 01:26 PM posted to rec.aviation.homebuilt
Blueskies
Default Plating 4130 parts
"Stealth Pilot" wrote in message ...
whatever process you use get a tube of Duralac and smear the face of
the metal abutting the wood with duralac, then push them into position
and bolt. this is a jointing compound designed to prevent corrosion
between dissimilar materials.
it is used in aviation and it works.
the rest of what you are doing is quite ok.
Thanks. I'll do that! Would you put a bit on the bolts as well?
certainly. dip any rivets you use in it as well. smear it in a
continuous coating between dissimilar materials and let it squish out
as you nut up the fasteners. wipe off the excess. it dries/cures to
something like a rubbery coating.
works metal(steel etc) to aluminium as well.
Stealth Pilot
Does anyone see a similar product sold in USA?
Welding 4130... Blueskies Home Built 20 March 1st 07 01:33 AM
ELECTRO-PLATING Chuck Home Built 1 December 14th 04 12:44 AM
Chrome plating rocker covers Jim General Aviation 4 May 14th 04 05:31 AM
Chrome plating rocker covers rip Owning 3 May 14th 04 05:31 AM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 03:04 PM
