Military HF communications under attack
Old September 29th 03, 06:27 AM
Gene Storey
Default Military HF communications under attack
The FCC is full speed ahead with its BPL (Broadband over Powerline)
rule-making, and the U.S. Air Force is looking to spend billions now on
replacement communications systems, as the use of HF radio will no
longer be possible. Some studies have even predicted that interference
problems will go all the way into the aircraft VHF navigation and voice
bands. "Certainly, the end of LORAN and marine DGPS is at hand" said
William C. Brodie, Air Force Director of Communications.
FCC Commissioner Abernathy says that BPL will be "Broadband
Nirvana." The military is trained to adapt, and they will adapt to
consumer needs.
http://hraunfoss.fcc.gov/edocs_publi...C-239079A1.pdf
Old September 29th 03, 06:37 AM
Tarver Engineering
"Gene Storey" wrote in message
consumer needs.
I don't see the people, or the quotes you mention in the URL.
What is it you are supposed to be Storey?
Old September 29th 03, 05:54 PM
phil hunt
longer be possible.
Why not?
problems
What's causing the interference?
bands.
Why?
And is it?
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
Old September 29th 03, 08:24 PM
Nigel Isherwood
"phil hunt" wrote in message
longer be possible.
Why not?
problems
According to http://www.arrl.org/news/stories/2003/08/08/2/?nc=1 , BRL is
using frequecies of 2 - 80 MHz (i.e. HF and sneaking into the bottom end of
VHF). I suspect that the power cables are acting as antenna.
bands.
Why?
And is it?
Old September 29th 03, 08:28 PM
Tarver Engineering
"Nigel Isherwood" wrote in message
longer be possible.
Why not?
problems
of
The lines are pretty "long" at those frequencies, to make much of an
antenna.
Old September 30th 03, 01:54 AM
Gene Storey
longer be possible.
Why not?
Tune your radio to 60 Hz.
After BPL 2 mHz to 80 mHz (and their harmonics) will have trash on the
whole spectrum.
Old September 30th 03, 02:55 AM
longer be possible.
Why not?
whole spectrum.
C'mon Gene, try to make some sense here will you?...why should
one tune to 60 Hz? (the power line freq btw). Pls do explain what
the hell you're talking about.
-Gord.
Old September 30th 03, 04:23 AM
Dave Holford
longer be possible.
Why not?
whole spectrum.
-Gord.
I presume he is trying to make the, valid, point that all those power
lines radiate a very nice signal at 60Hz, and by implication that they
will do the same if BPL is permitted to transmit digital data between 2
and 80MHz over the same lines.
It's late, so I'm not going to try and look it up now, but IIRC BPL has
been banned in some administrations for precisely that reason - ISTR
that Japan is one such administration.
BTW John - Long (very long) wires make excellent antennas provided that
they are at least several wavelenghts long.
Dave
Old September 30th 03, 04:24 AM
Gene Storey
The power line frequency (after BPL) will include the frequencies
2 to 80 MHz and the harmonics. I was just using 60 Hz a poor example.
WWV time signals will be wiped-out. NDB navigation sites will be
wiped out. Etc, etc. The noise floor in the 2-60 MHz band will be
significantly higher than it is now, thus requiring higher power, or a
change in operating frequency.
Old September 30th 03, 08:29 AM
Keith Willshaw
Scottish Power are already running broadband over power lines,
this doesnt seem to have wiped out HF communication
and the authorities in the UK who jealously guard radio
frequencies seem not to be over worried.
Keith
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 07:12 PM
B Nice war - here's the bill Alan Minyard Military Aviation 32 September 20th 03 07:36 AM
Bu$h Jr's Iran-Contra -- The Pentagone's Reign of Terror PirateJohn Military Aviation 1 September 6th 03 11:05 AM
04 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 5th 03 03:57 AM
07 Aug 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 8th 03 03:51 AM
