#251
#252
"Newps" wrote in message . .. wrote: And several Mountain Flying books mention that specifically. The official temperature anywhere is always in the shade. Ever seen a runway in the shade? The runway will no doubt have a higher temperature and the air above will be warmer than reported but how high would you need to fly to reach the reported air temperature as measured in the shade? An irrelevant question if you can't get there in the first place. But if you want an answer just look at the standard lapse rate as a start. Remember, too, that a thermometer held in the sun is going to read higher than a thermometer in the shade. What it's reading is the sunlight on skin or a thermometer, not the air temp. That's why they takes temps in the shade -- the heat transfer is much different. |
#253
"Dudley Henriques" wrote in message ... john smith wrote: Following the Palm 90 crash in Washington DC, I heard someone in aviation say something to the effect that if you are not airborne within 30-seconds of brake release following throttle up, abort and determine why you had not reached flying speed. I wouldn't be a fan for such a rule. Yep, way too general. You need to have specific standards for the plane and the airport, and follow those considerations when faced with a need to abort a takeoff. -- Jim in NC |
#254
Morgans wrote:
"Dudley Henriques" wrote in message ... john smith wrote: Following the Palm 90 crash in Washington DC, I heard someone in aviation say something to the effect that if you are not airborne within 30-seconds of brake release following throttle up, abort and determine why you had not reached flying speed. I wouldn't be a fan for such a rule. Yep, way too general. You need to have specific standards for the plane and the airport, and follow those considerations when faced with a need to abort a takeoff. For a T38, going into max AB from a standing start, at 30 seconds I'm busting 10 thou at .9 mach :-)) 30 seconds is a LOT of time in high performance airplanes. Time generally is a bad data point for an abort...WAY too many variables as you have correctly noted. -- Dudley Henriques |
#255
On Sep 13, 8:39 pm, "Morgans" wrote:
I wouldn't be a fan for such a rule. Yep, way too general. You need to have specific standards for the plane and the airport, and follow those considerations when faced with a need to abort a takeoff. I can just imagine the pilot sitting there on the take off roll "one thousand one, one thousand two....". -Robert |
#256
Robert M. Gary wrote:
On Sep 13, 8:39 pm, "Morgans" wrote: I wouldn't be a fan for such a rule. Yep, way too general. You need to have specific standards for the plane and the airport, and follow those considerations when faced with a need to abort a takeoff. I can just imagine the pilot sitting there on the take off roll "one thousand one, one thousand two....". -Robert ......and put this guy in a Lear at 30 seconds and see if he can still see the runway behind and under him :-))) -- Dudley Henriques |
#257
On Thu, 13 Sep 2007 19:45:44 -0700, "Matt Barrow"
wrote: "Newps" wrote in message ... wrote: And several Mountain Flying books mention that specifically. The official temperature anywhere is always in the shade. Ever seen a runway in the shade? The runway will no doubt have a higher temperature and the air above will be warmer than reported but how high would you need to fly to reach the reported air temperature as measured in the shade? An irrelevant question if you can't get there in the first place. But if you want an answer just look at the standard lapse rate as a start. Remember, too, that a thermometer held in the sun is going to read higher than a thermometer in the shade. What it's reading is the sunlight on skin or a thermometer, not the air temp. That's why they takes temps in the shade -- the heat transfer is much different. That is the reason for my question. Surely standard lapse rate does not apply? I'm wondering if the ground temperature will reduce quickly as you climb. In other words will the air temperature drop quickly as you leave ground effect or will it continue for many tens of feet? I presume if there's any cross wind the hotter air above the runway will drift sideways so maybe the effect will be less.. |
#258
news ![]() On Thu, 13 Sep 2007 19:45:44 -0700, "Matt Barrow" wrote: "Newps" wrote in message ... wrote: And several Mountain Flying books mention that specifically. The official temperature anywhere is always in the shade. Ever seen a runway in the shade? The runway will no doubt have a higher temperature and the air above will be warmer than reported but how high would you need to fly to reach the reported air temperature as measured in the shade? An irrelevant question if you can't get there in the first place. But if you want an answer just look at the standard lapse rate as a start. Remember, too, that a thermometer held in the sun is going to read higher than a thermometer in the shade. What it's reading is the sunlight on skin or a thermometer, not the air temp. That's why they takes temps in the shade -- the heat transfer is much different. That is the reason for my question. Surely standard lapse rate does not apply? I'm wondering if the ground temperature will reduce quickly as you climb. In other words will the air temperature drop quickly as you leave ground effect or will it continue for many tens of feet? I presume if there's any cross wind the hotter air above the runway will drift sideways so maybe the effect will be less.. IIRC, there is a large difference within the first few feet, and the first few tens of feet; but I don't recall what stardard there might be, nor the effects of wind and ground clutter. Logically, everything would have some influence... Peter |
#259
wrote in message news ![]() On Thu, 13 Sep 2007 19:45:44 -0700, "Matt Barrow" wrote: An irrelevant question if you can't get there in the first place. But if you want an answer just look at the standard lapse rate as a start. Remember, too, that a thermometer held in the sun is going to read higher than a thermometer in the shade. What it's reading is the sunlight on skin or a thermometer, not the air temp. That's why they takes temps in the shade -- the heat transfer is much different. That is the reason for my question. Surely standard lapse rate does not apply? SLR is only a _standard_ rate. It can be effected by pressure, inversions, wind, even the terrain. In this latter point, it's probably nullified in the first hundred or so feet. I'm wondering if the ground temperature will reduce quickly as you climb. That would depend on several factors including those mentioned above. A wind shear would probably have a great effect. In other words will the air temperature drop quickly as you leave ground effect or will it continue for many tens of feet? Ground effect can be ten feet, or a few hundred. It would be different if the runway surface was asphalt as opposed to concrete (different albedo). I presume if there's any cross wind the hotter air above the runway will drift sideways so maybe the effect will be less.. Possibly, but it would depend on the wind SPEED. -- Matt Barrow Performance Homes, LLC. Cheyenne, WY |
#260
My guess, from watching the video and hearing about the number of people aboard, was that the aircraft was overloaded. And the only reason anyone died was probably that the plane flipped over, otherwise they might have all walked away from it. Why guess when you can fire up your simulator and tell us exactly what happens at 107 F and 230 lbs overweight at Cameron park with a tailwind? ![]() |
| Oshkosh P-51 crash video | Frank from Deeetroit | Aviation Photos | 0 | July 30th 07 07:06 PM |
| S-3 Crash Video | Sanderson | Naval Aviation | 0 | June 13th 05 11:22 PM |
| Orlando Crash Video | Jay Honeck | Piloting | 35 | January 21st 05 04:30 AM |
| VIDEO: Helicopter crash | Micbloo | Rotorcraft | 0 | November 3rd 04 04:28 AM |
| Video of crash 206 | gaylon9 | Rotorcraft | 9 | December 2nd 03 05:53 PM |
