#91
In article , Guy Alcala
writes The V-2 was supersonic as it came down, so it would explode first then the sonic boom would be heard. Whether this was identifiable above the sound of the warhead explosion itself, I couldn't say. Probably not by the average bystander. I'd imagine that would be pretty low on their priorities at that moment, as they say "If you heard the bang you'd survived". -- John |
#92
"Guy Alcala" wrote in message ... Lawrence Dillard wrote: I'd sure like to know where the "77mm" stuff started. I've seen this mentioned in similar accounts, especially in the early war, but the Germans didn't have '77s'. Yes they did. They had the FK 96/16 left over from WW1. It was built in large numbers as a counter to the French 75mm http://www.landships.freeservers.com..._fk16_info.htm Keith |
#93
Keith Willshaw wrote:
"Guy Alcala" wrote in message ... Lawrence Dillard wrote: I'd sure like to know where the "77mm" stuff started. I've seen this mentioned in similar accounts, especially in the early war, but the Germans didn't have '77s'. Yes they did. They had the FK 96/16 left over from WW1. It was built in large numbers as a counter to the French 75mm http://www.landships.freeservers.com..._fk16_info.htm H'mm. the references I have all list the FK 16 n/A (neuer Art.) used in WW2 as 7.5 cm (75mm), but I suppose this could be one of those situations where the caliber was changed in name but not in fact. I wonder how many were still around and in use in WW2. It seems unlikely that any were issued to front-line divisions, as there seem to have been enough FH 18s (or even rechambered Russian 76.2mms) for them. Guy |
#94
So...
Howzabout thru mach one straight up? Caveat: from brake release (e.g: relying on thrust/weight only) Who: ?? What: F-15?or -16? When: Early/mid-70's? |
#95
So...
Howzabout thru mach one straight up? Caveat: from brake release (e.g: relying on thrust/weight only) Who: ?? What: F-15?or -16? When: Early/mid-70's? Caveat furthur clarification: e.g: no smash |
#96
"Guy Alcala" wrote in message ... Keith Willshaw wrote: H'mm. the references I have all list the FK 16 n/A (neuer Art.) used in WW2 as 7.5 cm (75mm), but I suppose this could be one of those situations where the caliber was changed in name but not in fact. I wonder how many were still around and in use in WW2. It seems unlikely that any were issued to front-line divisions, as there seem to have been enough FH 18s (or even rechambered Russian 76.2mms) for them. Guy The caliber of the FK16 was changed in fact, the FK16 n/A was built from 1934 with new barrels to replace the 77mm FK 16's which were left over from WW1 but in 1939 some 300 examples of the older gun were apparently still in service being largely phased out by 1942. I'll agree that few if any front line units would be so equipped and they seem mostly to have been used for training. Keith |
#97
"Mike Marron" wrote in message ... So... Howzabout thru mach one straight up? Caveat: from brake release (e.g: relying on thrust/weight only) Who: ?? What: F-15?or -16? When: Early/mid-70's? Who: Roland Beamont What: English Electric Lightning When:1959/60 The Lightnings initial climb rate was 50,000 ft per minute which is slightly less than that of the F-15 and better than the F-16 I recall seeing one do its party trick at RAF Middleton St George in the 60's , take off on full reheat, unstick and then climb out at 80 degrees going supersonic while still over the field Impressive as hell and boy was it noisy. Of course you had to declare a fuel emergency pretty much straight away but still ![]() Keith |
#98
"Keith Willshaw" wrote:
"Mike Marron" wrote: So... Howzabout thru mach one straight up? Who: Roland Beamont What: English Electric Lightning When:1959/60 The Lightnings initial climb rate was 50,000 ft per minute which is slightly less than that of the F-15 and better than the F-16 I recall seeing one do its party trick at RAF Middleton St George in the 60's , take off on full reheat, unstick and then climb out at 80 degrees going supersonic while still over the field Wasn't the Lightning the first plane to do Mach 1 at sea level? -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#99
"Chad Irby" wrote in message ... "Keith Willshaw" wrote: "Mike Marron" wrote: So... Howzabout thru mach one straight up? Who: Roland Beamont What: English Electric Lightning When:1959/60 The Lightnings initial climb rate was 50,000 ft per minute which is slightly less than that of the F-15 and better than the F-16 I recall seeing one do its party trick at RAF Middleton St George in the 60's , take off on full reheat, unstick and then climb out at 80 degrees going supersonic while still over the field Wasn't the Lightning the first plane to do Mach 1 at sea level? Pass, it was designed as a interceptor to knock down soviet nuclear bombers, hence the performance, I seem to recall it was less capable at low level . Keith |
#100
"Keith Willshaw" wrote in message ... "Guy Alcala" wrote in message ... Keith Willshaw wrote: H'mm. the references I have all list the FK 16 n/A (neuer Art.) used in WW2 as 7.5 cm (75mm), but I suppose this could be one of those situations where the caliber was changed in name but not in fact. I wonder how many were still around and in use in WW2. It seems unlikely that any were issued to front-line divisions, as there seem to have been enough FH 18s (or even rechambered Russian 76.2mms) for them. Guy The caliber of the FK16 was changed in fact, the FK16 n/A was built from 1934 with new barrels to replace the 77mm FK 16's which were left over from WW1 but in 1939 some 300 examples of the older gun were apparently still in service being largely phased out by 1942. I'll agree that few if any front line units would be so equipped and they seem mostly to have been used for training. Keith Robert Nelson of the US 3rd Division wrote that at Anzio (he was there) they used a captured "German 77" as an anti-tank weapon because they were more effective than "our 57s." http://tinyurl.com/pst6 Cheers. |
| Thread Tools | |
| Display Modes | |
| bell xp-77-info? | J. Paaso | Home Built | 0 | March 25th 04 01:19 PM |
| It broke! Need help please! | Gerrie | Home Built | 0 | August 11th 03 11:24 PM |
