Rod ends in single shear
Old September 29th 07, 11:56 PM posted to rec.aviation.homebuilt
Ed Sullivan
Default Rod ends in single shear
On Fri, 28 Sep 2007 05:18:45 GMT, Ed Sullivan
On Thu, 27 Sep 2007 21:18:38 -0400, Ernest Christley
The horns on the Dyke Delta are .100 4130. The prototype had flown for
over 40 years. If the horn was thin enough to deform from the rod end
being in single shear, it will bend just as much in double shear. There
is room for twist in the rod end even with both sides captured.
That may be so, but it has not been my experience. My horns and bell
cranks are a bit heavier however.
Anyway I'm too old to care
Ed
Seems to me I have seen bell cranks on both Pitts
Specials and Christen Eagles. They appeared to be no thicker than
..0625 and were in double shear as you describe. They must have held up
pretty good considering the stresses imposed on them in unllimited
aerobatics.
Old September 30th 07, 07:18 AM posted to rec.aviation.homebuilt
Dan[_2_]
Ed
aerobatics.
One thing I haven't seen mentioned is the length of the bell crank
arm or horns. I would assume a longer throw would require thicker
material assuming similar material.
Dan, U.S. Air Force, retired
Shear Pins for Propellors? Rich Lemert Piloting 25 April 3rd 05 09:04 PM
IFR w/pax under Single-Pilot/Single Aircraft 135 Bravo8500 Owning 20 March 9th 05 09:37 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
