Ground launching equipment question
Old October 29th 07, 03:56 PM posted to rec.aviation.soaring
Default Ground launching equipment question
Last weekend our club did some ground launching from a nearby dry
lake. I had two very successful launches using our "cheap" 1800'
rope. With the cheap rope we don't use a parachute on the cable.
When I tried to launch with the 3000' spectra rope, equipped with a
parachute, the chute at least partially opened when the glider was
going around 40 knots, and depsite full right rudder, the glider
ground looped to the left. All the pictures I've ever seen
(admittedly very few) of the cable chute used for winch or vehicle
tows seem to show the chute' is completely 'closed' when the rope is
still attached to the glider. I'm sure pilot error had a part in this,
but it really seemed that when the chute opened, I lost what little
rudder authority I had. It also occurred to me that the
Speed Astir verticle stab and rudder is one of the shortest
(vertically) around, and that may have been a contributing factor.
The dust cloud was quite impressive!
Old October 29th 07, 05:10 PM posted to rec.aviation.soaring
Dan G
What's the distance between the crown of the parachute and the
attachment to the glider? Should be at least 30 feet.
Dan
Old October 29th 07, 06:30 PM posted to rec.aviation.soaring
Dan
Seemed more like 10 or 15, but certainly less than 30.
Old October 29th 07, 10:30 PM posted to rec.aviation.soaring
Dan G
On Oct 29, 7:07 pm, John Smith wrote:
I winch launch a lot, but have never seen 30. 10 to 15 seems reasonable
to me.
That's the general recommendation from Tost (or rather, 10m is). We
used to use less but now use the correct length - it's a lot more
comfortable.
Dan
Old October 29th 07, 10:35 PM posted to rec.aviation.soaring
to me.
comfortable.
Dan
Shouldn't the 'chute stay closed though? I'm sure I wasn't clear, but
that was the root of my question.
Old October 29th 07, 10:46 PM posted to rec.aviation.soaring
Dan G
Well yeah, it should! The tension through the shroud lines should keep
it closed, but if that's too low the natural tendency for the chute to
inflate overcomes it. That could either be down to a poor design -
I've seen several parachutes that seem to inflate whatever - or
perhaps down to less-than-perfect pilot/winch/car driver technique.
Dan
Old October 30th 07, 08:49 AM posted to rec.aviation.soaring
Bert Willing[_2_]
The chute will open as soon as the force on the rope gets too low. On a
winch launch, this is typically the case if the pilot "follows the rope"
instead of pulling gently in order to rotate into initial climb attitude.
Bert
ps.com...
Old October 30th 07, 07:42 PM posted to rec.aviation.soaring
On Oct 30, 1:49 am, "Bert Willing" bw_no_spam_ple...@tango-
Bert
On this (aborted) launch, I was still rolling, both wheels on the
ground. I noted the chute opening in front of other gliders too,
while on the ground. I'd had no problems launching with our non-
chuted poly rope.
Old October 30th 07, 09:35 PM posted to rec.aviation.soaring
Andy[_1_]
On Oct 30, 12:42 pm, wrote:
On Oct 30, 1:49 am, "Bert Willing" bw_no_spam_ple...@tango- On this (aborted) launch, I was still rolling, both wheels on the
chuted poly rope.
How springy is 3000 feet of spectra? I imagine that would be more of
a factor for auto tow than winch. I'm speculating that the problem
with the spectra launch is not the parachute itself but the dynamics
of the rope tension. The result may be strongly dependant on how the
tow vehicle accelerarates to nominal launch speed.
Andy
Buy and Sell Ground Support Equipment knowmad Piloting 0 September 29th 05 07:46 PM
Used Ground Support Equipment knowmad Aviation Marketplace 0 September 29th 05 07:33 PM
Let's talk ground launching........ Rusty Soaring 23 September 4th 05 10:59 PM
Let's talk ground launching..... Steve Leonard Soaring 0 September 2nd 05 11:48 PM
From the ground up ... question about riveting Marco Rispoli Home Built 4 July 19th 04 01:05 AM
