alt. static.
Old November 4th 07, 02:09 AM posted to rec.aviation.piloting
Andrew Sarangan
Default alt. static.
On Nov 3, 3:01 pm, C J Campbell
On 2007-11-02 15:55:56 -0700, Andrew Sarangan said:
On Nov 1, 12:58 am, wrote:
I was preparing to fly a cessna 172SP the other day and as I usually
do I pulled the alt.static expecting a small wiggle in the gauges. And
got nothing. This was the first time I i got no response from the
gauges. I was told by somebody at the front desk this was common and
that many of the 172's show no movement at all. But.. if this is so..
how can I be certain the alt.static would work when I needed it.
Thanks in advance.
I have seen some airplanes show a small wiggle, and some that don't
when the static port is turned on or off. There is no easy way to
positively verify that your alternate static is working. If you are up
to it, you could suck on the static port and ask someone to verify
whether the VSI is showing a climb. Then repeat with the alt static
open. The latter should not show a climb. Or get a suction for this
purpose. Just a thought. I have never done it this way.
You don't want to, either. I have had avionics guys tell me that this
can damage the instruments.
Why would applying suction on the static port damage anything? Isn't
that what the atmosphere is doing during a climb?
Old November 4th 07, 02:55 AM posted to rec.aviation.piloting
Thanks in advance.
Like everything else in life; depends on how hard you suck...
Jim Pennino
Remove .spam.sux to reply.
Static Discharge gman Piloting 12 March 24th 07 08:56 PM
KX-155 static Robert M. Gary Piloting 3 September 13th 06 04:40 AM
KX-155 static Robert M. Gary Owning 4 September 13th 06 04:40 AM
IFR static discharge [email protected] Home Built 0 April 2nd 06 09:06 PM
static wicks keepitrunning Home Built 6 January 1st 06 02:01 AM
