ADF Problem
Old November 23rd 07, 11:50 PM posted to rec.aviation.owning
Al[_2_]
Default ADF Problem
The ADF in our Cessna 172 isn't working right. Yes, we can receive the
audio but the indicator only swings through 180 degrees on the indicator
(from 180 to 360) and doesn't point in the direction of the transmitter.
We tried repalcing the indicator with no improvement. Can someone
ewnlighten us as to other remedies? Simple antenna checks? Clues? All
in all, it's not worth spending a pile of money on an ADF. Of course,
we can still get the football and baseball games on the radio, so it's
at least worth something. Plus it fills a spot on the stack.
Thanks
Al
1964 Skyhawk
Spokane
Old November 24th 07, 12:12 AM posted to rec.aviation.owning
mikem
Default ADF Problem
Thanks
Al
1964 Skyhawk
Spokane
Next time you fly, switch off the ALT half of the Master Switch. If
the needle then points to the station, your alternator filter has
fallen off or failed.
Old November 24th 07, 12:27 AM posted to rec.aviation.owning
Mike Noel
Default ADF Problem
Check the antenna connectors. My Archer had a loop antenna mounted on the
belly and a sense antenna mounted from cabin top to the vertical stabilizer.
When I unscrewed and removed the loop antenna I found quite a bit of
contact corrosion. The female side of the plug was a mini tube socket that
I was able to buy at a local electronics store.
I eventually pulled out the ADF and installed an Air Gizmo panel mount for
my 496.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Old November 24th 07, 06:33 AM posted to rec.aviation.owning
Default ADF Problem
You didn't say what kind it was, but as the other poster said it
relates to
the antenna. There are a pair of coils at right angles. You symptom
suggests
that the fore aft one is OK but the other one is dead either for
connection reasons
or some other failure.
You could check it with an ohmmeter.
Bill Hale
my 496.
Best Regards,
Mike
Old November 24th 07, 01:24 PM posted to rec.aviation.owning
B A R R Y
Default ADF Problem
On Fri, 23 Nov 2007 16:27:42 -0700, "Mike Noel"
my 496.
Funny you should mention that...
Our plane had the ADF removed in the mid-90's by it's previous
owners, because the never needed it. We have dual VOR's, DME, and a
handheld GPS similar to yours.
The airport I fly to most often with my wife has "ADF Required" on the
ILS. ;^(
302 Problem Hal Soaring 11 August 17th 04 07:27 PM
ADF Problem tony roberts Owning 13 May 12th 04 03:59 AM
Problem with this NG? Regnirps Military Aviation 10 April 29th 04 04:39 PM
ILS problem Bernie Samms Simulators 2 September 17th 03 02:36 AM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 05:25 PM
