C-130 rocket assisted takeoff length
Old October 19th 03, 09:58 PM
Tex Houston
"Gord Beaman" wrote in message
news
Peter, what did they do to the Herc that they flew off of the
Forrestal(?) ? (without JATO at that!)
-Gord.
Still around as a USMC KC-130.
Tex
Old October 19th 03, 11:46 PM
Alan Minyard
On Sun, 19 Oct 2003 19:19:11 GMT, Guy Alcala
" wrote:
Michael Williamson
Well, it does help with ground run if you can guarantee a 30 kt
wind down the runway every time...
Mike
That's true isn't it?...one tends to forget that ~30 knots is a
LOT of airspeed gain, especially at the top of the take-off roll
range, takes a comparatevly long time to gather that extra speed.
An a/c that you normally rotate at 105 you now rotate at 75
(well, not really but you get my drift)
There's also the advantage that you don't have to pull G off the end of
the deck, in order to leave the 'ground' and climb over obstacles.
Indeed, you can even sink a bit. And of course, the a/c was almost
certainly nowhere near MTOW -- max. landing weight (8fps) is only
130,000 lb., vice the 155,000 or 175,000 lb. MTOW, and I imagine the
a/c was well under max. landing weight when it landed. The Herc's
power-on stall speeds (100% flaps) at landing weights are under 100
knots. For instance, at a landing weight of 110,459 lb. it has power
off/on stall speeds (100% flaps) of 80/65 kts. At 122,586 lb. they're
91/75 kts. 50% flaps would be used for takeoff, but even with no wind,
at a t/o weight of 100,000 lb. the a/c has a ground run of only 1,500
ft. at sea level. Add 30 kts or more of wind over deck and the Herc's
ability to land or takeoff from a large deck carrier isn't a surprise.
Guy
And, if you have a 15 knot wind, you can easily get 45 kts over the
deck. I never asked Adm Flately what the wind conditions were, and I
always regretted it :-(
Al Minyard
Old October 20th 03, 03:16 AM
news
-Gord.
Tex
Oh yes indeed, Quite successful, I have the film clips here,
impressive. Didn't look like it dropped at the end of the deck
either, seemed to be climbing smartly.
-Gord.
Old October 20th 03, 03:19 AM
Al Minyard
Yes, must have been fun talking to him about it...pretty
impressive feat.
-Gord.
Old October 24th 03, 03:20 AM
Daryl Hunt
"Steve R." wrote in message
The 130J isn't set up for Jato. Those Dowty props and RR engines really
toss
it in the air without it though!
Steve
I can't speak of the distance that a Jato C-130D took since it was on snow
(skibird) but you tried to bounce the nose into the air at about 60kts.
When the ski cleared, it emmediately popped to about 90kts and you popped
the 8 jato bottles and were airborne and going up. That is got to be the
hairiest ride ever.
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
U.S. Air Force award of four rocket launches this year is likely to be delayed Larry Dighera Military Aviation 15 May 14th 04 02:58 PM
Air Force launches rocket with secret military payload from Cape Canaveral Otis Willie Military Aviation 0 September 9th 03 10:07 PM
