Engine configuration
Old December 13th 07, 06:22 PM posted to rec.aviation.homebuilt
Darrel Toepfer
Default Engine configuration
"Bill Daniels" bildan@comcast-dot-net wrote:
I thought the original question was about inverted "V" engines. While
the LOM and Mikron engines are excellent products, they are inverted
I-6 and I-4 engines, not a "V".
Bootstrap a couple of them together! ;-)
Didn't we discuss an old US tank engine in here? It was 5 or more
engines geared together. Lots of unique engines in tanks, air cooled gas
radials, 90 degree "V" diesels, etc...
BTW, neither the LOM or the Ranger engines suffer from 'hydraulic
lock' which seems to be mostly related to P&W radials. I owned a
Ranger inverted in-line 6 which powered a PT - 19 and it never even
smoked on start. I also flew a Zlin with a LOM I-6 and it didn't give
problems.
I think the inverted engines allow a nicer looking cowl and they do
improve the pilots visibility forward and down.
Yep...
Old December 13th 07, 06:26 PM posted to rec.aviation.homebuilt
wright1902glider
From what I've seen historically, the engine configuration had to do
with 5 factors:
1. how to machine it, feed it, and get it lit (this was the major
issue before WW 1)
2. how to keep it cool (hence the popularity of the radial, which was
originally designed to power the Langley aerodrome)
3. because everybody else did it that way
4. cost
5. how to cram it into the airframe
Number 3 now seems to be the most popular reason to use an air-cooled
flat.
Harry
Old December 13th 07, 07:19 PM posted to rec.aviation.homebuilt
Alan Baker
Michael Henry wrote:
GTH wrote:
Michael Henry a écrit :
why isn't the Lycoming O-540 or the Continental O-520 an
inverted V?
They are derived from opposed engines, and the manufacturers thought
easier to retain the same cylinders and cylinder heads as their 4
cylinder counterparts.
OK so I just push my question back one generation: why is the O-360 not
an inverted V?
I'm asking more from a theoretical point of view. What is it that makes
the opposed configuration more attractive than the V configuration for
air-cooled engines? Likewise: what is it that makes the V configuration
more attractive than the opposed configuration for liquid-cooled engines?
There are new aircraft engine designs out the the Jabiru as an
air-cooled example and the Orenda as a liquid-cooled example. They
follow the same pattern that has become the norm.
There have been a number of aircooled inverted engines in the post WWII
period.
...and in the pre-WWII period! The deHavilland Gipsy Major being a
notable example.
I think one of the factors you're overlooking is vibration.
Certain engine configurations have less vibration due to the arrangement
of the reciprocating and revolving components:
A 90 degree V-8; a straight-6; ...
....and a flat-4.
A V-4 would have more vibration than a flat-4.
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling four feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect if you
sit in the bottom of that cupboard."
Old December 13th 07, 07:58 PM posted to rec.aviation.homebuilt
GTH
The Jabiru was designed as a replacement for the VW, and the designers
adopted the same configuration and even the same RPM.
Best regards,
Gilles
http://contrails.free.fr
Old December 13th 07, 08:02 PM posted to rec.aviation.homebuilt
GTH
...and a flat-4.
Right on that one.
Also it is interesting to observe that only *short* crankshaft engines
achieved success in civilian airplanes after WWII : radials, short flat
fours, or sixes.
Inline engines with their longer crankshaft have only survived in
marginal quantities in Eastern Europe.
Best regards,
Gilles
Old December 13th 07, 09:12 PM posted to rec.aviation.homebuilt
Opposed engines are simple and strong. Inverted engines are much
more complicated.
First: The cylinder extends into the crankcase so that oil thrown off
the bearings doesn't drain off the case walls and run into the
cylinders. Could cause hydraulic lock, certainly would use a lot more
oil.
Second: That oil can't be stored in the crankcase. There has to be a
separate oil tank, usually on the firewall.
Third: The oil has to be pumped out of the engine into the tank. My
Auster had a Gipsy Major inverted inline, and it had THREE oil pumps:
one to pump oil from the tank into the engine's workings for
lubrication, and two more to scavenge the case; one pumped oil out of
the front, the other out of the back. Because the engine gets tipped
up and down so much in an airplane, two outlets are necessary lest oil
pile up and start running into the jugs at the low end. One pump can't
do them both, or it would be happy to suck air from the high end
instead of pulling the oil out of the low end.
Fourth: The rockers and valve stems need either pressure lubrication
and ANOTHER scavenge pump, or, as with the Gipsy, the covers are taken
off occasionally and filled with oil. A pain, that is.
In spite of all that, I like the looks of the inverted
installation, confirming that, like so much of homebuilding and the
rest of general aviation, emotions usually trump common sense. (Just
look at the beautiful but huge, ridiculously expensive projects some
of us average-income guys start on, and are never able to finish.
Emotions over common sense.)
Dan
Old December 13th 07, 09:48 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Thu, 13 Dec 2007 18:19:14 GMT, Alan Baker
inverted V?
an inverted V?
period.
notable example.
...and a flat-4.
Yea, ever drive a Corsair V4? Even with a balance shaft they are not
smmoth.
Posted via a free Usenet account from http://www.teranews.com
Old December 14th 07, 12:20 AM posted to rec.aviation.homebuilt
Peter Dohm
"Bill Daniels" bildan@comcast-dot-net wrote in message
"Darrel Toepfer" wrote in message
. 18...
I can think of two inverted "V" air cooled aero engines that were
produced in quantity.
One is the German Argus As 10C 240HP used in the Me 108 and the Storch
and the other is the American Ranger V-770 inverted V12.
See: http://www.oldengine.org/members/die...ord/Ranger.htm
and http://en.wikipedia.org/wiki/Argus_As_10
LOM's are still in production: http://www.moraviation.com
I thought the original question was about inverted "V" engines. While the
LOM and Mikron engines are excellent products, they are inverted I-6 and
BTW, neither the LOM or the Ranger engines suffer from 'hydraulic lock'
which seems to be mostly related to P&W radials. I owned a Ranger
inverted in-line 6 which powered a PT - 19 and it never even smoked on
start. I also flew a Zlin with a LOM I-6 and it didn't give problems.
Bill Daniels
This is not my area of occupational or other specialty, but...
I think that you will find that the hydraulic lock, and also the lower plug
fouling problem in the bottom cylinders, is a common problem shared by all
of the radials that I have seen and is not exclusive to Pratt and Whitney.
Basically, the issue is that the oil storage tank is located at the top of
the engine compartment, well above the crankshaft, which has both a major
advantage and a major dissadvantage. The advantage is that the oil will
gravity feed into the intake of the pressure pump--making it very easy to
maintain full oil flow and pressure at any altitude without any requirement
for any additional pump to lift the from the tank to the pressure pump. (I
have no idea whether any reciprocating engines even actually had such a need
at any altitude that they were flown, but it is theoretically possible with
some combination of maneuvering loads and very high altitude.) There is an
additional benefit in that there is no delay between starting the engine and
pumping pressurized oil to the bearings. However, the well known
dissadvantage is that the oil from the storage tank will slowly drain
downward through the clearances of the oil pressure pump and through the
main and big end bearings, and into the lowest cylinders. Over time,
ranging from hours to days, it will fill the "bottoms" of one or more
pistons and drain slowly between the pistons and cylinder walls, between the
ring gaps, and into the combustion chambers of one or more cylinders. The
resulting pools of oil in the combustion chambers then cause the familiar
spark plug fouling and, in extreme cases, hydraulic lock.
As to the matter of inverted Vee engines: Personally, I like them; but I
really don't see any advantage over a "flat" engine, and only a slight
advantage over an upright Vee with offset reduction drive.
In short: Why fix what aint broke?
I hope this helps.
Peter
Old December 14th 07, 04:55 AM posted to rec.aviation.homebuilt
Big John
On Thu, 13 Dec 2007 20:02:54 +0100, GTH
...and a flat-4.
Right on that one.
fours, or sixes.
Best regards,
My first military aircraft was the PT-19A with a 200 HP inverted
Franklin air cooled engine.
Primary reason they are not flying today is the PT-19 had a bunch of
expensive AD's on the wood in the wing.
Don't ever remember the engine over temping and bird did not have any
cowel flaps.
Don't remember any engine failures on field during my Primary Training
period. Chit chat was that it was a good engine.
Big John
Old December 14th 07, 04:57 AM posted to rec.aviation.homebuilt
Big John
On Thu, 13 Dec 2007 12:59:11 GMT, "Paul Hastings"
"Michael Henry" wrote in message
Greetings!
My last post provoked a long and interesting series of threads so I am
emboldened to make another post.
This question concerns the configuration or layout of an engine. I have
noticed that air-cooled engines tend to have an opposed configuration
whereas liquid-cooled engines tend to have a V configuration. Both are
also available inline but I'll take a leap and say these are a minority
(I'm talking about current production engines not historical engines).
There are some liquid-cooled horizontally-opposed engines but I can't
think of any air-cooled "V" engines. Why is this? It suggests to me that
the advantages of the V configuration are specific to liquid cooling. Is
this really the case?
The Wikipedia article on "V Engine" is quite short but it includes this:
"Certain types of V engine have been built as inverted engines,
most commonly for aircraft. Advantages include better visibility
in a single-engined airplane, and lower centre of gravity."
OK, these are two pretty good advantages! There are no disadvantages
listed. So why isn't the Lycoming O-540 or the Continental O-520 an
inverted V?
Regards,
Michael
Lots of motorcycles out there that are air cooled v-twins. Granted they are
limited in horsepower for their displacement. ;^) (that ought to bring out the
Harley guys)
Paul
Paul
What about us Indian guys )
Big John
R172K Approach Configuration facpi Instrument Flight Rules 10 January 5th 07 04:58 PM
V-22 Prop Configuration, 3-vs-4 blades Don McIntyre Naval Aviation 23 April 10th 06 04:23 AM
T-2C Buckeye nav light configuration. Mike W. Naval Aviation 14 March 17th 05 08:05 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 06:57 PM
Hyping the Intermeshing Configuration Dave Jackson Rotorcraft 0 October 31st 03 09:34 PM
