#91
Mxsmanic wrote in
: george writes: If such an unlikely event might occur the pilots will go through their drills. There aren't any drills that would help. Computerised systems falling over is not a new thing That's why the aircrew are there and trained to handle such problems They are not trained to handle such problems. When the aircraft is controlled by computer and the computer fails, there isn't any training that will make any difference. Nope, wrong again. Manual reversion is primitive in a 'bus, but adequate for the task. Of course, don;'t take my word for it. I've only been trained to fly one and have. You are an idiot. Bertie |
#92
On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip
wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? |
#93
Larry Dighera wrote in
: On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Go **** yourself killfile boi Bertie |
#94
On Jan 10, 8:16 am, Larry Dighera wrote:
On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Oh lord no. We pray toward the right and the aircraft responds by turning right. It would be blasphemy to have a connection between controls and control surfaces. Cynical mode off |
#95
george wrote in news:df5c7fac-837e-4313-b2b5-a0bc3f04f011
@d70g2000hsb.googlegroups.com: On Jan 10, 8:16 am, Larry Dighera wrote: On Wed, 9 Jan 2008 19:05:43 +0000 (UTC), Bertie the Bunyip wrote in : Manual reversion is primitive in a 'bus, but adequate for the task. Are you implying that there is a physical link between the flight controls and the control surfaces? Oh lord no. We pray toward the right and the aircraft responds by turning right. It would be blasphemy to have a connection between controls and control surfaces. The rudder and the stab are both stil physically ( hydraulics) attached to the flight controls. Crews are trained to land the airplane using these alone. It hasn't had to be done for real yet. Bertie |
#96
On Wed, 9 Jan 2008 19:43:17 +0000 (UTC), Bertie the Bunyip
wrote in : The rudder and the stab are both stil physically ( hydraulics) attached to the flight controls. Unless there are hydraulic cylinders attached to the flight controls to activate the rudder and elevator (doubtful), there is going to be a requirement for hydrolytic pressure from a pump to activate those control surfaces. If that hydraulic pump can be controlled by the hypothetical hacker through the computer system, vulnerability exists, if the Dreamliner systems are similarly engineered. |
#97
: On Wed, 9 Jan 2008 19:43:17 +0000 (UTC), Bertie the Bunyip wrote in : The rudder and the stab are both stil physically ( hydraulics) attached to the flight controls. Unless there are hydraulic cylinders attached to the flight controls to activate the rudder and elevator (doubtful), there is going to be a requirement for hydrolytic pressure from a pump to activate those control surfaces. If that hydraulic pump can be controlled by the hypothetical hacker through the computer system, vulnerability exists, if the Dreamliner systems are similarly engineered. Go **** yourself Netkkkop Bertie |
#98
On Wed, 9 Jan 2008 19:43:17 +0000 (UTC), Bertie the Bunyip wrote in : The rudder and the stab are both stil physically ( hydraulics) attached to the flight controls. Unless there are hydraulic cylinders attached to the flight controls to activate the rudder and elevator (doubtful), there is going to be a requirement for hydrolytic pressure from a pump to activate those control surfaces. If that hydraulic pump can be controlled by the hypothetical hacker through the computer system, vulnerability exists, if the Dreamliner systems are similarly engineered. Never seen a system where the hydraulic pump was controlled; valves, yes, pumps, no. What would one "control"? -- Jim Pennino Remove .spam.sux to reply. |
#99
#100
On Wed, 09 Jan 2008 22:15:03 GMT, wrote in
: What would one "control"? The motor that drives the pump. |
| What are Boeing's plans? | Pooh Bear | General Aviation | 55 | September 30th 04 08:59 PM |
| What are Boeing's plans? | David Lednicer | General Aviation | 6 | September 27th 04 10:19 PM |
| What are Boeing's plans? | Pooh Bear | Owning | 12 | September 27th 04 10:07 PM |
| What are Boeing's plans? | Pooh Bear | Owning | 13 | September 27th 04 07:05 AM |
| What are Boeing's plans? | Larry Dighera | Piloting | 0 | September 17th 04 12:57 PM |
