Edwards air show B-1 speed record attempt
Old October 27th 03, 08:51 PM
John R Weiss
"B2431" wrote...
On C-130s we had the SPR (single point refuling panel) where they hooked up
nozzel. It had indicators reading pounds for each of the integral tanks.
That's a common arrangement. Tactical aircraft with SPR may not have any
indicator at the panel; simple lights indicating a full/not full tank (closing a
float switch) may be used instead. If a partial fuel load is desired, it must
be selected by fully fueling specific tanks and/or monitoring the cockpit fuel
gauges. In the case where over-the-wing fueling is used (in the past, commonly
done with the wing drop tanks on the A-4), either the tanks are filled
completely or a specific quantity in gallons specified. Even though the A-4
fuel system indicated in pounds, the 300-gallon (2000 lb nominal) drop tanks
were filled with 150 gallons for a "half drop tanks" load, regardless of fuel
type or density. Minor weight discrepancies due to fuel type (JP-4 vs JP-5) or
temperature were disregarded, since fuel planning assumed the worst case (low
density or weight) and performance effects due to slightly higher gross weight
with high-density fuel were negligible.
For the SPR systems with indicators on the panels, the person doing the
refueling needs to know little more regarding the specific fuel upload than the
final total fuel load (or sometimes the load in each tank). By manual or
automatic tank selection and shutoff valves, the tanks are fueled until the
final load is achieved. The fueler does not need to monitor or convert volume
(gallons or liters) to weight or mass (pounds or kilograms) -- he simply uses
the indicators in the aircraft fuel system to directly read the fuel on board in
the airplane's native units.
Sometimes, e.g. when several trucks may be required to refuel a large airplane,
an estimate of required fuel may be given to the fuel company dispatcher so
[s]he can dispatch the appropriate number of trucks. In commercial aviation
this figure is seldom, if ever, used as an "order" for a specific quantity; it
is only a planning guideline.
For example, when arriving at a station in a 747, I will notify the ops center
of the estimated fuel remaining (in Kg) on shutdown. They will then estimate
the fuel load required for the next leg and notify the fuel dispatcher. When
the refueler comes to the airplane, he never knows the number of gallons/liters
required. The airline ramp ops people will tell him the preliminary or final
fuel load in Kg, and the fueler will set that figure on the airplane refueling
panel (the 747-400 is almost completely automatic; once a total fuel load is
set, the airplane system automatically controls the feed to individual tanks).
The fueler has no idea how many gallons, liters, or Kg the airplane will
require -- only the final load. He records the gallons or liters delivered,
after the fact, on the receipt for billing.
The bottom line is that conversion of units is seldom a critical problem in
refueling modern commercial airplanes.
  #132
Old October 27th 03, 11:38 PM
Tarver Engineering
"Pat Norton" wrote in message
Tarver Engineering wrote:
Why change from the units of aerospace to some other arbitrary
set of units in the first palce?
That question does not parse. The problem is not a 'change' from setA
to setB. The problem is multiple units for the same thing. UnitX
coexists with unitY (and perhaps unitZ). You may wish to ask:
Not at all, in the Western World aerospace has been feet, pounds and
clockwise.
I will agree that your alternative units have merit, but not in aerospace.
  #133
Old October 28th 03, 12:40 AM
Tarver Engineering
"John R Weiss" wrote in message
"Tarver Engineering" wrote...
And you start with pounds as the basis and convert to have the fuel
vended, no matter what units of volume are used. Then the weight of the
airplane is checked to see if the fuel got onboard.
So, the FE begins with a takeoff weight, calculates the fuel to be
ordered
and leaves the weight on the dash for the pilot to cross check.
Nope! It is apparent you don't know at all what you are talking
about.
In "a high reliability sysetm" such as that in a 777 or 747-400, the
fuel
vendor is simply told the "final fuel" figure in kilograms
My goodness Weiss, you mean what I wrote in the first place is
completely
correct.
No, your fantasy "explanation" of what you think might happen isn't
anywhere
near "completely correct."
No.
  #134
Old October 28th 03, 12:49 AM
Tarver Engineering
"Alan Minyard" wrote in message
snip
You are right, when do you intend to start the conversion to the inch??
One tenth of a foot is already an American engineering standard for
transportation.
  #135
Old October 28th 03, 06:30 AM
Regnirps
I was visiting relatives in Sweden with my uncle. They had a nice 10 acre farm.
My uncle is from Texas and said he had a farm and could get in his car, drive
all day and still not be to the other side. The Swedish relative said:
"Ya, I had a car like dat vunce too."
-- Charlie Springer
  #137
Old October 28th 03, 06:39 AM
Regnirps
Hey you guys. The French System (Now called Metric though any system of
measurements is a metric) was officially adopted by the US Congress in the
1800's. I think that over a hundred years of refusal by the people would
convince anybody in business to pull a product. Why do you suppose non-profits
and governments still push metric?
-- Charlie Springer
  #138
Old October 28th 03, 11:48 AM
Pat Norton
Michael Williamson wrote:
US military airports now give Terminal Area Forecast
visibility in metres. All without a fuss.
In some cases they might, but the last time I got ATIS
here at Davis Monthan AFB, visibility was in nautical miles
You may be thinking of the METAR rather than TAF. In any case, METARS
use statute miles not nautical miles.
I have just been given the following TAF for Davis Monthan AFB
(visibility in meters):
KDMA 280505 14006KT 9999 BKN290 QNH2990INS WND VRB06KT AFT 17 T29/23Z
T13/13Z
Can you check again?
  #139
Old October 28th 03, 02:11 PM
Jo Stoller
Gord Beaman wrote:
"The court heard he had miscalculated the conversion
from US gallons to litres
Very interesting Pat, thanks.
Here are two mo
The aircraft landed firmly in a steep nose up attitude which caused
the tail area to make contact with the runway surface.
The Loadchit and Load message form was given to the Commander at
Menorca. It was annotated "All weights kilos" ...
Total passenger weight 18,251 kg
Baggage 3,692 kg
On the Loadsheet the Commander had converted the baggage figure into
pounds but had entered the passenger weight as '18251', the weight in
kilograms recorded on the Loadchit. Using the conversion multiple
2.2046, this figure should have been '40236'
http://www.dft.gov.uk/stellent/group...ty_500650.hcsp
The accident occurred when both engines lost power during a ferry
flight from Tangiers to Guernsey. The commander ditched the aircraft
into the sea near the island of Jersey but he did not survive. [...]
The aircraft was not carrying sufficient fuel for the intended flight.
The commander apparently ignored pre-flight and in-flight indications
that he should land and refuel in France.
It is difficult to understand why the commander thought the aircraft
could fly for 8 hours unless he miscalculated the endurance. In
aviation, the variety of units used (eg fuel quantities can be given
in litres, Imperial gallons, US gallons, pounds or kilograms) are a
potential trap for the unwary when the need to convert from one to
another is overlooked or miscalculated.
http://www.dft.gov.uk/stellent/group...ty_502535.hcsp
Bush's guard record JDKAHN Home Built 13 October 3rd 04 10:38 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
U.S. Troops, Aircraft a Hit at Moscow Air Show Otis Willie Military Aviation 0 August 28th 03 11:04 PM
