Wood Laminations and Springback
Old January 24th 08, 01:29 AM posted to rec.aviation.piloting
Kyle Boatright
Default Wood Laminations and Springback
I'm working on the center section for a Hatz. The trailing edge of the
center section is a recurved lamination that provides better access to the
front cockpit.
I've steamed and clamped the strips into a form, and they have taken on some
of the curve, but when I unclamp 'em after they dry, I get significant
springback. The question is whether I need to allow for this in the
finished lamination, or whether the springback will go away when I glue up
the assembly?
FYI, the lamination starts as four 3" x 1/4" strips.
Thanks in advance,
Kyle Boatright
Old January 24th 08, 01:30 AM posted to rec.aviation.piloting
Kyle Boatright
"Kyle Boatright" wrote in message
front cockpit.
some of the curve, but when I unclamp 'em after they dry, I get
significant springback. The question is whether I need to allow for this
in the finished lamination, or whether the springback will go away when I
glue up the assembly?
Thanks in advance,
Kyle Boatright
Never mind.
This was supposed to go to R.A. Homebuilt...
Old January 24th 08, 03:24 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Bertie the Bunyip
On 24 Jan, 00:29, "Kyle Boatright" wrote:
I'm working on the center section for a Hatz. *The trailing edge of the
front cockpit.
springback. *The question is whether I need to allow for this in the
the assembly?
Thanks in advance,
Just did my first laminations a few months ago. They didn't spring at
all once they were glued up.
Bertie
Old January 24th 08, 05:33 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_2_]
Just curious, to see how your experience stacks up with laminations I have
done.
What was the minimum radius for your laminations, approximately?
Jim in NC
Flying on the Cheap - Wood [email protected] Home Built 66 August 18th 06 06:33 AM
wood species question Stewart Glenn Home Built 78 August 11th 05 07:42 AM
Installing a wood prop... SteveR Home Built 19 July 24th 05 07:42 AM
Wood glider plans? Scott Soaring 4 January 18th 04 06:04 PM
Using Balsa wood Lou Parker Home Built 10 December 8th 03 06:08 PM
