"Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete |
"Bob Martin" wrote in message ... So a AIM-9 when mounted on the fuselage willl be ejector launched or are they limited by design? All AIM-9's are rail launched. Fuselage mounting of one would require a short pylon and a rail attached to it. A-7 http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete |
"Pete" wrote in message ... "Bob Martin" wrote in message ... So a AIM-9 when mounted on the fuselage willl be ejector launched or are they limited by design? All AIM-9's are rail launched. Fuselage mounting of one would require a short pylon and a rail attached to it. A-7 http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Looks like it fits the discription well, doesn't it. |
On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote:
"Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard |
On Wed, 12 Nov 2003 11:11:56 -0600, Alan Minyard
wrote: On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote: "Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard Certainly the F-8 mounted AIM-9s on fuselage pylons, but don't think you'll find any Zippers with such. Strictly wing-tip mounts as I recall. I don't think there's a "general rule" for rail vs ejector. Certainly free-fall weapons are ejector released, predominantly to insure clear and immediate separation from the airframe. Missiles, it seems, depend upon the size. Smaller missiles tend toward rail mount since they obtain an initial stabilized vector from their launch run. Larger missiles, with a larger impulse motor, seem to lean toward ejector release with an umbilical that allows for motor fire once clear of the airframe. Examples would be the large AGM-12C Bullpup (ejector) compared to the AGM-12B (rail). Or, the AGM-45 Shrike (rail) compared to the AGM-78 Standard (ejector). |
Vygg wrote in message ...
peter wezeman wrote: AL wrote in message ... Hi, Here is a newbie question. What are the merits and the pitfalls of rail vs ejector launchers for guided missiles? I suppose bombs have to be ejector launched and rockets rail. Whenever I visit an airshow, I ended up scratching my head. Ejectors are used to place a missile or bomb far enough away from the aircraft so that they are in relatively undisturbed airflow. This has been required on every fighter that carries missiles in an internal weapons bay, such as the F-102, F-106, YF-12, and the new FA-22. Ejectors are also often useful for external stores to get the weapon clear of the complex flow field near the aircraft. Extensive tests are carried out for any new aircraft or new store to determine the separation behavior and what type of ejector is required for it. I have a vague memory that the F-14 required especially powerful ejectors to ensure clean separation of bombs carried under the fuselage, as the fuselage of that aircraft is a lifting body and stores are subjected to aerodynamic forces that tend to push them up against the aircraft. I think it was also an F-14 that shot itself down when the ejector for a Sparrow missile failed and the missile lit off while still held in its recess. Hope this helps, Peter Wezeman anti-social Darwinist The F-106 and F-102 used rails, not ejectors for the AIM-4. Only the AIR-2A was "ejected" from the bay. Vygg In the pictures I have seen, the Falcon missiles on the F-102 and F-106 were held on parallelogram linkage devices that swung them down out of the weapons bay. I had thought that this was a type of ejector, but is it actually considered to be a retractable rail mount? Did it release the missile with a downward component of velocity, or did the missile fly itself forward off the rail? Did the missile guidance system have to establish lock on the target before it was launched? thank you Peter Wezeman anti-social Darwinist |
peter wezeman wrote: Vygg wrote in message ... peter wezeman wrote: AL wrote in message ... Hi, Here is a newbie question. What are the merits and the pitfalls of rail vs ejector launchers for guided missiles? I suppose bombs have to be ejector launched and rockets rail. Whenever I visit an airshow, I ended up scratching my head. Ejectors are used to place a missile or bomb far enough away from the aircraft so that they are in relatively undisturbed airflow. This has been required on every fighter that carries missiles in an internal weapons bay, such as the F-102, F-106, YF-12, and the new FA-22. Ejectors are also often useful for external stores to get the weapon clear of the complex flow field near the aircraft. Extensive tests are carried out for any new aircraft or new store to determine the separation behavior and what type of ejector is required for it. I have a vague memory that the F-14 required especially powerful ejectors to ensure clean separation of bombs carried under the fuselage, as the fuselage of that aircraft is a lifting body and stores are subjected to aerodynamic forces that tend to push them up against the aircraft. I think it was also an F-14 that shot itself down when the ejector for a Sparrow missile failed and the missile lit off while still held in its recess. Hope this helps, Peter Wezeman anti-social Darwinist The F-106 and F-102 used rails, not ejectors for the AIM-4. Only the AIR-2A was "ejected" from the bay. Vygg In the pictures I have seen, the Falcon missiles on the F-102 and F-106 were held on parallelogram linkage devices that swung them down out of the weapons bay. I had thought that this was a type of ejector, but is it actually considered to be a retractable rail mount? Did it release the missile with a downward component of velocity, or did the missile fly itself forward off the rail? Did the missile guidance system have to establish lock on the target before it was launched? thank you Peter Wezeman anti-social Darwinist On the F-106, rails 1 & 2 (forward) were connected by a web (actually a large metal plate rather than a spiderweb contraption), and rails 3 & 4 (aft) separately bracketed the ejector rack for the AIR-2A. The forward rails came down together (obviously, since they were connected) and the aft rails lowered simultaneously after 1 & 2 were retracted and clear. The Falcons were fired in pairs after the aircraft locked onto the target (MA-1A Radar for the AIM-4F, IR sensor on the upper part of the nose forward of the windscreen for the AIM-4G). The missiles came forward off of the rails. No ejector cartridges were loaded (or necessary) for the Falcons. The AIR-2A was kicked down out of the bay by a pair of ejectors and a lanyard pulled a pin in the rocket motor to fire it once the weapon cleared the aircraft. No actual "lock-on" was necessary for the Genie as it was ballistic. The AWCIS did, however, compute a flight path and time-to-go for detonation, as well as an egress sequence for the aircraft to escape the blast. That path was flown automatically if the pilot was in Auto AFCS and had SAGE Datalink in control. Can't speak for the Dagger as the only ones that I ever were around were all QFs. The drones didn't use the weapons bay, AFAIK. Vygg |
you'll find any Zippers with such. Strictly wing-tip mounts as I recall. The Zipper can carry them on the wing-tips, as you stated, but also on a double belly pylon, just in front of the main gear doors. _____________ José Herculano |
The F104G had a double rail pylon (2xAIM9s) that could be mounted on
the center fuselage station. I don't know if the C had the same capability. FWIW USAF experimented with a 104A carrying a Genie (MB1) nuke rocket on an extendable rail hung on a center fuselage station. I think the problem was lack of precise ranging information for an accurate launch. (Glad they didn't do it - nukes were always a PITA.) Walt BJ |
On Wed, 12 Nov 2003 17:47:36 GMT, Ed Rasimus wrote:
On Wed, 12 Nov 2003 11:11:56 -0600, Alan Minyard wrote: On Wed, 12 Nov 2003 04:00:33 GMT, "Pete" wrote: "Pete" wrote A general rule for missiles might be: Ejector racks next/on the fuselage Rails away from the fuselage. underwing and wingtip. And of course, to any "general rule", there is an exception. A-7 Little pylons w/ rails, mounted to the fuselage. http://www.fas.org/man/dod-101/sys/ac/a-7-dvic154.jpg Pete As with the F-8 and F-104 Al Minyard Certainly the F-8 mounted AIM-9s on fuselage pylons, but don't think you'll find any Zippers with such. Strictly wing-tip mounts as I recall. I don't think there's a "general rule" for rail vs ejector. Certainly free-fall weapons are ejector released, predominantly to insure clear and immediate separation from the airframe. Missiles, it seems, depend upon the size. Smaller missiles tend toward rail mount since they obtain an initial stabilized vector from their launch run. Larger missiles, with a larger impulse motor, seem to lean toward ejector release with an umbilical that allows for motor fire once clear of the airframe. Examples would be the large AGM-12C Bullpup (ejector) compared to the AGM-12B (rail). Or, the AGM-45 Shrike (rail) compared to the AGM-78 Standard (ejector). There was a seldom used set of rails that mounted on the C/L just aft or the front gear door. I don't think they were used operationally, but they did exist. Al Minyard |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 08:00 AM |
| Questions from a newbie. | Andrew Tubbiolo | Home Built | 9 | September 14th 04 02:40 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 06:23 PM |
