Pumping fuel backwards through an electric fuel pump
Old October 5th 03, 07:32 PM
sleepy6
Check the cutaway picture and info at
http://www.ppavionics.com/FacSolidState.htm
Notice that there is only one model that has a positive shutoff and a
built in check valve to prevent backflow. The others depend on the
valve built into the inlet. Ordinarily I would say that the inlet
valve would prevent backflow but I have seen two cases where it did
not. One resulted in a fuel starvation crash. Apparently the inlet
valve can hang open too easily to bet your life on it. I recommend
that a seperate check valve be used for safety on the models that do
not have one built in.
I also would not consider an application that depends on reverse flow
through the pump.
Bob
says...
Are you really sure fuel will flow backwards through the Facet pump? I
may be wrong as it has been a long time since I worked with one of the
se
pumps, but I remember that the design did not allow flow in the opposi
te
direction. I have seen a number of fuel setups that used two pumps in
parallel. With one pump "on" the other pump, the pump that was not
energized, did not allow any back flow. There was no need for a check
valve in the system as the pump acted as its own.
Greg Reid wrote:
I understand that the simple Facet pumps have no check-valve so this
should be possible. But is it harmful to such pumps?
Greg
Old October 5th 03, 11:58 PM
Bruce A. Frank
I have two of the 40108 pumps listed at that web site. I just hooked
them up opposed to each other. Neither could force gasoline backwards
through the other. They may not be leak free when exposed to reverse
pressure...the design may not be a full check valve design, but they
certainly do not flow backwards enough to allow filling a tank.
through the pump.
Bob
says...
se
te
Greg
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
\(-o-)/ AIRCRAFT PROJECTS CO.
\___/ Manufacturing parts & pieces
/ \ for homebuilt aircraft,
0 0 TIG welding
While trying to find the time to finish mine.
Old October 6th 03, 03:57 AM
Bill Daniels
How about a reversible positive displacement pump that won't allow fuel to
seep past it while stopped? A gear pump will do that if closely fitted.
That way you could pump fuel in either direction until you were trimmed and
just shut it off.
Bill Daniels
"Greg Reid" wrote in message
om...
I've installed a 12-gallon fuel cell aux tank in the tailcone of my
4-place conventional low-wing plane -- intended for go-fast trimming
when flying solo more than for its extra fuel capacity. As you know,
a typical 4-place is terribly nose-heavy with only front-seat
passengers and no baggage. The tank would be emptied if flying with a
full load of passengers and baggage.
Now I'm considering how to plumb it. My engine is gasoline, not
fuel-injected.
The simplest approach would be to vent the tank it to the outside, and
run a single 3/8 hard tube between my left main and the aux tank. The
aux tank is positioned towards the ceiling of the turtledeck so
there's a fair amount of gravity-feed available for it in normal
flying attitude to drain back into that same tank. I'd have a single
electric pump to pump from the main uphill to the aux tank, with a
shut-off valve in the line to keep it there. Opening the valve would
let it gravity-feed back into the main tank ... slowly. That is, if
it's OK to allow it to gravity feed "backwards" through the fuel pump.
(I need to consider the possibility of the main tank gravity-feeding
back into the aux tank in a prolonged steep climb. I'll need to
remember to shut off the valve whenever a fuel transfer isn't wanted.)
I'm wondering about installing a second electric pump in series at the
aux tank end, pointing back towards the main tank, to considerably
speed up the draining. Only one pump would be run at a time of course
-- either to fill or to drain the aux tank. But when either pump was
on, it would be pumping fuel "backwards" through the other one. I
I've got a more elegant approach (a little complicated to draw here)
that would use a single pump and a double-stacked selector valve as
used on a fuel-injected engine. The selector valve makes it so that
in the "fill" position, the pump would pump fuel from the main to the
aux, and in the "drain" position, that same pump would pump fuel from
the aux to the main. This is the slick set-up, but is considerably
more complex/expensive/heavy to implement.
The fourth approach would use separate fill and return lines, with
separate pumps, check valves, and shut-off valves. This would avoid
venting overboard. But it's even more complex, and I hope to not have
to go there.
Surely others have solved this simple plumbing challenge before me. I
welcome your ideas. :-)
Greg
Old October 6th 03, 02:27 PM
Scott Correa
om...
Greg,
Thats a bunch of weight and complexity to add for trim fiddling. I can
see the benefits but think that a fixed/removable ballast bar bolted to
somewhere
around the rudder post weighs less, is less complex, gets you 90% of what
you are looking
to achieve and has no failure modes that would be critical to flight. Make
a bar for solo,
one for 2 up. Some certificated gliders and helicopters do it this way.
But I'm afraid it
might be too simple..........
Scott
Old October 6th 03, 10:31 PM
Greg Reid
Hey guys, thanks for all of the commentary/concern ... and sorry I've
been remiss in responding until now.
Thanks in particular to Bruce for going the extra mile and a half in
actually hooking up and testing to see if you can pump backwards thru
a typical Facet pump (nope).
A simple "gear motor" mentioned elsewhere is what I need, I suppose,
so that the single pump could pump both ways (with polarity reversed).
I could add an on/off valve (manual or electric solenoid) to complete
the single-pump-and-single-tube hookup. Such gear motors are
typically found in cheap hardware-store siphoning pumps that let you
drain or fill your auto crankcase via the dipstick tube (turned by an
electric hand drill). I wonder if I can find one of aircraft quality
somewhere.
I did find the ppavionics site mentioned. That's the link I mentioned
having found (and then temporarily misplaced) earlier. They've got a
Facet pump model that contains internal valving to prevent flow in
either direction when off. So they could be used for a two-line and
two-pump setup for "fill" and "drain". I found some other stuff on
their site that seems "interesting", and wrote them (no response as
yet). (And no, I have no financial or other interest.)
I just want to assure you all that even when the aux tank is full,
I'll still be within rear CG limits ... barely. I wouldn't really
CHOOSE to take-off or land (or do intentional stalls) at that rear
limit, but it WILL be possible to do so safely.
I'm currently leaning towards the obvious two-line and two-pump
arrangement, but am still on the lookout for a lighter/simpler
alternative using a single line and single pump.
As I mentioned earlier, it's easily possible to use a single line and
a single pump to fill and drain (with the pump always running in its
normal mode) by using a stacked selector valve as used with a
fuel-injected engine, and a bit of fancy cross-plumbing of the valve
ports. This is basically trading the expensive selector valve for the
second pump and line. It might be a little lighter and somewhat less
complicated.
Someone else suggested much earlier using a single pump to fill and a
"bypass valve" to drain by gravity. That's an excellent and simple
solution -- if I could trust that gravity alone will drain the tank
within a reasonable length of time. I need to do a simple experiment
to find out.
Thanks again for all the comments,
Greg
Old October 7th 03, 07:09 PM
Big John
Greg
Have you thought about using ram air to empty the tank?
In the P-51, I've seen a 'L' shaped piece of tubing mounted in a
rubber fitting on the top front of the drop tanks, facing forward. The
ram air put pressure in the tanks and caused flow. System had a single
valve that you opened to let fuel transfer to engine.
The 'ram air' tubing was about 7/8 to 1 inch in diameter and cruise
speed was 220-250 mph depending on mission. One mission I remember we
were cruising at 180 mph escorting bombers on a very long range
mission (and drop tanks fed ok). We didn't like to fly that slow
escorting but using a higher airspeed and weaving used more fuel and
we could not escort full range of mission.The fuel transfer was rapid
enough to run the Merlin.
The exhaust of the vacuum pump was also used to pressurize the drop
tanks at times. More complicated to set up than ram air system.
Flew missions at 20K using the ram air pressure to feed the drop
tanks. Understood at higher altitude, with the lower IAS, they might
not always feed ok (or feed very slow)?
This is just an out of the box bit of data that you might use to make
a simple (reliable) feed system.
Big John
On 6 Oct 2003 14:31:30 -0700,
somewhere.
complicated.
to find out.
Greg
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
