sisu1a wrote:
If structure does not change the aerodynamics of a wing, then why are modern hot ships still made of wood, or metal? When the shift from wood and metal to fiberglass occurred, a huge factor was cost: it was much cheaper to build a glider to the tolerances required in molded fiberglass than the other materials, and it retained the shape better. At that time, you could build a lighter aluminum glider of the same performance, but it was a constant effort to keep the airfoil correct. I don't know if this is still true for carbon fiber versus aluminum; regardless, I think the cost would still favor the molded construction. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Paul -
I don't argue that there isn't room for improvement and that the newer materials have benefits. But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. With all due respect (I'm not trying to be antagonistic), please read Fred Thomas' "Fundamentals of Sailplane Design" book or go study aerodynamics before trying to lecture about the subject. --Noel |
was cost: it was much cheaper to build a glider to the tolerances required in molded fiberglass than the other materials, and it retained the shape better. At that time, you could build a lighter aluminum glider of the same performance, but it was a constant effort to keep the airfoil correct. I don't know if this is still true for carbon fiber versus aluminum; regardless, I think the cost would still favor the molded construction. No arguments here! Still a case for material advances improving sailplanes (by making laminar capable wings affordable and maintainable), but still a poor point for me to have tried to use to advance my hypothisis for current improvements...you got me. But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. I don't think I quantified the amount, just stated that many have said "it wont get better than X amount" and have been proven wrong as aerodynamics AND materials improve. And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. Now we really part ways. I was only citing that even currently available materials offer more room for improvement, but I'm certainly not limiting my thoughts on this to prepreg carbon. Do you not think that once OTHER materials are advanced enough to have a super-smooth uber-laminar wing that can change in airfoil/incidence/planform/etc while in flight (like a bird's wing. but much slicker) will not yield significant performance improvements? We do not yet have the materials to construct such a thing, but when (if?) the "Unobtanium" to construct such a wing comes about I think there will be a major leap in performance capabilities, but perhaps you do not see it this way. With all due respect (I'm not trying to be antagonistic), please read Fred Thomas' "Fundamentals of Sailplane Design" book or go study aerodynamics before trying to lecture about the subject. Lecturing? Hardly. (not feeling antagonized ; ) I simply felt the need to counterpoint some things from my post you clearly misinterpreted (equating strength/weight ratio of construction with wing loading for example). I appreciate your endorsement of Fred Thomas' book, and I will continue to read my copy. I do not profess to be an aerodynamicist and my opinions are mostly based on intuition, which leaves much room for learning I am open to. My original point was actually that the "this is all we have to look forward to" type statement are words that thankfully have been eaten many times over, and I think (hope?) they will have to be eaten again (also pointing out that they can 'possibly' eaten sooner than thought using current materials, but not that it would be practical to do...). Is this discussion group not for the exchange of ideas and a place to learn? I have no problem being wrong, as I all too often am. I however do not discourage anyone from posting about things they are truly interested in, whether they have a degree in that subject or not. Counter to that school of thought and historically speaking, many very important discoveries were made by people that luckily were ignorant to the "facts" that something was impossible so they dared to leap. Paul Hanson |
But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. Nasa doesn't seem to agree with you either: http://www.gizmag.com/go/2242/picture/3073/ (there are links to the rest Aero Elastic Wing article along with more pics) Perhaps they should read Fred Thomas' book and get over themselves! ; ) In Jest, Paul |
On May 5, 3:28*pm, sisu1a wrote:
But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. *And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. Nasa doesn't seem to agree with you either:http://www.gizmag.com/go/2242/picture/3073/ (there are links to the rest Aero Elastic Wing article along with more pics) Perhaps they should read Fred Thomas' book and get over themselves! *; ) In Jest, Paul Just for the 'what if' pile..... What if a new material becomes available that would allow a true variable airfoil / camber wing to be built. (like the Aero Elastic Wing on steroids) Not just the last 10% or so of the chord, but truly changing the airfoil in flight to whatever is best suited to the immediate circumstances? Yes, this is JUST a fantasy, but so was aviation in general 105 years ago. |
On May 5, 5:04 pm, wrote:
On May 5, 3:28 pm, sisu1a wrote: But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. Nasa doesn't seem to agree with you either:http://www.gizmag.com/go/2242/picture/3073/ (there are links to the rest Aero Elastic Wing article along with more pics) Perhaps they should read Fred Thomas' book and get over themselves! ; ) In Jest, Paul Just for the 'what if' pile..... What if a new material becomes available that would allow a true variable airfoil / camber wing to be built. (like the Aero Elastic Wing on steroids) Not just the last 10% or so of the chord, but truly changing the airfoil in flight to whatever is best suited to the immediate circumstances? Yes, this is JUST a fantasy, but so was aviation in general 105 years ago. How about a passive nano-unobtanium surface that smoothed and roughened at different speeds/loadings to prevent flow separation, along with the airfoil elasticity? Frank W |
On May 5, 4:09*pm, Frank Whiteley wrote:
On May 5, 5:04 pm, wrote: On May 5, 3:28 pm, sisu1a wrote: But the bottom line is that the increases in L/D and *aerodynamic performance* aren't likely to change by large amonths. *And the new materials have little or no effect on the aerodynamic performance or the shape of the wings. Nasa doesn't seem to agree with you either:http://www.gizmag.com/go/2242/picture/3073/ (there are links to the rest Aero Elastic Wing article along with more pics) Perhaps they should read Fred Thomas' book and get over themselves! *; ) In Jest, Paul Just for the 'what if' pile..... * What if a new material becomes available that would allow a true variable airfoil / camber wing to be built. (like the Aero Elastic Wing on steroids) Not just the last 10% or so of the chord, but truly changing the airfoil in flight to whatever is best suited to the immediate circumstances? *Yes, this is JUST a fantasy, but so was aviation in general 105 years ago. How about a passive nano-unobtanium surface that smoothed and roughened at different speeds/loadings to prevent flow separation, along with the airfoil elasticity? Frank W- Hide quoted text - - Show quoted text - YES! I'll buy one as soon as I'm not the weak link in my Speed Astir's performance! Oh... never mind. |
roughened at different speeds/loadings to prevent flow separation, along with the airfoil elasticity? Hey hey, I *did* say "passive boundary layer control"!! ;-) Lemme try to be clearer, and not as abrasive as perhaps I came across earlier: Aerodynamicists have gotten really good at figuring out optimum static shapes of airfoils and 3d wings for a desired "mission" or set of aerodynamic circumstances. Airfoil effectivness and pressure distributions are affected by the precision and smoothness of the external shape - and newer materials don't bring anything to the table that fiberglass doesn't already provide. Weight, in and of itself, doesn't play a part in the actual efficiency of a wing to extract energy / lift from the stream of air flowing around it; and weight savings are what things like pre-preg are generally good for right now (you might say "stiffness" - but you can usually get an equally stiff part with a much heavier layup of traditional fiberglass with a good core material; so in the end it goes back to being a weight issue). Elastic / flexible materials have already made an appearance before, at least as coverings over hinges to improve airflow (Speed Astir flaps, anyone?)... But to get a marked increase in glide efficiency over an entire flight, things like this are going to have to be able to react and adapt quite quickly to a wide variety of aerodynamic situations. Look at the Sinha "De-Turbulator" tape: At very specific speeds with very specific airflows it is able to momentarily provide a large boost to the glide ratio/efficiency of a wing. But it doesn't (yet) appear to be capable of adapting to different airflows and different flight regimes - so in the end if may not provide a huge performance boost to an overall flight. Additionally, it has not been proven that the boosted performance is a sustainable / stable flight condition - it might just be a momentary / transitionary gain that cannot be maintained for long enough to make a meaningful difference during a flight. When it comes to physics, we have pretty much mathematically solved the equations to provide the most efficient wing shape for any single flight condition. We can minimize drag or maximize lift or pick a middle-point that best matches our desires at that precise moment. An adaptable wing doesn't help in a static situation (i.e. constant airspeed, constant angle of attack, no-wind, calm-air, straight-line best-glide. That's theoretically what we mean when we talk about "Best L/D"). You can only get as good as you can get with the optimal wing-shape for that one situation. Furthermore, there's no getting around the fact that an actual aircraft flight is a chaotic and ever-changing blend of different conditions. For an aircraft to fly well overall, it needs to be a compromise that can work reasonably under all of the disparate conditions. And with current technology and materials (no matter how exotic), there's no way to make a wing that can dynamically optimize its shape in-flight and in reaction to all of the various conditions. I look forward to the day when such technology exists; but I might well be dead by that point (and I'm only 30 right now - but even as an optimistic technology professional I just don't see it being a near- term possibility). Take care, --Noel |
noel.wade wrote:
snip Furthermore, there's no getting around the fact that an actual aircraft flight is a chaotic and ever-changing blend of different conditions. For an aircraft to fly well overall, it needs to be a compromise that can work reasonably under all of the disparate conditions. And with current technology and materials (no matter how exotic), there's no way to make a wing that can dynamically optimize its shape in-flight and in reaction to all of the various conditions. I look forward to the day when such technology exists; but I might well be dead by that point (and I'm only 30 right now - but even as an optimistic technology professional I just don't see it being a near- term possibility). Take care, Makes me think of adaptive optics used to correct for atmospheric turbulence degrading the image generated by large telescopes. The medium the telescope is adapting to is the same, so I imagine the time scale is similar to what an adaptive surface of a sailplane would need. Could be kinda heavy equipping the wing with all those actuators though. :-o Shawn |
Maybe the time scale doesn't have to be *that* fast. Simply scale up "eagle cam"'s aerial
virtuosity http://animal.discovery.com/converge...29.15073148073 to NASA's http://www.nasa.gov/centers/dryden/n...-061-DFRC.html It would be interesting to hear if this idea went any further. And fun to imagine it's use in soaring. --Sarah Shawn wrote: snip Makes me think of adaptive optics used to correct for atmospheric turbulence degrading the image generated by large telescopes. The medium the telescope is adapting to is the same, so I imagine the time scale is similar to what an adaptive surface of a sailplane would need. Could be kinda heavy equipping the wing with all those actuators though. :-o Shawn |
| Thin Airfoil and Climb Performance | Brad[_2_] | Soaring | 16 | April 3rd 08 06:50 AM |
| climb performance Jet vs Prop | xerj | Piloting | 11 | July 7th 06 07:31 AM |
| Duo Turbo Climb / Altitude performance | Gary Emerson | Soaring | 16 | November 28th 05 09:19 AM |
| relative climb performance | Soaring | 8 | September 17th 05 08:21 PM | |
| 172 N Climb Performance | Roger Long | Piloting | 6 | September 11th 03 12:18 AM |
