#31
"Dudley Henriques" wrote:
The above is absolutely correct......... BUT.........Please do a google search for (p51 engine seizure "dudley henriques") and read the thread carefully, especially from the point where Gordo enters it under me. I believe it will be instantly apparent that the reason for this misunderstanding is obvious, and it's probably my fault. I was reacting to someone I don't particularly like and I was mincing words. If you read the thread carefully, you will see that what I was discussing with him about power and rpm was missing a main ingredient; that being what I was assuming he knew, when in actuality, I had completely omitted it from anything I was saying to him. That ingredient is the high rpm prop limiter on the governor of the 24D50 Ham Standard used on the Mustang. If you read what I was writing carefully, I believe you will realize that I was assuming both of were aware of the limiter function in relation to what we were discussing. I was wrong in assuming this. The facts are quite simple. Both Gordo and I know it. The only problem seems to be that he thinks it was he who "taught" me this, and that's pure fiction I can assure you. But the fault remains with me I think. I should have made it perfectly clear to him from the beginning about the prop governor, as I was considering it's function in every post I made to him, but I never actually mentioned it. In summation, it's 101 that rpm and not power is directly related to rotational mass/velocity/inertia with a constant speed prop....UNLESS as I was trying to say, the power is back past the high rpm limit stop as it very well is at idle power on the Mustang. This assumes normal aerodynamic loads on the prop as well. With this in play, it becomes totally correct to say that the rotational forces in play at 15 inches on this airplane are less then they would be at 61 inches, or anywhere else for that matter within the 42 degree pitch limits where a power change or a change in aerodynamic load would cause a pitch change to maintain a constant set RPM on this specific prop. I'm very sorry if what I said was misleading to Gordo. I should have discussed the prop governor with him from the onset. The plain truth is that I was just too ****ed off at him and just plain missed it. Such is Usenet!! :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt What a classic expert at obfuscation you are Henriques...It's actually funny. You're so good that I suspect that you've convinced yourself that you're right here...sad indeed. You're also a classic windbag, in a class by yourself, which I'm sure few on here would deny. --Gord. "Bull ****! This is a constant speed prop. RPM is a set value. The RPM can be set at 3000 and the manifold pressure can be anywhere between 15 inches and 61 inches, and it's the manifold pressure combined with the set RPM that will determine the power.....NOT the RPM!!! Are you trying to tell me that the rotational (energy) of a propeller is the same at 15 inches as it is at 61?". -D Henriques |
#32
"Gord Beaman" wrote in message ... "Dudley Henriques" wrote: The above is absolutely correct......... BUT.........Please do a google search for (p51 engine seizure "dudley henriques") and read the thread carefully, especially from the point where Gordo enters it under me. I believe it will be instantly apparent that the reason for this misunderstanding is obvious, and it's probably my fault. I was reacting to someone I don't particularly like and I was mincing words. If you read the thread carefully, you will see that what I was discussing with him about power and rpm was missing a main ingredient; that being what I was assuming he knew, when in actuality, I had completely omitted it from anything I was saying to him. That ingredient is the high rpm prop limiter on the governor of the 24D50 Ham Standard used on the Mustang. If you read what I was writing carefully, I believe you will realize that I was assuming both of were aware of the limiter function in relation to what we were discussing. I was wrong in assuming this. The facts are quite simple. Both Gordo and I know it. The only problem seems to be that he thinks it was he who "taught" me this, and that's pure fiction I can assure you. But the fault remains with me I think. I should have made it perfectly clear to him from the beginning about the prop governor, as I was considering it's function in every post I made to him, but I never actually mentioned it. In summation, it's 101 that rpm and not power is directly related to rotational mass/velocity/inertia with a constant speed prop....UNLESS as I was trying to say, the power is back past the high rpm limit stop as it very well is at idle power on the Mustang. This assumes normal aerodynamic loads on the prop as well. With this in play, it becomes totally correct to say that the rotational forces in play at 15 inches on this airplane are less then they would be at 61 inches, or anywhere else for that matter within the 42 degree pitch limits where a power change or a change in aerodynamic load would cause a pitch change to maintain a constant set RPM on this specific prop. I'm very sorry if what I said was misleading to Gordo. I should have discussed the prop governor with him from the onset. The plain truth is that I was just too ****ed off at him and just plain missed it. Such is Usenet!! :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt What a classic expert at obfuscation you are Henriques...It's actually funny. You're so good that I suspect that you've convinced yourself that you're right here...sad indeed. ..........well, actually no I'm not convinced I was right , as I so obviously said in the post above. In fact, I'm of the opinion that it was me who caused most of this misunderstanding. Is there something about that you don't understand? You're also a classic windbag, in a class by yourself, which I'm sure few on here would deny. Well, so far at least Gordo, you're a long list of ONE anyway!! I sincerely hope that in the six years I've been posting here I haven't affected others as I seem to have affected you. We'll just have to let others speak for themselves I guess. Who knows, you might just be right.......then again.......I hope not anyway :-) I know you don't believe this Gordo ole' boy, but it genuinely grieves me the way things have turned out between you and me. If you actually knew me as well as you think you know me, you'd know what a total pussycat I really am, and how totally wrong your misconception of me not dealing with mistakes is in reality. (I'm assuming of course that you simply have a misconception and that what's going on isn't deliberate ) The truth is that I've lived through an entire career in aviation dealing with mistakes; (mine and others) studying them as they relate to flight safety. I've made many mistakes in my life Gordo, and I'm still here because I faced them head on, recognized them and corrected them, not by avoiding them as you suggest. I've even tried in vain in this post to relate that the fault for this misunderstanding might have been mine, but it seems that's not in your agenda is it? :-) I keep showing your posts about me to my wife. She says the same thing......it's just sad....and so unnecessary.....and a waste. All the best to you regardless, Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
#33
"Dudley Henriques" wrote in message hlink.net... "Gord Beaman" wrote in message ... You're also a classic windbag, in a class by yourself, which I'm sure few on here would deny. God Gordo, I'm sorry. MY MISTAKE!!!!! :-) I just realized I missed Tarver for your list. That's two. I'll let the implication of this just pass without amplification if you don't mind. :-) All the best, DH |
#34
Ken Duffey wrote in message ...
As for the C-47 - I think the SAAF still operates them ?? Dunno about SAAF, but Paraguay's Air Force still operates the C-47. Cheers, Vicente |
#35
"Bjørnar Bolsøy" wrote: The B2/PR9 Canberra? (FF 1949, entered service 1951, still in service?) P/F-51 Mustang. 1943-84. Last used as frontline equipment by Dominican Republic AF until 1984. Posted via www.My-Newsgroups.com - web to news gateway for usenet access! |
#36
"Matt Wiser" wrote in message news:3fca1555$1@bg2.... "Bjørnar Bolsøy" wrote: The B2/PR9 Canberra? (FF 1949, entered service 1951, still in service?) P/F-51 Mustang. 1943-84. Last used as frontline equipment by Dominican Republic AF until 1984. The last B-52H was delivered in October 1962...care to venture another guess? Tex |
#37
P/F-51 Mustang. 1943-84. Last used as frontline equipment by Dominican Republic AF until 1984. Super Cub. Even if you regard it as distinct from the J-3, the PA-18 went into service with the USAF in 1950. The Israeli defense forces sold off their last dozen PA-18s last year, for a service life of 52 years even if no other military is presently using it. Isn't it amazing? In WWI, fighter aircraft went through four distinct generations. Now we have planes lasting a half-century. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#38
How about the old C-47 ? It seems it was designed in the 30's and is still
flying in some parts of the world. |
#39
"Gord Beaman" wrote in message ... Ed, I suspect that Ken is referring to the Confederate Air Force vice Canadian Armed Forces. Yes? Commemorative Air Force |
#40
"Steven P. McNicoll" wrote:
"Gord Beaman" wrote in message .. . Ed, I suspect that Ken is referring to the Confederate Air Force vice Canadian Armed Forces. Yes? Commemorative Air Force Of course, I had forgotten about the change there...thanks. -- -Gord. |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
