TruTrak ADI current draw
Old May 28th 08, 06:25 AM posted to rec.aviation.soaring
Hellman
Default TruTrak ADI current draw
Several times on this newsgroup people have asked about the power
consumption of TruTrak's electronic artificial horizon (ADI), but
until now I haven't seen a definitive answer. (Apologies if I missed
it. I did do a search on the newsgroup before posting this.) I emailed
TruTrak and got the following answer:
The current draw of the ADI is around 180 milliamps. It is nearly the same for both sizes.
Please let me know if you have any further questions. Thanks!
(I had asked if there was any difference between the 2-1/4" and the
3-1/8" models.) Not bad!
Martin
WT
Old May 28th 08, 08:50 AM posted to rec.aviation.soaring
Darryl Ramm
Martin
WT
My more serious concern with the ADI is how exactly the unit performs
in a glider - especially given it is *not* a normal artificial
horizon. It displays what TruTrack calls "vertical velocity enhanced
pitch". So what happens to the pitch indication when you encounter
significant change in vertical speed say in wave or even in a thermal.
Anybody have any actual experience using one of these? The pitch
indication behavior? How does the unit handle continuous high turn
rate thermalling?
Darryl
Old May 28th 08, 03:52 PM posted to rec.aviation.soaring
JJ Sinclair
I have been flying with the TruTrack for a year now and find it just
what I want. I use it when getting close to shear lines marked by Q's
that don't have a firm base and step-up 1000 feet from one side to the
other, like we get all the time here in the Mendacino Mountains. It is
instant-on and it can be turned on while in a bank...............comes
right up to show your correct bank angle. It looks like a gyro, but
shows no pitch information. I have had it on for 30 minutes and it
always showed the correct attitude. Plenty good enough to execute a
180 in order to get out of an unexpected IFR situation, just maintain
your cruise speed which will keep the pitch under control and crank it
around using the TruTrack....................Please no hate-mail about
the FAR's, I use it just in case I'm fiddling with the computer one
day and suddenly find everything has turned gray!
JJ
rate thermalling?
Darryl
Old May 28th 08, 04:18 PM posted to rec.aviation.soaring
Darryl Ramm
JJ
rate thermalling?
Darryl
JJ
Just to be clear. TruTrak (I keep forgetting to forget the c) is the
company, they make multiple products. You are talking about a TruTrak
Pictorial Turn and Bank, which I also have in my glider and I am also
impressed with. Marty is talking about the TruTrak ADI - an artificial
horizon. It is the pitch information in the artificial horizon that I
am mostly questioning. It would be great if it works as well as their
pictorial turn and bank, but they've not answered questions about this
when I tried before and so far I've not heard of anybody who has
really shaken one of these out in a sailplane.
Darryl
Old May 28th 08, 07:31 PM posted to rec.aviation.soaring
bumper
Concurring with Darryl, it should also be noted that the TruTrak pictorial
turn and bank (roll info only), is usually ordered set at a 1" minute
standard turn rate for glider use (we turn a lot and steeply). For power
plane use, and the default setting, it's typically set at a 2-minute turn
rate as this is the standard rate turn for instrument flying.
So, is the ADI version (with pitch), also available in the 1-minute turn
rate for gliders?
I'm also using and am happy with the roll only TruTrak.
bumper
"Darryl Ramm" wrote in message
JJ
rate thermalling?
Darryl
JJ
Darryl
Old May 28th 08, 11:52 PM posted to rec.aviation.soaring
Darryl Ramm
rate for gliders?
bumper
JJ
rate thermalling?
Darryl
JJ
Darryl
Bumper
If it is an artificial horizon/ADI it should show bank angle not turn
rate. Their documentation says bank angle.
Darryl
Old May 29th 08, 06:02 AM posted to rec.aviation.soaring
rate for gliders?
bumper
JJ
*My more serious concern with the ADI is how exactly the unit performs
rate thermalling?
Darryl
JJ
Darryl
Bumper
Darryl- Hide quoted text -
- Show quoted text -
We had a similar discussion a while back on the Van's Air Force forum.
Here's what the final word was directly from TruTrak: "The gyros in
the ADI are rate gyros. They sense only rate of change. When you
describe tipping the unit, you momentarily cause a rate change in the
gyro. After you leave it on its side, it no longer senses a rate of
change, therefore the display returns to level. Think about that
motion in an aircraft however, if you put the ADI on it's side, you
are obviously in a banked turn. This causes a constant azimuth and
roll rate change which would be displayed on the ADI as the angle of
bank. I hope this helps you to understand how the ADI works, please
let me know if you have any further questions. Thanks!"
Lucas Massengale
Technical Support
TruTrak Flight Systems
479-751-0250
866-878-8725
www.trutrakap.com
I have ADI on the panel of my RV-8A. Haven't flown with it yet but
have talked to many, many folks about what it can and cannot do. It is
not a true artificial horizon. But for soaring it seems like an ideal
solution for those inadvertant IFR experiences. The ADI has an option
for an internal back-up battery which is suppose to power the unit if
main power fails. The ADI uses a 2 amp fuse/breaker but the current
drain is not documented in the manuals.
Albert Thomas
"4"
Old May 29th 08, 06:37 AM posted to rec.aviation.soaring
Darryl Ramm
rate for gliders?
bumper
JJ
rate thermalling?
Darryl
JJ
Darryl
Bumper
Lucas Massengale
Technical Support
479-751-0250
866-878-8725www.trutrakap.com
Albert Thomas
"4"
"But for soaring it seems like an ideal solution for those inadvertant
IFR experiences"...is that considering what the pitch indication will
do when encountering sudden rate of change of climb/descent say inside
a CB or being blown downwind while IFR inside a lennie? My concern is
things that you can't understand how they will operate in nasty
situations where you really need them are not an "ideal solution". It
is one thing beings stressed by things not going well and being in
IFR, it would be worse to have to ignore the pitch indication on the
ADI or untangle whether you believe the ASI or TruTrak ADI. It might
be that the TruTrak ADI is usable in these situations, but I'd like to
hear it's been used/demonstrated by folks in similar situations it
will be needed in before assuming it is going to work like other
artificial horizons. Without that my preference would be for a T&B
with no pitch indication.
BTW from the description above maybe Bumper's question may be valid.
Darryl
Non-starving pilot artists draw BIG! Jim Logajan Piloting 2 March 12th 08 02:34 PM
Trutrak auto pilot davidh Home Built 2 November 21st 07 01:48 AM
King KLX 135 and TruTrak "Digitrak" autopilot... [email protected] Home Built 3 August 31st 05 06:28 AM
TruTrak Solid-State T&B Jim Hendrix Soaring 10 August 31st 04 07:46 PM
Where do you draw the line? Bruce Greeff Soaring 4 July 1st 04 08:59 PM
