"Le Chaud Lapin" wrote in message
... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Jun 9, 7:29*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
D0t C0m wrote: "Le Chaud Lapin" wrote in ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? Why not? It woul be ejucational. Cheers |
D0t C0m wrote: "Le Chaud Lapin" wrote in ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? I'll raise you one to make three additional trim systems. Any more? Cheers |
More_Flaps wrote in
: On Jun 9, 7:29*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Le Chaud Lapin" wrote in messagenews:5c4deac0-2b92 ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? I'll raise you one to make three additional trim systems. Any more? I can think of four for a total of five, depending on whether you'd consider hydraulic centering to be the same as a bungee trim system. theothersa re of course, a tab system which is th emost common light aircraft system. the trimmable stab, a'la Cub and most airliners and the vane, like some early T-carts had.. There're probably some others, but i can't think of any. Bertie |
on 6/8/2008 1:25 PM Bertie the Bunyip said the following:
Le Chaud Lapin wrote in news:2bd217b4-297e-411f- : On Jun 8, 12:21 pm, wrote: On Jun 7, 11:08 pm, Le Chaud Lapin wrote: Also, for experienced pilots that know the answer, please do not ruin it by telling everyone before any answers have been given, though if you are not certain of the answer and would like to speculate, that's fine. ![]() -Le Chaud Lapin- Guess you missed this thread: http://groups.google.ca/group/rec.av...wse_thread/thr... Did indeed. Just glad that the answer is not laid-out in first few posts. For students that are reading this, don't cheat by reading that thread! There is no point in giving your answer if you look it up first. ![]() -Le Chaud Lapin- So, what are they suposed to do, get it from reading tea leaves? Pull it out of their asses, of course, just as he does with most of his posts. |
On Jun 9, 9:06*am, Bertie the Bunyip wrote:
More_Flaps wrote : On Jun 9, 7:29*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Le Chaud Lapin" wrote in messagenews:5c4deac0-2b92 ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? I'll raise you one to make three additional trim systems. Any more? I can think of four for a total of five, depending on whether you'd consider hydraulic centering to be the same as a bungee trim system. theothersa re of course, a tab system which is th emost common light aircraft system. the trimmable stab, a'la Cub and most airliners and the vane, like some early T-carts had.. There're probably some others, but i can't think of any. I'd count that as the same -the acutuating system doesn't count, just the aerodynamic priciples. So, if you have four I'll raise you again one to make five... Any raise on five basic methods? Cheers |
More_Flaps wrote in
: On Jun 9, 9:06*am, Bertie the Bunyip wrote: More_Flaps wrote innews:64b157a9-99f5-4429-9125-d1e2 : On Jun 9, 7:29*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Le Chaud Lapin" wrote in messagenews:5c4deac0-2b92 ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? I'll raise you one to make three additional trim systems. Any more? I can think of four for a total of five, depending on whether you'd consider hydraulic centering to be the same as a bungee trim system. theothersa re of course, a tab system which is th emost common light aircraft system. the trimmable stab, a'la Cub and most airliners and the vane, like some early T-carts had.. There're probably some others, but i can't think of any. I'd count that as the same -the acutuating system doesn't count, just the aerodynamic priciples. So, if you have four I'll raise you again one to make five... Any raise on five basic methods? Yeah, they;re essentially the same. Go on. I'll call. Bertie |
Rich Ahrens wrote in
. net: on 6/8/2008 1:25 PM Bertie the Bunyip said the following: Le Chaud Lapin wrote in news:2bd217b4-297e-411f- : On Jun 8, 12:21 pm, wrote: On Jun 7, 11:08 pm, Le Chaud Lapin wrote: Also, for experienced pilots that know the answer, please do not ruin it by telling everyone before any answers have been given, though if you are not certain of the answer and would like to speculate, that's fine. ![]() -Le Chaud Lapin- Guess you missed this thread: http://groups.google.ca/group/rec.av...owse_thread/th r... Did indeed. Just glad that the answer is not laid-out in first few posts. For students that are reading this, don't cheat by reading that thread! There is no point in giving your answer if you look it up first. ![]() -Le Chaud Lapin- So, what are they suposed to do, get it from reading tea leaves? Pull it out of their asses, of course, just as he does with most of his posts. Exactly... Bertie |
On Jun 9, 9:24*am, Bertie the Bunyip wrote:
More_Flaps wrote : On Jun 9, 9:06*am, Bertie the Bunyip wrote: More_Flaps wrote innews:64b157a9-99f5-4429-9125-d1e2 : On Jun 9, 7:29*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Le Chaud Lapin" wrote in messagenews:5c4deac0-2b92 ... On Jun 8, 11:07 am, "Robert M. Gary" wrote: On Jun 7, 10:08 pm, Le Chaud Lapin wrote: What exactly happens when the trim is adjusted to point the nose upward? What type of plane is this for? I have a Mooney and also fly a 182. Both trim system are very, very different. For sake of those of us who only own MSFS, let's say a C172. Does MSFS emulate the servo tab on the elevator? What does it do when you change the trim in the air? Trying to emulate real life trim on a simulation system that uses spring centered control sticks isn't going to work like real life as you may already know. Should I post the spoiler on how a couple other mechanisims work (besides servo tabs)? I'll raise you one to make three additional trim systems. Any more? I can think of four for a total of five, depending on whether you'd consider hydraulic centering to be the same as a bungee trim system. theothersa re of course, a tab system which is th emost common light aircraft system. the trimmable stab, a'la Cub and most airliners and the vane, like some early T-carts had.. There're probably some others, but i can't think of any. I'd count that as the same -the acutuating system doesn't count, just the aerodynamic priciples. So, if you have four I'll raise you again one to make five... Any raise on five basic methods? Yeah, they;re essentially the same. Go on. I'll call. Should'nt we wait to see if there's any other raise? Cheers |
| F-100 detail | Pjmac35 | Aviation Photos | 0 | July 26th 07 11:29 AM |
| Finding "Neutral" Position on Piper Elevator/Trim Tab | [email protected] | Owning | 10 | December 7th 06 02:43 PM |
| Detail pops in too late in FS2004 | CatharticF1 | Simulators | 0 | August 27th 03 04:25 AM |
