Russian Air Force may receive fifth-generation fighter in 2013
Old July 18th 08, 01:29 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jeffrey Hamilton
Default Russian Air Force may receive fifth-generation fighter in 2013
"JG" wrote in message
On Jul 11, 12:56 pm, Jack Linthicum
ZHUKOVSKY (Moscow Region), July 7 (RIA Novosti) - Russia is expecting
a new fifth-generation fighter to enter service in 2013, the Air Force
commander said on Monday.
"We will begin test flights [of the new fighter] in 2009, and hope to
receive the aircraft in 2013," Col. Gen. Alexander Zelin said.
The new fighter aircraft, tentatively designated as the Sukhoi PAK FA
or T-50, will be built at the Komsomolsk-on-Amur aircraft
manufacturing plant in Russia's Far East.
The T-50 fighter, equipped with two powerful engines with thrust
vectoring, will feature high maneuverability and stealth to ensure air
superiority and precision in destroying ground and sea targets.
Some experts believe the PAK FA fighter has been designed to be
comparable to both the American F-22 Raptor and F-35 Lightning II.
It will eventually replace the MiG-29 Fulcrum and Su-27 Flanker
fighters in the Russian Air Force and will be exported to other
countries.
Interesting, it hasn't even flown yet and is at least two years late.
Typical Russian
Its taking longer for their Indian correspondents to gather the
designs and software from US "sources"...JG
Yes I believe the Chinese may now have a few of them, they're a very
secretive sort.
cheers....Jeff
Old July 18th 08, 08:50 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Outspend em again
in general, term "expensive" does not mean the best one
we already have had G5 thing to try long time ago
see, http://www.youtube.com/watch?v=6R2lm2QzCp8
Kind russian regards,
Yuri
www.testpilots.ru
Old July 18th 08, 02:15 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
On Jul 18, 4:50 pm, wrote:
Outspend em again
see,http://www.youtube.com/watch?v=6R2lm2QzCp8
Yuri
www.testpilots.ru
Although I can respect the impressive engineering in the MiG 1.42, Su
27/37 series, S.47 I can not take them seriously as
5th generation fighters. They are barely 4th generation aircraft.
They are barely and improvement over the F-15.
The Americans have with the F22 produced an air superiority fighter
that is vastly superior to anything else in the
world whether that be French, European or CIS or Russian. By vastly
superior I mean that the kill ratio will be
in favour of the F-22 by a very large margin.
This is easy to understand, the F-22 will detect any opposing aircraft
first, it will then be able to fire a missile first and destroy the it
enemy in large numbers. Modern missiles are quite reliable.
The Russian officers and engineers who set out to produce the MiG 1.42
and S.47 and Su 37 set out to produce an aircraft better than the 35
year old F-15. They succeeded in producing a slightly better aircraft
in some areas.
The USAF strategists and engineers who created the F-22 produced a
completely new concept that makes irrelevant these old ideas.
What the Mikoyan and Sukhoi have succeeded in producing are aircraft
that have the same thrust to weight ratio as the F-15 and the same
armament levels but better instantaneous turn rates due to more
complicated aerodynamics, possibly they have smaller radar signatures
but only by a small amount (a reduction by a factor of 10 is
insignificant). These so called 5th generation aircraft are only
slightly better than the 35 year old F-15. When the F-15 is upgraded
with modern radar (eg AESA) and missiles there is little better about
the new Soviet fighters except better dog fighting though there climb
rates and acceleration is likely to be little better. I understand
that the Russian or CIS short range missiles have evolved exceptional
maneuverability. The F-22 is designed to destroy its opponents well
before a dogfight can occur. I'm sure if a dogfight does occur the
F-22 with its truly exceptional thrust to weight ratio and very high
cruise speed will do very well.
In seeking to produce their own stealth fighters the Russian air force
has acknowledged this.
Attempts to produce stealth defeating radars based in impulses or bi
static principles will loose much of their effectiveness in the
presence of simple noise jamming.
New Russian fighter...wow! Ricky Piloting 25 March 21st 08 02:42 AM
New Russian Fighter? [email protected] Piloting 9 March 15th 08 02:13 PM
What is a nth Generation fighter? Tom Nealon Military Aviation 64 December 17th 03 11:18 PM
Russian Fighter Book Charles Talleyrand Military Aviation 11 September 13th 03 09:21 PM
Joint Russian-French 5th generation fighter? lihakirves Military Aviation 1 July 5th 03 02:36 AM
