EW Data logger failure?
Old July 27th 08, 10:36 AM posted to rec.aviation.soaring
nimbus
Default EW Data logger failure?
The red LED is always "ON" whatever I am doing with the ON/OFF switch.
Impossible to know if the unit is switched ON or OFF. With or without
antenna gives the same result.
Does anybody have an idea of the problem?
Bruno
Old July 27th 08, 11:24 AM posted to rec.aviation.soaring
Geoff Vincent
Hi Bruno,
I had an identical problem with our club EW (D) logger only last week.
Fixed it immediately by changing the battery. They thrive on a fresh
alkaline 9 volt cell, but seem to be very unforgiving of low cell
voltage - ours was a regular "heavy-duty" cell at 8.4 volts (no load).
Regards,
Geoff Vincent
Grampians Soaring Club
Australia
On Sun, 27 Jul 2008 01:36:16 -0700 (PDT), nimbus
Bruno
Old July 27th 08, 12:02 PM posted to rec.aviation.soaring
nimbus
On 27 juil, 11:24, Geoff Vincent
Hi Bruno,
Fixed it immediately by changing the battery. *They thrive on a fresh
Regards,
OK. But how to replace the battery? Do I need to send the Unit back to
the producer in UK?
Bruno
Geoff Vincent
Australia
Bruno
Old July 27th 08, 12:41 PM posted to rec.aviation.soaring
Martin Gregorie[_3_]
the producer in UK?
No, its a 5 minute job once you know where the battery is.
The battery is just inside the flat endcap opposite the D-9 connector.
Use a small, fine bladed screwdriver to gently prise out the two plastic
domes. These cover the screws holding the end cap on. Unscrew them
with a crosspoint screwdriver. Pull the cap off and slide the battery out.
Replace with a new 9v alkaline battery and reassemble in the opposite
order. The plastic caps press back into place.
Repeat annually.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old July 27th 08, 01:11 PM posted to rec.aviation.soaring
Martyn Johnson
Bruno
On the opposite end to the connector there are 2 small round black plastic
plugs. Lever them out with a small penknife. Take out the 2 screws
uncovered and the end plate pops off to show a PP9 9V battery which simply
unclips.
I have 2 rechargeable NiMH cells which I regularly recharge/swap. Works
for me.
Cheers
Martyn
Hi Bruno,
Fixed it immediately by changing the battery. =A0They thrive on a
fresh
load).
Regards,
the producer in UK?
Bruno
Geoff Vincent
Australia
switch.
Bruno
Old July 27th 08, 02:00 PM posted to rec.aviation.soaring
Brian[_1_]
On Jul 27, 5:11*am, Martyn Johnson
Bruno
unclips.
for me.
Cheers
Martyn
Hi Bruno,
fresh
load).
Regards,
the producer in UK?
Bruno
Geoff Vincent
Australia
switch.
Bruno- Hide quoted text -
- Show quoted text -
This does assume you have a "D" Model. If you have one of the newer
EW's it doesn't apply. But I have seen a simlar issue caused by a
setting in the setup file on the newer ones.
Brian
Old July 27th 08, 04:45 PM posted to rec.aviation.soaring
nimbus
I have the new model (bought in January 2008). I did remove the
"battery" cap. I found an assembly of 3 metal ion sub batteries.
These batteries are made by GBS in UK. I contacted them in order to
have spare batteries.
I hope that opening the battery cap will not make my flights invalid.
I am a little disappointed about the weakness of this battery assembly
(only after 6 months, I got already problems !).
Bruno
Old July 27th 08, 11:11 PM posted to rec.aviation.soaring
Edward Lockhart[_3_]
Bruno
I had a similar problem with my EW Microrecorder a few months ago - in my
case the hard drive was frozen.
Let the battery run flat (24 hours) and when you recharge, the recorder
resets.
As yours is one of the newer models, you can also reset the unit by
shorting two of the pins in the RJ45 connector. Sounds drastic but it is a
design feature on the newer units. You'll have to ask Graham which pins.
Hope this helps,
Edward
Old July 28th 08, 08:06 AM posted to rec.aviation.soaring
Mike Schumann
The EW Microrecorder doesn't have a hard drive.
Mike Schumann
"Edward Lockhart" wrote in message
Bruno
resets.
Hope this helps,
Edward
** Posted from http://www.teranews.com **
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 06:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 06:09 PM
Ted, your LX logger......... [email protected] Soaring 6 June 26th 06 05:21 PM
Cambridge 302 -or- Borgelt B50 plus data logger Romeo Delta Soaring 25 May 30th 04 10:50 AM
Colibri Data Logger reviewed TOM RENT Soaring 18 April 16th 04 11:47 PM
