Shrinking inner sleeve
Old August 10th 08, 03:09 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Shrinking inner sleeve
A splice by inner sleeve requires an inner tube with an OD just under
the ID of the original tubing.
I've been splitting the tube, removing a 5/16 lengthwise piece and
then squeezing the tubing in a vice, trying to keep it round. I'm
running a bead along the seam, then grinding it down. Finally, I chuck
it in my drillpress and file to fit.
Is there an easier /smarter way to do this? - MikeH
Old August 12th 08, 09:44 AM posted to rec.aviation.homebuilt
Bruce A. Frank
Yes, In my collection of scrap I usually have the next smaller diameter
of tube. polish it with a little sand paper and chamfer the cut ends
then tap things together. Your method works, I have done it when nothing
else was available, but the lack of a uniform tight fit all the way
around could reduce the load capacity...but, a couple of extra rosette
welds can eliminate that possible weakness by locking things together so
well that a "loose" spot in the internal fit makes no difference.
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 03:15 PM
Any tricks to forming an inner sleeve? Michael Horowitz Owning 0 September 7th 07 11:05 PM
Tie down sleeve for Ventus 2 Steve Leonard Soaring 7 April 5th 07 09:04 PM
Navman GPS sleeve Oscar Goudriaan Soaring 1 March 2nd 07 10:27 PM
is the US sailplane fleet shrinking? [email protected] Soaring 8 May 9th 06 08:23 PM
