what every boy needs - yeah seriously
Old January 8th 09, 06:37 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default what every boy needs - yeah seriously
veedubber and others
the venerable old VW engine conversion is quite usable.
if you were to take all the lessons learnt from all the engine
building done so far and apply them to a new engine design, what would
the new engine design look like?
I think the flat 4 makes a very serviceable aircraft engine.
underslung pushrods like the O-200 and VW would remain.
I'd use hydraulic lifters.
the castings for the crankcase would be simpler, more like the O-200
than the complexities of the VW casing.
the crankshaft would be a little more robust at the front end
I'd fin the pushrod tubes and use the oil returning to the crankcase
as a radiator.
the engine would be mounted on dynafocal lord mounts.
I'd use electron for the crankcasings.
spin on oil filter. (z79)
magnet in the sumpplug.
what else???
Stealth Pilot
Old January 8th 09, 07:58 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
"Stealth Pilot" schrieb im Newsbeitrag
would look like this one: http://www.ulpower.com/
Old January 8th 09, 08:34 PM posted to rec.aviation.homebuilt
All of that is out there, already available. But the truth is, it's
not needed; not in the immediate sense.
What IS needed are aluminum head-castings having twice as much fin-
area as what's presently available. This won't fit on a bug or bus so
there is no start-up money. Coming up with the cores should have been
done by the EAA -- about fifty years ago. The fact it wasn't is good
evidence that it won't.
The need for juice lifters is appreciated -- and they are already
available, if you start with a late-model Mexican crankcase (it uses
the Type IV hydraulic lifters). But you can reduce your valve
adjustments to once every fifty hours or so by tossing the stock
adjuster screw and replacing them with the swivel-foot type. Flat-to-
flat, the valve adjustment wears at a glacial rate, assuming the valve-
train geometry has been set up properly, which it isn't in nine
engines out of ten.
But the VW simply lacks the Good Stuff that is found in a REAL
aircraft engine, such as 8x the bearing area, and a flanged crankshaft
carried in a massive Final Bearing similar in size to that on the
A65.
Modern ignition systems are actually superior to the typical backwards
Slick, and there is no evidence supporting a need for dual ignition,
other than the Feel Good legislation passed in 1937 imposed upon us
after some Legislator's son augered in the E2 of the college flying
club. College. Rich kid(s). Our tax money to teach them to fly.
Until a Representative from Illinois wanted to know what the hell was
going on? Why only those particular colleges? And nothing for female
college students nor, heaven forbid, BLACK college students.(*) So
everyone jumped in and hung their favorite line-item onto the
legislation and THAT's how we ended up with a mandate to provide TWO
ignition systems rather than one. But most folks aren't bright enough
to figure it out. These are the same technical idiots who think
adulterating gasoline with subsidized alcohol fer crysakes is a GOOD
idea when it's roughly akin to shooting yourself in the foot while
practicing your Fast Draw in front of the mirror.
So we end up with the only organization that claims to speak for the
grass-roots aviators doesn't, and the only government agency that
claims to speak for aviation in general, won't. Because it is so
highly politicized that we're as likely to be ordered to put a
flashing red light on the nose of our airplanes during the Christmas
season, as to have them do anything that truly fosters 'General'
aviation... so long as the General happens to be driving a jet or
turbo-prop.
The point of all that is that it really doesn't have a lot to do with
powerplants. Nor even with airplanes. What it has to do with is
Money and Politics and the desperate urge to fix things that aren't
broke.
Want some examples of this & that? Tear down an aircraft engine,
compare it's rod bearing area to that of the Volkswagen. Indeed, tear
down a MODEL T and do the same! To sling a prop, hour after hour and
year after year, we need something we ain't got. But leave it up to
the 'experts' and we'll be forced to fly behind a 1300cc power-head
running six grand into a PSRU that costs about that and has a TBO that
doesn't match the power head.
In fact, if our lives are going to depend upon a gear-box from Lapland
we might as well push for a ceramic turbine as the hot-section... and
use the same basic engine for everything from 50hp to 200hp.
But we won't.
We'll be stuck with whatever us we'ens can throw together because when
push comes to shove, there aren't enough of us to even influence the
plowing under of some of our most cherished air fields. And while a
certain well-funded few will assemble their RV's and do everything By
the Book, a significantly larger number of dyed in the wool American's
will notice that there aren't any traffic cops in the sky and that, as
much as various agencies wish otherwise, there's nothing than your
personal integrity to prevent you from building yourself a flying
machine and using it as such, tens of hours each month and hundreds of
hours each year, without any numbers of any kind -- without those
LUXURY taxes the bean-counters insist on charging you. But of course,
that will divorce you from the SOCIAL aspects of General Aviation and
that right there will be enough to protect all those Americans who
fear having something fall upon their heads unless it is first blessed
by some bureaucracy. THEN it's okay for it to fall down upon their
heads.
It's not just the engine, although if we're talking about powered
flight it doesn't take a Rocket Scientist to see that the engine(s)
has a lot to do with it. Nor is it about the Politicians, although
anyone bright enough to pour **** out of a boot realizes we have the
best government money can buy. And it's not about the bureaucrats
either, since they are largely concerned with events AFTER they
happen. Which leaves the only group that has anything to do with the
issue, which is guys like you & me. In my case the fact I live well
below the 'official' poverty line renders me invisible. Which means I
can build and fly as much as I want to, without having any effect at
all upon the Important Decisions which shape the future of American
aviation (and Australian too, when you get down to it).
-R.S.Hoover
Old January 8th 09, 11:18 PM posted to rec.aviation.homebuilt
what else???
Stealth Pilot
As VeeDubber has pointed out the heads are the limiting factor for HP.
The VW has other problems but workarounds for them have been found,
even if they are inelegant ones.
I've looked at and sawed up more VW heads, and sketched out more ways
to improve them, than a sane person would be willing to admit to in
public. If one insists on dual plugs and a true improvement (other
than just more cooling capacity) then I haven't been able to come up
with a solution - unless one also moves the camshaft and spaces the
lobes out to match the bore spacing. This requires a new crankcase as
well.
Doing this opens up MANY options using inexpensive off the shelf
parts. I'm thinking a split head, like Scat makes, but following the
layout of a Porsche 356 might be a good starting point?
Oil-cooled VW heads are an option I have not heard anyone talk about
for aircraft use. I've not done any math related to this option but
it seems to be a viable one. Anyone actually tried the methods used
by Porsche tuners on a VW?
Leon McAtee
Old January 9th 09, 12:56 AM posted to rec.aviation.homebuilt
Monk
On Jan 8, 12:37*pm, Stealth Pilot
A Subaru?
Old January 9th 09, 01:16 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
what else???
Stealth Pilot
well.
Leon McAtee
Fin area of the heads is only the first in a long line of limitations.
To my thinking, the next is the cylinder hold down studs (that don't
go all the way across).
The next would be valve seats (hydraulic lifters won't help there).
Valve size would have to be enlarges to let the engine breathe.
Six or eight places later comes the thrust bearings. At some output
level one would have to take power off the fat end and install larger
thrust bearings.
In the end, it makes a wonderful 40 horsepower motor.
Old January 9th 09, 01:18 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Monk wrote:
On Jan 8, 12:37 pm, Stealth Pilot
A Subaru?
We had one running direct drive - at 40 to 50 hp.
But to use the full potential it needs a proper PSRU -
along with all the extra weight that implies.
(Ever try to prop a motor with a PSRU on it?_
Old January 9th 09, 01:56 AM posted to rec.aviation.homebuilt
Peter Dohm
"cavelamb" wrote in message
what else???
Stealth Pilot
well.
Leon McAtee
thrust bearings.
The cylinder hold down studs have always been my first concern as well.
In the end, I completely agree that it is a great, inexpensive 40 horsepower
alternative for a single place aircraft.
Peter
Old January 9th 09, 02:11 AM posted to rec.aviation.homebuilt
jerry wass
as a radiator.
what else???
Stealth Pilot
Would you please expand on "electron for crankcasings"
Old January 9th 09, 02:21 AM posted to rec.aviation.homebuilt
On Jan 8, 3:56*pm, Monk wrote:
A Subaru?
Not bad. But it's going to come down to the Bottom Line. And in
that regard, the individual heads are the winners. Why? Because we
can do the machining ourselves.
First off, we can forget about lost-foam or anything more exotic than
green-sand, simply because there aren't enough of us. So we stick to
standard, readily available valves, valve guides, valve seats and
studs. The fins make the castings pretty tricky but if it was easy
you would have seen it years ago.
There's a couple of directions we can't go but if we borrow a page
from the Corvair we can position our exhaust stack just about anywhere
and still have a good seal. Most of us have MIG, which means we can
do the stack-extensions. And since it's a new casting we can provide
the boss for the hold-down bolt.
Here again, borrow a page from the Corvair (or from GM) and we end up
with a 'rocker arm' that actually works. The tricky bit is that it
does NOT need to be aligned on a shaft... we can literally put a valve
anywhere there is room. And that means at any angle as well.
Domed or hemi-shaped chamber won't buy us anything. I'm pretty sure
of that, based on some work I did in that area about 30 years ago.
But that's actually to our advantage. By keeping the combustion
chamber simple we keep our valve-train geometry simple. AND YES, we
run juicers.
Exhaust outlet to the stack is probably a rectangle, as with the
Porsche. We put the wiggles into the exhaust stacks, which we make
out of Monel or whatever, secured with that bolt we stole from the
Corvair.
So we make a L-head and an R-head; mirror images. We do the best we
can with the fins but recognize our limitations and leave the most
difficult of them as CUT fins: Rather than try to cast perfect fins in
a couple of high-risk areas, we settle for a quarter-inch bar of
aluminum that's configured for easy SAWING, which we do as part of the
flash clean-up.
-R.S.Hoover
Yeah! I'm back online..No thanks to Charley. CFLav8r Piloting 10 August 24th 04 05:14 AM
Yeah, I got that one... Wade Meyers Military Aviation 0 July 1st 03 05:45 AM
