Airliner crashes into Hudson River after LGA departure
Old January 17th 09, 09:30 PM posted to rec.aviation.piloting
RST Engineering
Default Airliner crashes into Hudson River after LGA departure
Oh really, and how do you figure that. Any idea what his altitude was when
**** started happening?
I believe the mode C showed him maxing out at about 3200 MSL at 3+ minutes
into the flight. That would seem to be right with a 200 knot max glide rate
sink of about 1000 fpm and a 6 to 7 minute take-off to landing time.
  #52
Old January 17th 09, 09:47 PM posted to rec.aviation.piloting
Monk
On Jan 17, 2:54*pm, (Jeff none) wrote:
1 of the passengers said something about seeing birds flying by before
the landing.
Although the pilot did an excellent job I wouldn't call it a
"landing", more like a ditching maybe?
  #53
Old January 17th 09, 09:57 PM posted to rec.aviation.piloting
Maxwell[_2_]
"RST Engineering" wrote in message
when **** started happening?
rate sink of about 1000 fpm and a 6 to 7 minute take-off to landing time.
Probably a moot point now anyway, haven't they established he landed gear
up?
  #54
Old January 18th 09, 12:08 AM posted to rec.aviation.piloting
RST Engineering
They established that two days ago.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"Maxwell" #$$9#@%%%.^^^ wrote in message
up?
  #55
Old January 18th 09, 12:11 AM posted to rec.aviation.piloting
Ricky
On Jan 17, 2:17*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
I wonder if the gear was still down from take off, and they didn't have
time
or power to lift it.
That statement is as idiodic as some things MX says...oh, wait, you
have an "MX" in your sig, too. Go figure, two of the worst trolls have
"MX" in their names.
From the photo of the plane as it approached the river and the fact
that he was above 3,000 ft, when the birdstrike occured. I know your
aviation knowlege is practically nil, but an airline usually retracts
their gear by then, just so you know.
Any idea what his altitude was when sh** started happening?
About 3,400 ft, according to http://www4.passur.com/lga.html.
Any more stupid questions, MX?
Ricky
  #56
Old January 18th 09, 12:16 AM posted to rec.aviation.piloting
B A R R Y[_2_]
Tech Support wrote:
He looked at Teterboro, glanced at the altimeter, figured
the angles and did the math. He decided in that nano second that he
couldn't make Teterboro, and THAT decision made his entire salary for
a lifetime career.
Coming up short @ TEB would have been Ug-ly!
  #57
Old January 18th 09, 02:52 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.disasters.aviation,rec.arts.poems,demon.local
ah
Default Maxie begins a new kook-out.were.... Airliner crashes into Hudson River after LGA departure
Bertie the Bunyip wrote:
"Maxwell" #$$9#@%%%.^^^ wrote in news:%Focl.29929$H12.18354
@newsfe12.iad:
"Bertie the Bunyip" wrote in message
John wrote in
news:32b8ee0b-1587-4404-a9f3-e33d06d50c51
@u18g2000pro.googlegroups.com:
On Jan 15, 3:12 pm, Mxsmanic wrote:
Kingfish writes:
Holy smokes! CNN is reporting an airliner went down in the Hudson
after departing LaGuardia. I heard something about birdstrikes,
but
can't imagine a double engine failure due to that(?) They sure
picked a cold day to go swimming... Hope everybody is ok...
Bird strikes are a leading cause of engine failure. Jet engines
don't
often
fail all on their own.
Well, according to
http://www.aviationweek.com/aw/gener...y_channel.jsp?
channel=busav&
id=news/eng08036.xml
By the way, the study's authors noted that compressor stalls/surges
account for two-thirds of the engine malfunctions in today's
turbofans. This is a change from earlier generation turbine designs
in
which uncontained failures were the principal malfunction. Since
stall/ surge is the primary engine malfunction, one would assume
that
it would be a regular item during initial, recurrent or simulator
training. And yet, I cannot recall ever reviewing the matter or
being
exposed to a compressor stall/surge during a simulator session.
I have, but only a couple of times and just to run through the
drill.Most checklists just have you retarding the throttle and/or
shutting down anyhow.
Most times nowadays with high bypass fans it trashes the engine
straight
away, unlike the old JT8s and such which would fart away happily
enough
until you pulled the thrust lever back.
Bertie
Sounds like you, retarded and farting away.
Awww, maxie make a witty!
ROLF!
ah
  #58
Old January 18th 09, 04:00 AM posted to rec.aviation.piloting,alt.usenet.kooks,alt.disasters.aviation,rec.arts.poems,demon.local
Bertie the Bunyip[_28_]
ah wrote in news:49728b5c$0$57670
@newsfe12.iad:
John wrote in
Kingfish writes:
Hudson
but
don't
often
Well, according to
channel=busav&
stalls/surges
designs
in
that
being
straight
enough
Bertie
ROLF!
Tie me kangaroo down, sport.
Bertie
  #59
Old January 18th 09, 01:09 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.disasters.aviation,rec.arts.poems,demon.local
ah
@newsfe12.iad:
John wrote in
Kingfish writes:
Hudson
but
don't
often
Well, according to
channel=busav&
stalls/surges
designs
in
that
being
straight
enough
Bertie
ROLF!
What-ho, Squiffy?
ah
  #60
Old January 18th 09, 04:06 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
m:
One of the things that helped him make that decision was that he had
hundreds, if not thousands of "dead stick landings" as a flight
instructor, glider.
CFIG
Well, I wouldn't say there was much of a decision to be made, myself. no
thrust and all that. Glider instructor woudl have helped him control the
airplane OK.
Was chattin with an A320 driver last night and he told me the airplane's
flight controls would have gone into a a law that the crew weren't used to
as a result of the power loss ( unless they hade the APU running which is
not likely) making the handling less than intuitive for him.
Bertie
Plane down in Hudson River Judah Piloting 10 January 6th 06 05:15 PM
Peruvian airliner crashes in jungle Bushleague Piloting 4 August 24th 05 05:37 PM
Flying down the Hudson River SeeAndAvoid Piloting 19 March 24th 04 07:26 PM
Hudson river Paul Sengupta Piloting 2 January 9th 04 01:18 AM
Hitting airliner with rifle round? [was: PK of Igla vs. airliner] B2431 Military Aviation 7 August 21st 03 12:29 AM
