Why does one need to LEAN OUT a CARB when climbing?
Old January 21st 09, 06:29 PM posted to rec.aviation.piloting
Tman[_2_]
Default Why does one need to LEAN OUT a CARB when climbing?
Thanks, finally somebody on my nerdy wavelength, and a really thoughtful
reply, but...
Todd W. Deckard wrote:
The carb throat is a double venturi and a manometer between the opening and
the neck would show a theoretical pressure drop of:
p(opening) - p(neck) = .5 * density of air * { velocity(neck)^2 -
velocity(opening)^2 }
(Lets ignore carb ice for a second and say that the air is
incompressible).
agreed.
{ Pressure / density } + .5 * { velocity ^ 2 } + gravity * change_in_height
= a constant
I think you are speaking of the velocity of the gas in the orfice system
and the density of the gas, relative to the pressure differential that
is driving the fuel flow. If so, I agree (caveat below). Note that
this is equivalent to saying that the fuel flow is proportional to the
square root of the pressure differential, same assumption I made.
so Air over Fuel cancels your density term.
Check your math carefully, are you sure that you are not confusing the
density of the fuel (constant) and density of the air (decreasing)
terms. I gave this the quick and dirty back of the napkin verification,
and it seems I still had both density terms in the final equation
relating mass airflow to mass fuelflow. If you think you're right...
I'll do a little more rigorous playing with the terms.
My current hunch on this: The mass fuel flow is not proportional to the
square root of the pressure differential, but more or less directly
proportional to the differential. This is because of the viscous
friction effects of the avgas in going through the metering orfices. If
those effects predominate, (not surprising given the very small orfice
sizes), I'd say Bernoulli has little to say about the mass flow rate of
the avgas, and it is more linearly related to the pressure differential.
Q.E.D. Good question. If I ever become a physics teacher I am going to
put this one on the final!
I think I'm going to forward this to one of my old fluid dynamics profs
Old January 22nd 09, 12:03 AM posted to rec.aviation.piloting
Ron
On Wed, 21 Jan 2009 12:29:21 -0500, Tman
reply, but...
incompressible).
agreed.
= a constant
You all are making this much too complicated. The reason you lean the
mixture as you climb is.... if you don't the check airman will flunk
you on your check ride.
Ron
Old January 22nd 09, 12:36 AM posted to rec.aviation.piloting
reply, but...
* * * * * * *(Lets ignore carb ice for a second and say that the air is
incompressible).
agreed.
= a constant
is driving the fuel flow. *If so, I agree (caveat below). *Note that
terms. *I gave this the quick and dirty back of the napkin verification,
relating mass airflow to mass fuelflow. *If you think you're right...
My current hunch on this: *The mass fuel flow is not proportional to the
* square root of the pressure differential, but more or less directly
proportional to the differential. *This is because of the viscous
friction effects of the avgas in going through the metering orfices. *If
Q.E.D. *Good question. * If I ever become a physics teacher I am going to
I think your problem is the assumption that there's a linear
relationship between air density and pressure differential. The same
pressure differential is the force that lifts our airplanes off the
ground, and as they gain altitude the density decreases. The stall
speed will rise, but not linearly with the decrease in density; it's
the square root of the decrease in density that we're looking for. In
the carb, one-half the density should then cut the pressure
differential and therefore fuel flow by one quarter, which will give
us a mixture twice a rich as when we took off. We find half the
density at 18,000 feet, incidentally.
Dan
  #28
Old January 22nd 09, 01:43 AM posted to rec.aviation.piloting
On Jan 21, 5:25*pm, Tman wrote:
* In the carb, one-half the density should then cut the pressure
us a mixture twice a rich as when we took off. *
At the risk of dragging on the subject ... Wouldn't that actually lean
it out, requiring one to compensate by richening the mixture at higher
altitudes? *One-half the density i.e. one half the mass airflow at
constant velocity, fuel flow by quarter... sounds like that mixture is
leaner!
No, the fuel flow drops by a quarter, to three-quarters of what
it was at sea level. With half the density, that gives us a mixture
that is half again as rich as it was at sea level, requiring leaning.
Dan
Learning to lean WingFlaps Piloting 2 March 12th 08 11:47 AM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 02:48 AM
Carb temp guage vs. Iceman carb ice detector Mike Rapoport Piloting 1 September 28th 04 04:13 AM
Whether to Lean or Enrich jls Owning 12 March 3rd 04 08:56 AM
Leaning / step climbing? aaronw Piloting 30 November 17th 03 06:44 PM
