F35 cost goes up.
Old December 28th 03, 09:04 PM
Tarver Engineering
"Magnus Redin" wrote in message
snip
Canceling the USAF JSF version forcing the USAF to buy the USN version
and perhaps some more F-22:s saves money now and will perhaps make the
procurement more expensive when the aeroplanes are in production. But
perhaps not much more expensive since the production runs will be
longer.
Except that USN does not wish to participate in the F-35 procurement, in
favor of replacing the F/A-18As with robots. The USAF, however needs the
F-35 to hedge their bet that the F-22 will ever be produced in any numbers.
Old December 28th 03, 10:18 PM
Chad Irby
Oddly enough, the only person who seems to believe that the Navy wants
to give up on piloted planes in the near future is... well, Tarver.
Sure, you can find one or two odd folks who think robots are the way to
go in the short term (in the long run it's not so chancy, but the tech
is nowhere *near* what we need right now), but most folks agree that we
need a near-future manned Navy attack plane to replace the ones we have
right now.
The new carriers in the pipeline - the CVN-21 series - are planned to be
primarily F-35 equipped (with F-18 and E-2 for the near term), with UCAV
to supplement on high-risk missions - once they figure out how to use
UCAVs on a crowded flight deck with manned planes (not a trivial feat).
As far as the F-22, we're buying them, they're working fine, and we all
know Tarver's delusions on that particular airframe...
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old December 29th 03, 12:29 AM
Tarver Engineering
"Chad Irby" wrote in message
om...
numbers.
Actually, the Navy has publicly told the Pentagon each year, for several
years, that they want to opt out of the F-35 at production. The reason the
Navy stays is for the USMC version, to support fixed wing Marine air.
As to the Navy giving up piloted aircraft, I have already posted to this
thread the 526 F/A-18 Super Bugs in the Navy pipeline; as well as noting how
very successful the Navy's integration of COTS for reliability has been.
The Super Bug is already battle tested.
Old December 29th 03, 12:56 AM
Chad Irby
Then you can easily name a source for this, since it directly
contradicts everything they've said to the public, right?
Oh, wait. You can't. As usual.
cirby at cfl.rr.com
Old December 29th 03, 02:27 AM
Tarver Engineering
om...
In what way do you feel I have contradicted myself, Chad? What I wrote
there is identical to what I have written before. It it some lack of data,
or a reading and comprehension problem, you have?
Old December 29th 03, 04:27 AM
Chad Irby
several years, that they want to opt out of the F-35 at
production.
Okay, here's a reading comprehension tip:
When I mentioned "the Navy" and how *you* contradicted *them*, you
weren't contradicting *yourself*, you were contradicting "the Navy."
What I wrote there is identical to what I have written before.
Yes, and it's still wrong.
No, it's the same old one you've been demonstrating here and in other
newsgroups since about the first day you discovered Usenet.
Once again, "the Navy" is not "you."
cirby at cfl.rr.com
Old December 29th 03, 08:12 AM
Chad Irby
Fred J. McCall wrote:
Scott Ferrin wrote:
:The "Super" Hornet isn't a stealth aircraft
For some definition of 'stealth'. It is billed as 'affordable
stealth'.
They did some airframe reshaping and added some radar absorbing
material, which takes the F-18 E/F out of the "barn door" category and
into something like the Eurofighter's RCS category.
Still an order of magnitude or so to go to get to the F-35 RCS range.
:and if they want stealth the F-35 is pretty much their only choice.
:Not only that the F-35 is suppose to have a significantly longer
:range than the Hornet.
But not longer range than the Super Hornet. Don't confuse the two
aircraft.
Um... the F-35 is going to have about a 50% better combat radius than
the F-18E/F, according to the Navy.
600 nm for the F-35 versus 410 nm for the Super Hornet versus about 290
nm for the older Hornets.
cirby at cfl.rr.com
  #29
Old December 29th 03, 05:06 PM
Fred J. McCall
Chad Irby wrote:
:Um... the F-35 is going to have about a 50% better combat radius than
:the F-18E/F, according to the Navy.
Sources?
:600 nm for the F-35 versus 410 nm for the Super Hornet versus about 290
:nm for the older Hornets.
Paper airplanes always look good. I'll wait until they actually have
the thing designed completely and are bending metal. Any bets that
it's heavier and has shorter legs than the current paper says?
Funny that the Navy intends to keep a mix of F-35C and F/A-18E/F then,
wouldn't you say? Particularly with the Super Hornet in the 'heavy
lift strike' and 'tanker' roles.
"Millions for defense, but not one cent for tribute."
-- Charles Pinckney
  #30
Old December 29th 03, 06:28 PM
Scott Ferrin
The Super Hornet is in production right now which means the airframe
have low flight hours or no flight hours on them. Tankers really
don't require anything ground breaking and the Super Hornets wouldn't
be used in a "first day of combat" role as an attack aircraft against
a competent adversary. Once the F-35 is in service the Super Hornet
will be pretty much second-string.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
