#62
"Morgans" wrote: "Orval Fairbairn" wrote I don't think that there is a very large "anti-auto engine crowd." That said, there are a lot of people, myself included, who view the auto conversion field as a potential minefield. I have known personally several people who used (or attempted to use) auto conversions in airplanes. Snip some examples There have been several other V-8 based direct drive instalaltions that, frankly, were very rough-looking and ended up as catastrophic failures. I have a friend who has a very nice Stuart 51, with a big-block Chevy and PSRU. He is taking small steps to make sure that it all works as desired. That said, if you think you can negotiate the minefield of enging development, have at it, but please, acquire all the technical hepl and talent you can get. No doubt, that it can be, and usually has been a good way to go broke, if you try to produce setups. Anyone who thinks they will save gobs of money is fooling someone. That said, there are ways to get the bugs out, and study of failures and successes are a part of it. Note that I said I would feel good about getting into a plane that had the bugs worked out of the conversion, or something along that line. I guess that line should have been emphasized, because that is the key. Precisely! Unfortunately, I have seen too many that had catastrophic results. Too many were attempting to fly before the bugs had even been identified. I have come to the conclusion that aircraft engine design is as much art as it is science. After all, the engines we normally fly (and take for granted) are those from which all (or at least, most) of the bugs have been eliminated. Some bugs still emerge, such as the infamous O-320H, dual mags, cracking crankcases on big-bore Continentals, etc. -- Remove _'s from email address to talk to me. |
#63
#64
Stuart Fields wrote:
Of course there are a bunch of Subaru powered aircraft out there with and without PSRUs. All that said, it is still hard to beat the Lycoming in every thing but acquisition costs. As one who's just bought the car that houses it, it will be interesting to see whether the Subary flat-four diesel finds any aircraft applications. Are there any diesel aer-engines, or diesel car engines frequently used in aircraft? I had the impression that diesel aero-engines died with airships and the Junkers 86, but I'm always willing to learn.... -- BMW K1100LT Ducati 750SS Honda CB400F SH50 Triumph Street Triple If you don't know what you're doing, don't do it. Workshop manual? Buy one instead of asking where the free PDFs are chateau dot murray at idnet dot com |
#65
The Older Gentleman schreef:
Are there any diesel aer-engines, or diesel car engines frequently used in aircraft? I had the impression that diesel aero-engines died with airships and the Junkers 86, but I'm always willing to learn.... Not sure if you are aware but you are posting to news://rec.aviation.homebuilt ; where this subject has been discussed several times. Though of course the story is not ended, not by a long way. I am considering an aero-conversion of the Subaru flat-4 diesel but will need engineering help as I'm not schooled in mechanics. If you are really curious about diesels in airships, consult www.dair.co.uk - that engine scales down the idea behind the JuMo diesels. KA |
#66
I have a friend who has adapted a V8 engine into his Long Eze. It is direct drive with no PSRU. He has flown cross country from CA to Oshkosh several times. As far as I can tell he has not had any engine problems. Wow, I would like to see that set-up. Did he have to move the fire wall forward, for ballance? I would not use any auto engine, without at least an additional bearing for thrust added to the crank. I had a 350 chevy crank in a van that was 25 thousands over spec, in end slop. That was without any thrust on the engine. -- Jim in NC |
#67
jan olieslagers wrote:
The Older Gentleman schreef: Are there any diesel aer-engines, or diesel car engines frequently used in aircraft? I had the impression that diesel aero-engines died with airships and the Junkers 86, but I'm always willing to learn.... Not sure if you are aware but you are posting to news://rec.aviation.homebuilt ; where this subject has been discussed several times. I can see the x-post, yes. But I'm not a regular subscriber to the ng (well, never looked at it, to be honest), so I didn't know. Though of course the story is not ended, not by a long way. I am considering an aero-conversion of the Subaru flat-4 diesel but will need engineering help as I'm not schooled in mechanics. If you are really curious about diesels in airships, consult www.dair.co.uk - that engine scales down the idea behind the JuMo diesels. Thanks for that. I'm a hot air balloon fiend, so aerostats are always of interest. -- BMW K1100LT Ducati 750SS Honda CB400F SH50 Triumph Street Triple If you don't know what you're doing, don't do it. Workshop manual? Buy one instead of asking where the free PDFs are chateau dot murray at idnet dot com |
#68
On Sat, 7 Mar 2009 15:55:16 -0500, "Morgans"
wrote: wrote Chrysler put a LOT of 413 and 440 engines in medium duty trucks (like dump trucks etc) over the years - and used the same engines in New Yorkers and Imperials, as well as road runners etc (440). Ford did the same with the 460. Standard engine in big Lincolns, optional in pickups and LTDs, and very common in 3-10 ton trucks as well. The anti-auto (or truck) engine crowd will never admit that one of these engines would work well, and be reliable in an airplane. I get so tired of the "they never run at full output in autos" way of thinking. I still would rather get in an auto engine conversion airplane that has had the bugs worked out, than any airplane with a rotax engine of any size. And everyone else, no, I will not go into the reason for this attitude, again. With the possible exception of the 912S. Those 912s stand up VERY well but the price!!!!!!! |
#69
#70
On Sun, 8 Mar 2009 09:54:53 -0700, "Stuart Fields"
wrote: "Orval Fairbairn" wrote in message news ![]() In article , wrote: In uk.rec.motorcycles Morgans wrote: The anti-auto (or truck) engine crowd will never admit that one of these engines would work well, and be reliable in an airplane. I get so tired of the "they never run at full output in autos" way of thinking. I still would rather get in an auto engine conversion airplane that has had the bugs worked out, than any airplane with a rotax engine of any size. There is a fundamental problem, any auto engine is designed to deliver purely rotational power from the crankshaft to the transmission. In aero applications the prop is applying the entire power of the engine trying to pull the crankshaft forward out of the block. That needs some serious thrust bearings which auto engines simply do not have. That is where PSRU design takes up the mission. A good PSRU will have the thrust bearings, etc. required for the mission. I have a friend who has adapted a V8 engine into his Long Eze. It is direct drive with no PSRU. He has flown cross country from CA to Oshkosh several times. As far as I can tell he has not had any engine problems. I believe a cooling hose once. I also don't believe he did it for cost savings. @ 10cents per hour for labor he probably has tens of thousands of dollars in it. However he can get Vne at less than full throttle and doesn't worry much about 100LL. He is also a good engineer with a darn good oily thumb. Of course there are a bunch of Subaru powered aircraft out there with and without PSRUs. All that said, it is still hard to beat the Lycoming in every thing but acquisition costs. Forget the aquisition cost - it's the maintenance/rebuild that kills you. Certified parts are pricey. An average auto conversion can be zero timed for the cost of doing one jug on a "real" aircraft engine. |
| There I was, flat on my back... | Kyle Boatright | Home Built | 5 | August 16th 07 06:34 AM |
| Flat tire | Viperdoc[_4_] | Piloting | 11 | June 4th 07 03:57 PM |
| Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 02:59 AM |
| Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 03:12 PM |
| Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 06:57 PM |
