Wingtip Camera
Old April 3rd 09, 01:42 AM posted to rec.aviation.soaring
NG[_2_]
Default Wingtip Camera
Anybody have a recommendation for a small thin digital camera with
decent quality that might be suitable for taping to a winglet for
inflight down-the-wing shots, with a connection for an rf remote?
Have not been able to find a small camera with remote option.
Thanks...
Old April 3rd 09, 02:15 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
Actually normal small camcorders can be used, that often do come with a
remote control. You really need to make some sort of proper mount out of
aluminium sheet or fibreglass that fits round the front of the wing. Then
hold it in place with gaffer tape. There is surprisingly little effect on
the handling or performance of the glider, but don't let the FAA or EASA
catch you doing it!
Derek Copeland
Thanks...
Old April 3rd 09, 03:30 PM posted to rec.aviation.soaring
Simon Taylor[_2_]
Thanks...
Canon IXUS compacts capable of running the 'CHDK' software (third party
software for your digital camera, no matter how odd that sounds) allow the
shutter to be triggered by applying a voltage to the USB port on the
camera.
http://chdk.wikia.com/wiki/CHDK
The RF remote would have to be adapted from something suitable; to trigger
an old 35mm camera I used a wireless doorbell. Of course, keep in mind that
nowadays there's always the lazy option of setting the camera to interval
shooting and letting the multi-gigabyte card fill up!
Simon
Old April 3rd 09, 09:30 PM posted to rec.aviation.soaring
vic20owner
Thanks...
ATC-2000 from oregon scientific? Has the advantage of including the
power, memory and camera in one unit so no cables and its relatively
cheap.
See example he
http://www.youtube.com/watch?v=XzIvCa1E2vs
Old April 5th 09, 12:12 AM posted to rec.aviation.soaring
cernauta
On Thu, 2 Apr 2009 16:42:28 -0700 (PDT), NG
Thanks...
many digital cameras support infrared remote control. My samsung
NV(8,10,11,15 etc.) for example.
they claim up to 10m range. I never tested this feature.
The suggested USB-wireless remote seems to me a promising solution
Aldo
Old April 5th 09, 09:00 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
The video below was made with a Mini DV Camcorder that comes with an Infra
Red remote Control.
http://www.youtube.com/watch?v=v2Qh95I_YM0
And this one was made using a 7.1 Megapixal Fuji S5700 still camera in
movie mode, recording onto a 2 Mb SD Card. Unfortunately no remote control
with this.
http://www.youtube.com/watch?v=d_7ClqhOeDw
The quality in both cases is quite acceptable for Youtube purposes, where
they seem to apply quite a fair bit of compression. It is better in the
originals.
My choice for gliding videos, if I was starting from scratch, would be a
small HD camcorder recording onto a built in HDD, mini DVD or SD card.
These are getting quite cheap these days, but I would recommend making a
proper mount for wing or tail mounted shots, so that you don't lose it in
flight!
Del Copeland
Thanks...
Aldo
Old April 5th 09, 02:00 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
Whoops Sorry, The SD card in the Fuji camera is 2Gb, not 2 Mb.
D.C.
Infra
Red remote Control.
control
with this.
where
originals.
in
flight!
Del Copeland
Thanks...
Aldo
Old April 8th 09, 10:02 AM posted to rec.aviation.soaring
noel.wade
Just a quick FYI:
Hard-drive based Camcorders are a bad idea, as most of them are not
qualified for use above 10,000' MSL (thanks to Kempton Izuno for
pointing this out and saving me some $$)... The problem is the
cushion of air that the hard drive read/write heads float on, above/
beside the platters... as air density goes down these things become
more susceptible to striking the spinning hard drive platters - not a
good thing!
--Noel
Old April 8th 09, 07:30 PM posted to rec.aviation.soaring
Jim White[_2_]
I doubt it Noel. The heads do ride on air but for sterility reasons in a
sealed air capsule which was sealed in a clean room. The most likely
problem is that the air tight capsule which is sealed with a sticky label
will be compromised. This will ultimately lead to contamination and disk
failure. The smallest mite of dust etc will cause a head crash.
At 08:02 08 April 2009, noel.wade wrote:
Just a quick FYI:
good thing!
--Noel
Old April 8th 09, 08:28 PM posted to rec.aviation.soaring
Just a quick FYI:
pointing this out and saving me some $$)... *The problem is the
good thing!
--Noel
Having worked in the HDD industry quite a bit I suspect the
aerodynamics of the head would be an issue if the sealed platters were
exposed to ambient pressure at well above 10,000'. The cold might be
an issue too if you were flying in wave. Dust is an enemy as well as
the heads fly REALLY low over the platter. Then there's shock/
vibration. All are arguments for using a solid state camcorder - no
moving parts aside from an optical zoom if you go that way. I just
ordered a Canon VIXIA HFS10 HD Dual Flash Memory w/32GB Internal
Memory & 10x Optical Zoom. It shoots True HD and is supposed to have
great low light performance, rapid autofocus and lots of other useful
features. You can get really good small, light HD camcorders that
record to SDHC cards these days for very little $.
9B
[10/13] - 11 Port Wingtip.JPG (1/1) Part 2 Waldo.Pepper[_2_] Aviation Photos 0 September 11th 08 12:23 AM
Camera mounts for small digital camera kestrel254 Soaring 5 August 19th 08 05:03 PM
L-23 wingtip wheel modification 5Z Soaring 0 February 8th 06 06:50 PM
Visible wingtip vortex! Bill Piloting 23 October 25th 05 11:37 PM
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 04:09 AM
