FAA throws pilots under the Airbus
Old October 29th 09, 05:28 PM posted to rec.aviation.piloting
Brian Whatcott
Default FAA throws pilots under the Airbus
Clark wrote:
Due process is required in judicial actions, not by private employers. Why
would you confuse one for the other?
Going way off track fast, here. But it is a source of amazement to
foreign nationals that we US citizens explicitly or implicitly sign up
for jobs that are "fire at will."
Expressing one's desire for employment with "termination for cause"
(describing the class of causes) is the remedy here.
Brian W
  #32
Old October 29th 09, 05:53 PM posted to rec.aviation.piloting
D Ramapriya
On 29 Oct, 20:00, Mike Ash wrote:
In article
*D Ramapriya wrote:
Quite. Skeptics need only remind themselves of the name of Nick
Tafuri, a cove with 13k+ flying hours who committed a somewhat
elementary error and didn't live long enough (nor did 160 others) for
the FAA to revoke or take any other action on his license.
So, wait, did Tafuri make a prior screwup that should have resulted in
revocation of his license, but didn't, and thus allowed him to continue
flying and get his passengers killed?
No, I probably mis-conveyed. Tafuri botched it and the upshot was a
very avoidable CFIT. Tafuri was apparently was one of AA's "star"
pilots (not entirely clear what maketh a star pilot). During an
approach to Cali, he had to key in the Rozo NDB on the FMC. He picked
the first name that came up on screen upon keying in "R" since the 757
FMC throws up the nearest waypoint first, without checking whether it
was indeed Rozo. On that night it wasn't, and he entered the
coordinates for an NDB called Romeo, causing the aircraft to make an 8
o'clock turn and on a course with a 10k ft mountain which they
impacted thereafter.
If after that error they'd somehow gotten off unscathed, whether
Tafuri's license would've been revoked is anyone's guess.
If there were no prior infractions then this
paragraph is a complete non sequitur.
Eh? The exact opposite, as I read it! It was *because* there were no
prior infractions that the "first error after yonks of safe flight,
ergo should be let off with a rap on the knuckles" line looks hard to
logically defend.
Ramapriya
  #34
Old October 29th 09, 06:07 PM posted to rec.aviation.piloting
Jim Logajan
D Ramapriya wrote:
On 29 Oct, 00:34, Danny Flyboy Danny.Flyboy.
I think any professional who has been doing his job flawlessly for 25
years who makes a mistake that results in no injuries to any persons,
no damage to any equipment, and causes 144 people to be 40 minutes
late deserves to have his/her livelyhood taken away for the rest of
his/her life!
Does the FAA revocation mean what you write or is it that these blokes
have to get themselves re-licensed (correct term?)?
Revocation "only" means their pilot certificate is no longer valid. But I
believe the revocation on its own doesn't mean the person can't attempt to
get another pilot certificate ab initio. According to FAR 61.13(d)(2) the
FAA will not issue any certificate to a person whose certificate was
revoked for a period of 12 months after the last revocation.
Assuming another certificate is obtained, having a revocation in ones
piloting history would make employment as a commercial pilot rather
difficult - though technically not impossible.
The only revocation I can find in the U.S. FARs that might be considered
potentially "permanent" is under 61.18 - which deals with so-called
"Security disqualification."
  #35
Old October 29th 09, 09:00 PM posted to rec.aviation.piloting
Mike Ash
In article
In article
logically defend.
In my mind, if you're advocating some action, and you bring up an
example to support it, that example had better have an improved outcome
as a result of your proposed action.
You're advocating for more immediate, stronger enforcement. This would
not have changed the outcome of Tafuri's ill-fated flight in any way. As
such, I don't see it as being a supporting example at all. He screwed up
and killed 160 people. If he had been flying in a regime of stronger
enforcement, he still would have screwed up and killed 160 people.
A good example here would be someone who screwed up badly, got a slap on
the wrist, and THEN went on to kill a couple of hundred people. I can't
think of any such off hand, but I'm sure someone else will pipe up with
one.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
  #36
Old October 29th 09, 10:37 PM posted to rec.aviation.piloting
Jeffrey Bloss
On Thu, 29 Oct 2009 16:00:09 -0400, Mike Ash wrote:
In my mind,
What mind?
_?_ Outside of a dog, a book is a man's best friend.
(@ @) Inside of a dog, it's too dark to read.
-oOO-(_)--OOo-------------------------------[ Groucho Marx ]--
grok! Devoted Microsoft User
  #37
Old October 30th 09, 01:44 AM posted to rec.aviation.piloting
a[_3_]
On Oct 29, 4:00*pm, Mike Ash wrote:
In article
In article
logically defend.
one.
Mike Ash
Radio Free Earth
An even better approach might be what the FAA is doing in this case.
If pilots do something overtly stupid, making an example of them will
likely make other pilots less likely to do the same thing. There may
very well be demands for due process, it will be interesting to see if
the pilots union support its members, or recognize the larger issue.
The action that spawned this thread has no realistic defense, does it?
The first rule I learned is, first control the airplane. They didn't,
and had no over riding circumstance that would justify the lack of
attention.
This is the FAA's version of the first rule of entrepreneurship --
Ready, Fire, Aim. In my view the FAA is right.
  #38
Old October 30th 09, 02:09 AM posted to rec.aviation.piloting
Ron Garret
Mike Ash wrote:
In article
In article
logically defend.
one.
I think the point Mike is trying to make is: imagine if the outcome of
the flight had been different. Suppose the plane had, say, run out of
fuel as a result of the extra time spent in flight, or flown into a
thunderstorm. In that case it is hard to imagine anyone arguing against
emergency revocation. The pilots' actions are still the same; the only
difference would be the circumstances. The decision to revoke or not
should be based on what the pilots *did* (or in this case failed to do),
not on whether they happened to avoid catastrophe through sheer dumb
luck.
rg
  #39
Old October 30th 09, 04:32 AM posted to rec.aviation.piloting
D Ramapriya
On Oct 30, 12:00*am, Mike Ash wrote:
In article
And that's what most SOPs hereafter will I'm sure incorporate...
something along the lines of "shut down all laptops" after the
"Approach Briefing" item on the checklist. Or even a "Check flight
deck alertness" directive to the Chief Cabin Attendant ere TOD
These will, as a direct upshot of their adherence, preclude a similar
scenario in future.
But the point about LNAV (PROFILE in Airbuses) remains - why had the
A320's FMC not commenced descent from TOD unless these coves had left
open the option of manual initiation?
Well, you never know. If a similar incident had occurred earlier
without loss of life, there may well have been a crosscheck (from the
other crew member) written into the checklist prior to confirmation.
That would be an example of pilot error in the technical sense, i.e.
having done the technical bits wrongly - selecting the Idle Open
Descent Mode during final approach in an A320, e.g.
What happened in this case was more a case of personal regimentation
(remain focused all the time, follow procedures/checlists, etc.) being
less than desirable - and these are hard to eliminate through
legislation alone - rather than the lack of competence itself. You
could introduce systems to forfend similar occurrences but then when
someone violates them negligently, as it seems to have happened, you
simply have to remove that weed, little else.
Ramapriya
  #40
Old October 30th 09, 05:11 AM posted to rec.aviation.piloting
Mike Ash
In article
attention.
"No realistic defense" doesn't really matter. It doesn't matter if what
they did was completely unjustified, they still deserve due process and
punishment in proportion to their infraction. Even confessed murderers
get due process. Pilots who screwed up and caused no harm should
definitely get it.
Suspend their licenses until an investigation is complete, put them
through whatever passes for due process with the FAA, and then at the
end if it all indicates revocation, then do it. I can't see any
justification for an emergency revocation.
Mike Ash
Radio Free Earth
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 01 Airbus 380 Lifting off Runway 36.JPG (0/1) Just Plane Noise[_2_] Aviation Photos 2 August 2nd 09 03:36 AM
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 11 Airbus 380 demo.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 0 August 1st 09 02:42 AM
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 10 Airbus 380 demo.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 0 August 1st 09 02:42 AM
Airbus 380 and White Knight 2 at Oshkosh - July 31 2009 01 Airbus 380 Lifting off Runway 36.JPG (1/1) Just Plane Noise[_2_] Aviation Photos 0 August 1st 09 02:42 AM
Paraglider spiral dive, throws chute and ends up in the trees Stewart Kissel Soaring 8 March 1st 05 11:04 PM
