The Melting Deck Plates Muddle - V-22 on LHD deck....
Old December 10th 09, 05:22 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
mike
Default The Melting Deck Plates Muddle - V-22 on LHD deck....
StrategyPage.com
December 2, 2009
by James Dunnigan
Earlier this year, the U.S. Navy discovered that the heat from the
MV-22's gas turbine engines, which blow their exhaust right on to the
deck of the LHD while waiting to take off, caused high enough
temperatures to the steel under the deck plates, to possibly warp the
understructure. This was already a known potential problem with the
new F-35B vertical takeoff jet fighter.
So now the Navy has two hot new aircraft that require an innovative
solution to the melting deck problem. The Navy also discovered that
the exhaust heat problem varied in intensity between different classes
of helicopter carriers (each with a different deck design.)
The Navy is looking for a solution that will not require extensive
modification of current carrier decks. This includes a lot of decks,
both the eleven large carriers, and the ten smaller LHAs and LHDs.
This is shaping up as another multi-billion dollar "oops" moment, as
the melting deck problem was never brought up during the long
development of either aircraft.
Previously, the Harrier was the only aircraft to put serious amounts
of heat on the carrier deck, but not enough to do damage. But when you
compare the Harrier engine with those on the V-22 and F-35B, you can
easily see that there is a lot more heat coming out of the two more
recent aircraft. Someone should have done the math before it became a
real problem.
Old December 10th 09, 06:23 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Malcom \Mal\ Reynolds
In article
3f72b032-2be2-4377-a180-01d7a81404fe@d2
1g2000yqn.googlegroups.com,
Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Use what NASA uses for the shuttle?
Wouldn't cost that much at all
Old December 10th 09, 06:42 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
David E. Powell
On Dec 9, 11:22*pm, Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Make a designated VTOL area and add shuttle style tiles there.
Old December 10th 09, 08:23 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
David E. Powell wrote:
On Dec 9, 11:22 pm, Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
It wouldn't stand up to mechanical abuse. While the tiles will
withstand heat they would crumble under the weight of taxiing aircraft
and deck vehicles.
Dan, U.S. Air Force, retired
Old December 10th 09, 08:24 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
guy
On 10 Dec, 04:22, Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
How did they manage with the AV8/Harrier then?
Guy
Old December 10th 09, 08:52 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
real problem.
I second the question and point that V-22 & F-35B's heat discharge is
from exhaust gas discharge and/or propeller (IF I grokked well, the 35B
has a sort of vertical propeller contraption) when the harrier's heat
discharge are from jet vanes so at least on paper, Harrier's vertical
exhaust is more hot than V-22...
Best regards from Italy.
Dott. Piergiorgio.
Old December 10th 09, 10:50 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
BlackBeard
On Dec 9, 11:52*pm, "dott.Piergiorgio"
real problem.
How did *they manage with the AV8/Harrier then?
discharge are *from jet vanes so at least on paper, Harrier's vertical
Dott. Piergiorgio.
As for the 35B, yes it uses a central fan device for vertical TO/L,
but it also has an exhaust tail that rotates to 90 degrees down. So
there are two forces working to lift it. I spent a week or so shooting
both.
As for the V-22, the solution, like the Harrier might be to limit TO/
L to rolling approach/landing. With both platforms direct impingement
is enough to cause damage.
BB
Old December 10th 09, 11:57 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
real problem.
Dott. Piergiorgio.
both.
*As for the V-22, the solution, like the Harrier might be to limit TO/
L to rolling approach/landing. *With both platforms direct impingement
BB
Or use the rocket launch technique and spray water across the take-off
area.
Old December 10th 09, 12:15 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
guy
real problem.
Dott. Piergiorgio.
both.
BB
area.- Hide quoted text -
- Show quoted text -
Can the V-22 not do at least a partial rolling(STOL) take off?
Guy
Old December 10th 09, 12:21 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Roger Conroy[_3_]
"Dan" wrote in message
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
It wouldn't stand up to mechanical abuse. While the tiles will withstand
heat they would crumble under the weight of taxiing aircraft and deck
vehicles.
Every LHD comes with an unlimited supply of water that can be used for
cooling.
Pump the water into a double skinned section of the deck (analogous to a
"wet wing" aircraft fuel tank) designated for use by the problematic
aircraft.
Cooling water directly on the deck surface will cause other problems - steam
and hot spray getting blasted in all directions is not a good idea.
Flight deck queens Michael Huber[_2_] Aviation Photos 2 January 19th 08 07:38 AM
Kiev's deck - with Yak-36s and Ka-25s Dave Kearton Aviation Photos 0 March 2nd 07 07:12 AM
Ka-25s on Kiev's deck Dave Kearton Aviation Photos 0 March 2nd 07 07:09 AM
Straight deck ops Greasy Rider Naval Aviation 18 January 10th 07 02:35 AM
Deck height Sean Trost Home Built 5 July 16th 04 04:46 AM
