#11
"JL Grasso" wrote in message ... On Fri, 16 Jan 2004 17:57:34 -0800, "Tarver Engineering" wrote: "Bertie the Bunyip" wrote in message .. . "Tarver Engineering" wrote in : "Phil Miller" wrote in message news
Hey Splappy, Do you remember this series of pronouncements; From: "Tarver Engineering" Newsgroups: rec.aviation.military Subject: Do Hercules military aircraft use the same fuel as civilian aircraft? Date: Fri, 8 Nov 2002 19:19:37 -0800 snip wrote in message Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture. Yes really, on every jet engine TIT is Total Inlet Temperature. Yep. Nope. Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. One has to wonder if the trolls of ram will ever catch a clue. The irony of it all. ![]() Total Air Temperature (TAT)is the maximum temperature attainable by air when brought to rest adiabatically. Total Air Temperature is the total of several probes at the inlet of the engine. (ie T1) The word "Total", when used to describe the type of temperature reading that a probe is reporting, has nothing to do with totalizers or wiring connections. The term "total" has to do with the use of multiple probes. Wiring thermocoulpes in seris gives a Total temperature. Where the probes are wired in parallel, a Totalizer is used downstream to add the thermocouple outputs together. Why do you post, Grasso, when it is clear that there is no subject WRT aircraft that you know? Perhaps you would do better sticking to your parts catalogs and forget about pretending you understand anything about aircraft. Otherwise, you are likely to become a hazard to aviation. |
: "John Mazor" wrote in message ... "Bertie the Bunyip" wrote in message ... "Tarver Engineering" wrote in : "Phil Miller" wrote in message news
Hey Splappy, Do you remember this series of pronouncements; From: "Tarver Engineering" Newsgroups: rec.aviation.military Subject: Do Hercules military aircraft use the same fuel as civilian aircraft? Date: Fri, 8 Nov 2002 19:19:37 -0800 snip wrote in message Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture. Yes really, on every jet engine TIT is Total Inlet Temperature. Yep. Nope. Once again, Tarver goes TITs up. Once again the Bunyip has been mazored. Nice troll though. I'm an excellent troll, actually. Bertie |
: "Bertie the Bunyip" wrote in message ... "Tarver Engineering" wrote in : "Phil Miller" wrote in message news
Hey Splappy, Do you remember this series of pronouncements; From: "Tarver Engineering" Newsgroups: rec.aviation.military Subject: Do Hercules military aircraft use the same fuel as civilian aircraft? Date: Fri, 8 Nov 2002 19:19:37 -0800 snip wrote in message Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture. Yes really, on every jet engine TIT is Total Inlet Temperature. Yep. Nope. Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. Total inlet temperature? Bwawhahhwhahwhahwshhhwhhahwhahwhhah! What a fjukwit. One has to wonder if the trolls of ram will ever catch a clue. Oh I think they all have more than a clue as to what you're all about, splaps boy. The irony of it all. ![]() Well, exactly. Bertie |
: "JL Grasso" wrote in message ... On Fri, 16 Jan 2004 17:57:34 -0800, "Tarver Engineering" wrote: "Bertie the Bunyip" wrote in message .. . "Tarver Engineering" wrote in : "Phil Miller" wrote in message news
Hey Splappy, Do you remember this series of pronouncements; From: "Tarver Engineering" Newsgroups: rec.aviation.military Subject: Do Hercules military aircraft use the same fuel as civilian aircraft? Date: Fri, 8 Nov 2002 19:19:37 -0800 snip wrote in message Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture. Yes really, on every jet engine TIT is Total Inlet Temperature. Yep. Nope. Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. One has to wonder if the trolls of ram will ever catch a clue. The irony of it all. ![]() Total Air Temperature (TAT)is the maximum temperature attainable by air when brought to rest adiabatically. Total Air Temperature is the total of several probes at the inlet of the engine. (ie T1) The word "Total", when used to describe the type of temperature reading that a probe is reporting, has nothing to do with totalizers or wiring connections. The term "total" has to do with the use of multiple probes. Wiring thermocoulpes in seris gives a Total temperature. Where the probes are wired in parallel, a Totalizer is used downstream to add the thermocouple outputs together. Why do you post, Grasso, when it is clear that there is no subject WRT aircraft that you know? Perhaps you would do better sticking to your parts catalogs and forget about pretending you understand anything about aircraft. Otherwise, you are likely to become a hazard to aviation. Like you? bertie |
Tarver Engineering wrote:
Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. Yeah, OK, so in Tarverworld the temperature of the gas entering the turbine is around 18,000 degrees C. The irony of it all. ![]() Indeed. Rick |
Jim Yanik wrote:
bimetallic thermocouples generate millivolt signals,and paralleling them would not work. You can go back to sleep now. Rick |
"Rick" wrote in message ink.net... Tarver Engineering wrote: Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. Yeah, OK, so in Tarverworld the temperature of the gas entering the turbine is around 18,000 degrees C. What is you post supposed to mean, Rick? Did you just want to make something up and look stupid? |
"Rick" wrote in message ink.net... Jim Yanik wrote: bimetallic thermocouples generate millivolt signals,and paralleling them would not work. You can go back to sleep now. Unbelieveable. The irony of it all. |
On Sat, 17 Jan 2004 at 03:28 GMT, Bertie the Bunyip wrote in
alt.alien.vampire.flonk.flonk.flonk: "Tarver Engineering" wrote in : "John Mazor" wrote in message ... "Bertie the Bunyip" wrote in message ... "Tarver Engineering" wrote in : "Phil Miller" wrote in message news
Hey Splappy, Do you remember this series of pronouncements; From: "Tarver Engineering" Newsgroups: rec.aviation.military Subject: Do Hercules military aircraft use the same fuel as civilian aircraft? Date: Fri, 8 Nov 2002 19:19:37 -0800 snip wrote in message Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture. Yes really, on every jet engine TIT is Total Inlet Temperature. Yep. Nope. Once again, Tarver goes TITs up. Once again the Bunyip has been mazored. Nice troll though. I'm an excellent troll, actually. Bertie Nah, you're crap! ;-) But what's this rec.aviation.military froup? How can anything military be merely recreational? -- PJR :-) mhm #34x8 Smeeter #30 WSD #42 Alcatroll Labs Inc. (Executive Vice-President) news:alt.usenet.kooks - Hook, Line and Sinker, Dec 2003 news:alt.hackers.malicious - Wittiest Troll, 2003 news:alt.flame: Most Boring Writer, 2003 news:alt.fan.pjr - Usenet like Mother used to make (Remove NOSPAM to reply) |
news
"Rick" wrote in message ink.net... Tarver Engineering wrote: Yep, the individually wired theromcouples are sent to a Totalizer, when they are not wired in series. That is why the datum is a total. Yeah, OK, so in Tarverworld the temperature of the gas entering the turbine is around 18,000 degrees C. What is you post supposed to mean, Rick? Did you just want to make something up and look stupid? I agree with Tarver. Making things up and looking stupid is his game. It's very unfair of you to move in on his franchise. Bertie |
| Thread Tools | |
| Display Modes | |
| Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 11:14 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Hercules Engines | Tarver Engineering | Home Built | 0 | January 20th 04 12:05 AM |
| Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 06:36 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
