Hercules Engines
Old January 17th 04, 05:21 PM
running with scissors
"Tarver Engineering" wrote in message ...
"Bertie the Bunyip" wrote in message
"Phil Miller" wrote in message
news
Hey Splappy,
Do you remember this series of pronouncements;
Newsgroups: rec.aviation.military
Subject: Do Hercules military aircraft use the same fuel as
civilian aircraft?
Date: Fri, 8 Nov 2002 19:19:37 -0800
snip
Not really. On the T56 engine TIT = (T)urbine (I)nlet (T)empreture.
Yes really, on every jet engine TIT is Total Inlet Temperature.
Yep.
Nope.
Yep, the individually wired theromcouples are sent to a Totalizer, when they
are not wired in series. That is why the datum is a total.
One has to wonder if the trolls of ram will ever catch a clue.
The irony of it all.
do you know what "series" and "parallel" means ??
the irony of it all indeed !
  #43
Old January 17th 04, 05:23 PM
Tarver Engineering
"running with scissors" wrote in
message om...
snip
I ask because I came across an interesting paragraph in the T56-A-15
service manual yesterday. Went like this...
Same for any MM, the data does not need to be accurate.
grief !
so if that were the case, then a generic manual would suffice.
Nope, the manual has to be close enough to do the work. Errors in MMs are
commomplace and not any real hazard. Just as B-52 operators don't really
need to know how their wing works, mechanics don't really need to know how a
system works.
  #44
Old January 17th 04, 05:25 PM
Rick wrote in message link.net...
Yeah, OK, so in Tarverworld the temperature of the gas
entering the turbine is around 18,000 degrees C.
Indeed.
Rick
much the way that in tarverworld a spoiler is a flap and a flight
director is an autopilot.
  #45
Tarver Engineering
message om...
news
Hey Splappy,
civilian aircraft?
snip
(T)empreture.
Yep.
Nope.
they
Sure. I am an engineer with a masters degree.
So funny and so stupid.
  #46
Old January 17th 04, 05:27 PM
"Rick" wrote in message
ink.net...
they
What is you post supposed to mean, Rick?
Did you just want to make something up and look stupid?
thats purely your area of expertise, huh splaps boy.
  #47
Old January 17th 04, 05:29 PM
"JL Grasso" wrote in message
On Fri, 16 Jan 2004 18:55:11 -0800, "Tarver Engineering"
snip
The term "total" has to do with the use of multiple probes. Wiring
thermocoulpes in seris gives a Total temperature. Where the probes are
wired in parallel, a Totalizer is used downstream to add the thermocouple
outputs together.
Why do you post, Grasso, when it is clear that there is no subject WRT
aircraft that you know? Perhaps you would do better sticking to your
parts
catalogs and forget about pretending you understand anything about
aircraft.
Otherwise, you are likely to become a hazard to aviation.
You're the Wierd Al Yankovic of technology.
I am an engineer with a masters degree and you are a clueless loser, Jerry.
a sewage engineer with a masters degree in landscape gardening.
  #48
Old January 17th 04, 05:39 PM
snip
outputs together.
parts
aircraft.
Dick Van Dyke on crank ! who coined that expression again ?
  #49
Old January 17th 04, 06:02 PM
Rick
Why would you think that adding the signals from
thermocouples in series would add the temperature?
Well, maybe because the terminal voltage of thermocouples in
series is the multiple of the number of thermocouples.
In which case when the - the TURBINE inlet temperature - is
imposed on 18 thermocouples in series the output voltage is
18 times that of one thermocouple or 18 thermocouples in
parallel.
This concept which is so foreign to you is well known, it is
the basis of isotope or thermoelectric generators, the
arrangement is sometimes called a thermopile ... as opposed
to a Tarverpile which is a hot, steaming, but highly
unproductive, mound.
You must be a common troll, Tarver, it is inconceivable that
an adult with your level of reading and reasoning skills
could function outside a constant care facility. Maybe you
don't.
Rick
  #50
Old January 17th 04, 06:04 PM
Tarver Engineering
ink.net...
How would that have any bearing on temperature?
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 20th 04 12:05 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
