Hercules Engines
Old January 22nd 04, 03:23 AM
Tarver Engineering
"Rick" wrote in message
hlink.net...
Tarver Engineering wrote:
What if the thermocouples are wired in parallel, to a totalizer?
So now you are using the "p" word as if you knew it all
along ... geez, Tarver, you are a piece of work.
Sure and Yanik already notified you of the series type thermocouple
connection.
Are you really this dense, Rick, or are you just being a little turd?
  #122
Old January 22nd 04, 03:25 AM
Tarver Engineering
"Scet" wrote in message
Dan, we went through this early last year I think it was and Tarver was
shown to be wrong as per normal.
No Scat, I was correct then and correct now. The only difference is that
this time the Knoyle archive troll has collapsed.
You know, that idiot detector you bought into?
Or are you a Miller archive troll sub-idiot?
  #123
Old January 22nd 04, 03:26 AM
Tarver Engineering
snip
Sorry Jim, but it does work.
Sorry Scat, but it does work and is how the J-52, J57 and J-75 engines were
instrumented.
What is it you do, little troll?
  #124
Old January 22nd 04, 03:28 AM
Tarver Engineering
snip
Yep, an averaged TIT signal on a T56.
Nope, only an idiot would devide the Total.
To devide would only increase the complexity and reduce reliability.
Are you a janitor, by any chance, Scat?
  #125
Old January 22nd 04, 03:29 AM
Tarver Engineering
No it isn't John and you know it from the discussion we had on this
subject
last time....you were wrong then and you are wrong now.
I am still correct, the only difference is that I proved it in this thread.
You are making a fool of yourself, Scat.
  #127
Old January 22nd 04, 06:12 AM
B2431
snip
shown to be wrong as per normal. On T56 engines the thermocouples are
connected in parallel and pick up TIT, the signal is then averaged. They
are averaged due to the non-uniform temperatures that occur at the turbine
inlet due to the short time of spraying fuel from the nozzle, to fuel
ignition, to introducing the hot gasses at high velocity to the turbine
inlet. The hot gases are not completely mixed and so there are some
stratifications of hotter and cooler areas at the turbine inlet. The
temperature averaging function of the parallel thermocouple circuits
compensates for these non-uniform temperatures.
Scet
Oh, heck, and I bet I missed a bunch of tarverisms.
Dan, U. S. Air Force, retired
  #130
Old January 22nd 04, 07:19 AM
fudog50
Tarver, you were "totally" wrong in your original response dated Nov
8th, 2002 about T-56's and TIT. I can't speak for other motors but I
do know a T56-14 pretty well and have changed enough t-couples and
enough TIT gauges and done hundreds enough efficiency runs and
calculations to know that it is actually "Turbine Inlet Temperature".
You have since tried to tap dance around being put on the spot, too
funny! I got one for you, Mr. T-56, how can T-56 efficiencies
sometimes be measured at over 100%??? And what are the test cell
limits and the allowable differences between test cell runups and on
the wing measurements? What are the allowable differences between
flights? Ok, Mr. T-56, Lets hear your expalnation on this? How many
t-couples on a T-56 have you actually changed out? How many hours,
days etc. have you actually spent chasing an efficiency problem?
On Wed, 21 Jan 2004 18:28:29 -0800, "Tarver Engineering"
snip
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 20th 04 12:05 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
