"Cub Driver" wrote in message ... That a 1 kT airburst is a lot better than 100MT cumulative load dropped on Los Angeles, New York, Seattle, etc. True, but consider that any such missile would almost certainly have exploded over Canada, and the debris would presumably have fallen to the ground. What did the Canadians think of this? Apparently they liked it, because IIRC they also had AIR-2 Genies (US control of warheads, of course) for their own F-101 force. Brooks all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"WaltBJ" wrote in message om... I logged almost 1500 hours in the F102A and its ugly brother the TF. It was a delightful airplane to fly, light on the controls, and was a good formation bird. It had great performance compared with the F94/F86D/F89 group. It could reach about .93 in military and 1.3 in AB properly maintained the radar was every bit as good as the F4's. - when new. Later on it lost some performance due to tired engines. It had good range even clean - 950 miles clean, 1300 with wing tanks. Now for the bad points. 1 - couldn't see back - 60 degree blind cone to rear. 2 - fuel was in two sets of wing tanks - an equalizer was supposed to make sure you ran dry simultaneously. Often it didn't and you had to juggle the boost pumps to keep an equal amount in both wings. Get too busy and you could flame out due to an air bubble from the empty side. 3 - the canopy had to go before you could eject - its metal top precluded ejecting through it. 4 - No guns, not even one. 5 - wrong engine. The J57 was a good engine but the first engine, the Gyron, never made it into service. The second one was the Olympus but it was way delayed. There was about a foot space between the J57 and the inside fuselage . . . 6 - weak gear, limit touchdown at typical landing weights was 540 feet per minute. 7 - no internal air compressor. It used HP air to launch missiles and rockets, start the engine if no 3000 psi Joy unit was around, brakes, and emergency gear extension. The F84F had a compressor, why not the Deuce? 8 - No AIM9 rails - why not? 9- the Deeuce was skinned with 7075ST which was not Alclad and therefore the bird had to be painted to rpevent (alleviate?) corrosion. This added weight and in later days drag from touched up paint jobs. As for a real continental air defense mission - our conclusion was you weren't coming back. Either the prompt radiation from a TNW was going to get you or you were going to have to stop the bomber no matter what. BTW a 20 MT going off 60 miles away from a fighter at 40000 gives the crew something like 3000 rad right now. Air up there is too skinny to soak up the gammas. The delta configuration can be treacherous if you don't watch out. The Deuce could develop one hell of a sink rate if you got too slow. Just pulling the nose up and adding a little bit of power results in a higher sink rate. Getting careless on final approach was dangerous. It could just hold level flight at 115 KIAS and full afterburner with about a 35 degree angle of attack. Getting out of that state required lowering the nose and losing altitude) to reduce the induced drag to where the bird could accelerate. This was insidious because the bird was controllable in all three axes. Pulling power to idle at 115 left you in apparent 'level' flight but the vertical velocity indicator was pegged - downward. Pulling G - it could develop about 6 1/2 G at 300 KIAs - but stay there too long and all your airspeed disappeared real quick. It could fly a tighter overhead pattern than any other century series fighter - pull too many G and the downwind would be in so close it'd take a ninety degree bank to make the base turn. WingCos got red-faced when they saw that. BTW its absolute altitude was 59,000 plus, subsonic in full AB. Got up there once after completing a test hop - had read Jackie Cochrane had set a level flight altitude record in a T38 of something like 54000 and I thought the Deuce could top that. It did, handily. FWIW it was good XC bird and had lots of carry room. There was the main electronic bay behind the cockpit where two guys coudl get in there and close the hatch. I have it on good authority that eight cases of Crown Royal would fit in there. We genrally used the missile bay because we normally didn't take the missiles on cross countries. Some bases (SAC) got huffy if you had ordnance aboard. That's about it - cheers, Walt BJ WOW, I stand corrected. Thank you! Harley |
#24
a MiG but we got one hell of a lot of flying - 1800 hours in one (1!)
month, flying CAP for the recce birds and scrambling on anything that flew. I gotta assume you meant 180 hours! Still about double the most I ever had in a month in the fighting drumstick (EA-6B) Pugs He did not mean himself, he said we as in his unit. Ron Tanker 65, C-54E (DC-4) |
#25
Kevin Brooks wrote:
"Mark" wrote in message m... Have wondered whether the thinking behind the design was to engage multiple bombers (i.e. a formation) with one weapon.... That might have been a more applicable reason behind the larger warheads you found in the SAM's like Bomarc and Nike Hercules, Definitely. I've got the MICOMA History of the Nike Hercules (and also the Ajax) program, and the Nike Hercules alternative nuke warhead's primary role was to prevent the use of bunching tactics, i.e. coming in packed together so that the bombers appeared as one target on the radar, but far enough apart that a conventional warhead would only get one of them at most, and maybe none. The target handling capacity of the Nike system could only engage one a/c at a time, thus allowing most of them through the missile's engagement envelope. The nuke warhead (IIRR the W-30, the same as used by Talos, and supposedly 5kt) eliminated that option. Presumably it also served as an option of last resort against a single leaker ("Fail Safe", anyone?). The really funny part is the Army had to assure the more clueless citizens worried by living inside the booster impact circle, that the missiles would never be launched from their operational sites (generally around cities) for training, and that if the missiles ever were launched they'd have a heck of a lot more to worry about than the minuscule chance of having an empty rocket booster fall on their house. Guy |
#26
In article , Ron
wrote: a MiG but we got one hell of a lot of flying - 1800 hours in one (1!) month, flying CAP for the recce birds and scrambling on anything that flew. I gotta assume you meant 180 hours! Still about double the most I ever had in a month in the fighting drumstick (EA-6B) Pugs He did not mean himself, he said we as in his unit. Ron Tanker 65, C-54E (DC-4) I stand corrected, missed that, thanks for the clarification. Pugs |
#27
"Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Mark" wrote in message m... Have wondered whether the thinking behind the design was to engage multiple bombers (i.e. a formation) with one weapon.... That might have been a more applicable reason behind the larger warheads you found in the SAM's like Bomarc and Nike Hercules, Definitely. I've got the MICOMA History of the Nike Hercules (and also the Ajax) program, and the Nike Hercules alternative nuke warhead's primary role was to prevent the use of bunching tactics, i.e. coming in packed together so that the bombers appeared as one target on the radar, but far enough apart that a conventional warhead would only get one of them at most, and maybe none. The target handling capacity of the Nike system could only engage one a/c at a time, thus allowing most of them through the missile's engagement envelope. The nuke warhead (IIRR the W-30, the same as used by Talos, and supposedly 5kt) The nuclear weapons archive indicates the Nike herc actually used the W-31m, which came in a total of five yields (1 thru 40 KT), with two different mods produced for the Herc (Mod 0 and Mod 2, which I assume means that the 1 KT and 12 KT versions were available). http://www.designation-systems.net/dusrm/m-4.html Another source (NPS, surprisingly enoough) claims that they were fitted with W-31's and three yield options (2-20-40 KT), and two other sources indicate the W-31 with 2 or 40 KT. So from what i can discern, the Nike Herc carried the W-31, and nobody can agree as to how many or what yields were offered. ![]() eliminated that option. Presumably it also served as an option of last resort against a single leaker ("Fail Safe", anyone?). The really funny part is the Army had to assure the more clueless citizens worried by living inside the booster impact circle, that the missiles would never be launched from their operational sites (generally around cities) for training, and that if the missiles ever were launched they'd have a heck of a lot more to worry about than the minuscule chance of having an empty rocket booster fall on their house. ISTR reading of a single test launch from an operational Nike site; IIRC it was a coastal site up in New England. But that may be as suspect as the various yields reported by different sources... We had a Nike site located at the old Patrick Henry Airport in Newport News (the launch site was right next to the remains of an old WWII POW camp, and the control site was located about half a mile closer to the runways); great place to root around as a teenager after it was shut down by the ARNG (though the missile launch pits had been backfilled with concrete rubble). Interestingly enough, we also had a BOMARC site operating during the same timeframe (though IIRC it closed down a year or so earlier than the Nike site) maybe three or four miles down the road (it is now serving multiple uses, with the admin/launch area being the public school bus maintenance facility, and some of the ammo bunker areas (located in an industrial/office park) being used by private companies). We also had F-106's (and later F-15A's) from the 48th FIS sitting alert maybe ten or twelve miles away at Langley AFB, and another Nike herc site across the river at FT Story in Virginia Beach. We were one well protected chunk of geography. Of course, the area had a lot of rather densely packed high value targets (Langley, home of TAC and also IIRC an EC-135 Looking Glass site; Norfolk and its naval and naval air station facilities, Little Creek amphib base, Yorktown Naval weapons depot, Ft Eustis (which we invariably called "Useless", FT Monroe (which had additional protection, being the last active Army post complete with *moat*), etc. Brooks Guy |
#28
#29
All y'all worrying about air defense nuke missile airbursts ought to
get a copy of "The Effects of Nuclear Weapons" and in (my 1957 copy) Chapter 9 you will learn a lot about fallout. The drift of the fallout in a wind is something quite disturbing, even in a 15 mph wind, which for a 1 MT fission weapon results in lethal dosages hundreds of miles downwind. That was why NORAD went to 'bombkiller' nuclear missiles, to try to prevent that from happening. Walt BJ |
#30
"B2431" wrote in message ... From: "Kevin Brooks" Of course, the area had a lot of rather densely packed high value targets (Langley, home of TAC and also IIRC an EC-135 Looking Glass site; Norfolk and its naval and naval air station facilities, Little Creek amphib base, Yorktown Naval weapons depot, Ft Eustis (which we invariably called "Useless", FT Monroe (which had additional protection, being the last active Army post complete with *moat*), etc. Brooks The 135s were KCs with TWA and battle staff functions. We used the KC-135 T.O.s instead of the EC-135. They flew standard KC as well as Scopelight missions. Scopelight was the east coast version of Looking Class and flew the battle staff and CIC Atlantic. The air crew were 6 ACCS. There were similar missions based in England and the Pacific. The names of which I forget. Thanks for the clarification. Would that difference explain the unholy reverberations (for those of us below the flightpath) that accompanied their takeoffs, in that they used the water injection of the KC? Brooks Dan, U.S. Air Force, retired |
| I was wondering | Badwater Bill | Home Built | 2 | August 6th 03 05:38 AM |
