About when did a US/CCCP war become suicidal?
Old February 25th 04, 08:31 PM
Howard Berkowitz
In article . net,
"Carey Sublette" wrote:
"WaltBJ" wrote in message
om...
Comments:
1) It is true that there is no theoretical limit to the size of a TNW.
The practical limit is when the bomb vents to space rather than
expanding across the surface of the earth. Big bombs are impractical
since they blow the hell out of the hypocenter (spot directly under
the bomb) but the radius of destruction increases as the cube root of
the bomb's yield. One could take the same amount of critical material
and make numerous smaller bombs and achieve a much greater area of
destruction by carefully distributing them over the target zone.
The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to
strategic balance was that it was undeliverable against the U.S. The
weight
of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum
payload,
and two and a half times its normal weapon load. Range of the Tu-95 was
already marginal for attacking the U.S. even with a normal bomb load.
Even
worse, since the bomb's dimensions - 2 meters wide and 8 meters long -
were
larger than the bomb bay could accommodate part of the fuselage had to be
cut away, and the bomb bay doors removed. The bomb was partially recessed
in
the plane, but not enclosed, with over half of it protruding in flight. A
deployed version of a Tsar Bomba carrier would of course had a bulging
bomb
bay enclosure added, but this would have further reduced range from the
drag.
Clearly, it was unsuitable as an aircraft-delivered weapon. While I
tend to think the motivations were propaganda and perhaps some
technologists gone wild, I would not, however, dismiss it is unusable.
Impractical and fraught with risks? Of course.
Ship or submarine delivery systems, probably sacrificing the delivery
platform, certainly wouldn't have the same restrictions on cubage and
weight. Would we have been as alert then to a third-country tramp
steamer?
Conceivably, there might be some prepositioned ground options, perhaps
in Germany, as an ultimate deterrent against a NATO counterstrike.
Even nastier would be placement on seabeds.
  #43
Old February 25th 04, 08:52 PM
Jack Linthicum
Peter Skelton wrote in message . ..
MacNamarra stated in his book that the US was deterred from a
strike by the Soviets 550 warheads in 1962 (Cuban crisis), so MAD
was operating at that time, although not named yet. If he is not
correct, the 1963 test ban treaty is further evidence that the
situation was recognized.
I would say that MacNamara, as usual, is not correct. In 1962 the
decision-makers in the West (UK-USA) knew from Oleg Penkovsky that the
Soviet Union had only 10 or so ICBMs and they would take 10-12 hours
to get ready for launch. The Soviet documents from the period under
discussion remain inaccessible to historians and create gaps that can
only be filled in with conjecture. Even the reasons for the Cuban
missile gambit are very clouded.
http://www.gwu.edu/~nsarchiv/CWIHP/BULLETINS/b4a11.htm
Soviet Cold War Military Strategy: Using Declassified History
By William Burr
"The history of the Soviet strategic program is at the same time a
history of U.S. perceptions."1 So wrote a team of historians and
political scientists in a once highly classified Pentagon history of
Cold War strategic arms race. The authors were describing an
important problem: so long as primary sources were unavailable,
academic and government analysts interested in explaining Soviet
military policy had to resort to "inferences drawn by long chains of
logic" to interpret the scattered data available to them.2 And to a
great extent, that data, whether leaked/declassified or not, had been
filtered through the U.S. intelligence system. Under those
circumstances, interpretive efforts were always constrained; the
relative opacity of Soviet defense policymaking made it difficult to
ascertain, much less evaluate, the relevant "facts." This made it
easy for analysts to fall back on Cold War ideology and habits such
as "mirror imaging," which could easily lead to misunderstanding.
Thus, educated guesswork and perceptions alone, severed from the
deeper understanding that primary sources can provide, shaped the
American public's understanding of Soviet military decision-
making, policies, and programs for the entire Cold War period.
more
  #44
Old February 25th 04, 09:23 PM
Jack Linthicum
(Peter Stickney) wrote in message ...
"George Z. Bush" writes:
Peter Stickney wrote:
BMEWS was the response to the threat of ICBMs coming over the Pole.
But, in some ways, we were still further along than the Soviets wer in
building and deploying useful ICBMs and SLBMs. Kruschev was great at
showing off spactacular feats of missilery, and veiled, and not so
veiled threats to use his missiles, but that wasn't backed up by what
was in the field. Consider, if you will, that if the Soviets had had
a viable ICBM or SLBM force in 1962, they wouldn't have tried putting
the short-range missiles in Cuba. That whole business grew out of the
Soviet's knowledge that they couldn't effectively strike. (Either First
Strike or Second Strike)
That was all very interesting, and certainly did much to refresh flagging
memories. However, it still didn't resolve the starting date for
MAD, because
it ignored the ongoing SAC airborne alerts and the nuclear armed subs roaming
the oceans. I personally have the feeling that the MAD doctrine evolved from
recognition of those SAC policies by the Soviets, which would place
the date at
or before construction of the DEW line.
All guesswork on my part. What do you think?
Well, just my opinion, of course, but I think that the MAD thinking
didn't occur until the mid '60s. It really didn't get set in stone
until it was decided to limit the deployment of the Spartan/Safeguard
ABM system, which occurred before the negotiation of the ABM Treaty
which occurred in 1972. The Soviets, of course, had been trying with
all possible strength to get systems in place to deliver their nukes
all through the 1950s. As I pointed out before, air-breathers -
Bombers and Cruise Missiles, weren't going to cut it, at least in our
mutual perceptions. (Since it never got tried for real) The Soviets
put more efforts into their ICBM projects than we did, but their
progress wasn't as fast as they wished, so they propagandized the hell
out of it, making themselves look much more powerful than they were,
and hoped that we either wouldn't find out, or wouldn't call the
bluff. (All that Missile Gap stuff in the 1960 election, for
example.)
So the Soviets had been trying to present a credible force for quite a
while, but weren't really there.
All through the 1950s, the Soviets didn't have any confidence in their
ability to put bombs on target, The idea of MAD, which is more a
Western conceit, rather than a bilateral policy, didn't come about
until the Soviets had a significant and reliable ICBM force. This
didn't happen until the mid '60s, at best, with their development of
storable-fuel ICBMs, and the Yankee Class Ballistic Missile Subs.
That feeling of inferiority, after all, was what drove Kruschev to try
to put the short and medium range missiles in Cuba in 1962. They knew
that they were going to come off second best against what we had, and
counted on holding the initialtive and being agressive to make the
differnece. It didn't work that way, and that's the main reason why
Khruschev was chucked out - he scared the Supreme Soviet more than he
scared us. (And mind you, he was plenty scarey)
There's no definite indication tha the Soviet Heirarchy ever really
bought into the idea of MAD. The Soviets, don't forget, were perfectly
willing to trade vast numbers of their population for their system's
survival. The communization of the Ukraine, and the scorched-earch
strategies used in WW 2 are ample examples of that.
But then, this is one of those things that is really a matter of
trying to nail Jello to the wall - since it was never a stated,
formal, policy, but more an attitude and set of perceptions.
http://cns.miis.edu/pubs/npr/vol09/91/91krep.pdf which argues MAD came
about after the various treaties had established offensive missiles
but prohibited defensive missiles. Everyone tries to put a date on MAD
but I would argue that once Herman Kahn starting having his little
briefings on winning thermonuclear war the idea was fertilized and the
gestation period a matter of how you determine whether an idea is born
in the brain or on paper.
and
http://en.wikipedia.org/wiki/Mutual_Assured_Destruction
Mutual assured destruction
(Redirected from Mutual Assured Destruction)
Mutual assured destruction (MAD) is the doctrine of a situation in
which any use of nuclear weapons by either of two opposing sides would
result in the destruction of both the attacker and the defender. The
doctrine assumes that each side has enough weaponry to destroy the
other side and that either side, if attacked for any reason by the
other, would retaliate with equal or greater force. The expected
result is that the battle would escalate to the point where each side
brought about the other's total and assured destruction - and,
potentially, those of allies as well.
Assuming that neither side would be so irrational as to risk its own
destruction, neither side would dare to launch a first strike as the
other would launch on warning (also called fail deadly). The payoff of
this doctrine was expected to be tense but stable peace.
The primary application of this doctrine occurred during the Cold War
(1950s to 1990s) between the United States and Soviet Union, in which
MAD was seen as helping to prevent any direct full-scale conflicts
between the two nations while they engaged in smaller proxy wars
around the world. MAD was part of U.S. strategic doctrine which
believed that nuclear war between the Soviet Union and the United
States could best be prevented if neither side could defend itself
against the other's nuclear missiles (see Anti-Ballistic Missile
Treaty). The credibility of the threat being critical to such
assurance, each side had to invest substantial capital in weapons,
even those not intended for use.
This MAD scenario was often known by the less frightening euphemism
"nuclear deterrence".
Critics of the MAD doctrine noted that the acronym MAD fits the word
mad (meaning insane) because it depended on several challengable
assumptions:
Perfect detection
No false positives in the equipment and/or procedures that must
identify a launch by the other side
No possibility of camoflaging a launch
No alternate means of delivery other than a missile (no hiding
warheads in an ice cream truck)
The weaker version of MAD also depends on perfect attribution of the
launch. (If you see a launch on the Sino-Russian border, who do you
retaliate against?) The stronger version of MAD does not depend on
attribution. (If someone launches at you, end the world.)
Perfect rationality
No rogue states will develop nuclear weapons (or, if they do, they
will stop behaving as rogue states and start to subject themselves to
the logic of MAD)
No rogue commanders on either side at any time with the ability to
corrupt the launch decision process
All leaders with launch capability care about the survival of their
subjects
While MAD does not depend on the assumption that the retaliatory
launch system will work perfectly, it does depend on the challengable
assumption that no leader with launch capability would strike first
and gamble that the opponent's response system would fail
Inability to defend
No shelters sufficient to protect population and/or industry
No development of anti-missile technology or deployment of remedial
protective gear
The doctrine was satirized in the 1964 film Dr. Strangelove or: How I
Learned to Stop Worrying and Love the Bomb. In the film, the Soviets
have a doomsday machine which automatically detects any nuclear attack
on the Soviet Union, whereupon it destroys all life on earth by
fallout. The film also has the rogue commander who (ignorant of the
Russian doomsday machine) orders his wing on a (preemtive) nuclear
strike, betting that the high command has to back him by launching all
their nuclear arsenal to survive the Russian counterattack. The film
mirrored life in that the nuclear strategist Herman Kahn had actually
contemplated such a machine as one strategy in ensuring mutual assured
destruction. In fact, the film represents an interesting phenomenon
explored by certain theorists: contrary to the assumptions of MAD, a
threat fulfilling strategy --in which one promises to act on one's
threats, regardless of the rationality of doing so-- could be used by
one side to subdue the other. To have a chance of working, however,
the strategy must be known by the enemy --a condition that is not
satisfied in Kubrick's film. It is not entirely clear, though, whether
adopting such a risky strategy can be classified as a a rational act
at all.
The fall of the Soviet Union has reduced tensions between Russia and
the United States and between the United States and China. MAD has
been replaced as a model for stability between Russia and the United
States as well as between the United States and China. Although the
administration of George W. Bush has abrogated the anti-ballistic
missile treaty, the limited national missile defense system proposed
by the Bush administration is designed to prevent nuclear blackmail by
a state with limited nuclear capability and is not planned to alter
the nuclear posture between Russia and the United States. MAD's
replacement (asymmetric warfare) is designed to take advantage of
years of analysis that focussed on finding a concept for stability
that did not rely on holding civilian populations hostage.
The Bush administration has approached Russia with the idea of moving
away from MAD to a different nuclear policy of total weaponry
escalation. Russia has thus far been rather unreceptive to these
approaches largely out of fear that a different defense posture would
be more advantageous to the United States than to Russia.
Some argue that MAD was abandoned on 25 July 1980 when US President
Jimmy Carter adopted the countervailing strategy in Presidential
Directive 59. From this date onwards US policy was to win a nuclear
war. The planned response to a Soviet attack was no longer to bomb
Russian cities and assure their destruction. American nuclear weapons
were first to kill the Soviet leadership, then attack military
targets, in the hope of a Russian surrender before total destruction
of the USSR (and the USA). This policy was further developed by
President Ronald Reagan with the announcement of the Strategic Defense
Initiative (aka Star Wars), aimed at destroying Russian missiles
before they reached the US. If SDI had been operational it would have
undermined the "assured destruction" required for MAD.
The Bush administration also proposed the use of small nuclear weapons
to be used against terrorists in caves. The implication was that
nobody would militarily object to this preemptive usage of nuclear
weapons, as the US was the only superpower with both nuclear weapons
and strong world policy ambitions.
  #45
Old February 25th 04, 09:24 PM
Joe Osman
"Jim Knoyle" wrote in message
news
"Carey Sublette" wrote in message
ink.net...
om...
Comments:
weight
payload,
Even
were
be
recessed
in
A
bomb
drag.
2) I should think doctrine on the possible use of nuclear weapons
took
a serious hit when a real sober look was taken of the two nuclear
accidents the USSR experienced - Chelyabinsk and Chernobyl. The USSR
never ever achieved the capability to feed all its people from its own
resources and what fallout from numerous nuclear weapons would do to
the arable lands of the Ukraine really doesn't bear thinking about.
The U.S. similarly vulnerable to this effect from the eastward fallout
plumes of strikes on the Montana and Wyoming missile fields.
What the heck! Back in the '50s you could buy tickets and go
sit in abandoned uranium mines in Montana and elsewhere.
It was supposed to help cure 'What ails you.'
snip
There still there, but now its the radon doing the curing:
http://cnts.wpi.edu/RSH/Docs/Radon/Index_RadSpas.htm
http://www.outwestnewspaper.com/radon.html
I guess suckers are still being born every minute.
Joe
Carey Sublette
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
  #46
Old February 25th 04, 09:34 PM
Olivers
Jack Linthicum muttered....
At the same moment US INTEL, US Political (and Western European and the
NATO "consensus") opinions were clouded (and the four often quite
different, 4 conclusions from 4 perspectives), what the Soviet
"leasdership" actually "thought" and upon which factors they might base
actions and reactions remained equally if not more clouded. Nor was the
machinery within the Soviet organs of the state and the military near so
monolithic as we all would have liked to conclude (since it made
predictions so much easier and justifiable).
On "our" side, junior, company and field grade officers and low level
commanders tended to view the various Soviet weapons systems as far less
well developed and potentially effective than they seemed to be viewed at
the highest military and political levels, leading many of us to believe
that some exaggeration was employed at those levels to justify policy and
war plans.
Obviously, the modern parallel may be found as relates to the WMD
issue...that the risk in "denying" their potential existence may have
seemed so great that to do so seemed unwise.
Meanwhile, a "re-look" at the Soviet policy during the period signals that
the Soviet leaders were misled by their own military who, in a traditional
(for militaries and their suppliers throughout history) panegyric oversold
systems and capabilities to an even greater extent than we in the West did.
Perhaps, in the final analysis, better that both sides over-rated the other
and at the same time were over-sold as to their own capabilities, thus
staying a longer step away from some almost accidental petty confrontation
screwing the pooch.
TMO
  #47
Old February 25th 04, 09:43 PM
Chad Irby
Greg Hennessy wrote:
On 25 Feb 2004 08:31:03 -0800, (John Schilling)
Wouldn't a deployed Tsar Bomba carrier have been a militarized Proton,
aka UR-500 aka 8K82? The space launch version uses only storable
propellants, can put twenty tons into low orbit with the smallest
fairing easily holding a 2 x 8 meter payload, and my references on
the space launch side claim that it was developed with the ICBM role
and the Tsar Bomba payload in mind from the start (1961).
The airburst footprint of 100MT delivered that way would indeed be scary.
Hadnt realised that an ICBM was a viable delivery platform for it.
Weapons effects from:
http://www.stardestroyer.net/Empire/Science/Nuke.html
100 MT 1 MT 100 KT
77.1 km 11.7 km 4.5 km Thermal radiation radius (3rd degree burns)
33 km 7.2 km 3.4 km Air blast radius (widespread destruction)
12.5 km 2.7 km 1.3 km Air blast radius (near-total fatalities)
7.5 km 3.1 km 2.0 km Ionizing radiation radius (500 rem)
35.7 sec 4.5 sec 1.6 sec Fireball duration
2.7 km 430 m 170 m Fireball radius (minimum)
3.3 km 530 m 210 m Fireball radius (airburst)
4.4 km 700 m 280 m Fireball radius (ground-contact airburst)
Of course, with that same payload, you could put up a couple of dozen 1
MT bombs of the same vintage.
Looking at effective destruction, you only get:
100 MT 1 MT 100 KT
3421 km^2 163 km^2 64 km^2
21 times the "widespread destruction" area, for 100 times the power,
when comparing the 100 MT versus a 1 MT, and 53 times the effect for
*1000* times the power of a standard-issue 100 KT weapon.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #50
Old February 26th 04, 02:02 AM
Howard Berkowitz
Kahn wasn't the only one talking in that period. He published _On
Thermonuclear War_ in 1961, and the popularization _Thinking about the
Unthinkable_ in 1962, and _On Escalation: Metaphors and Scenarios_ in
1965.
Henry Kissinger had published _Nuclear Weapons and Foreign Policy_ in
1957, and there were various RAND Corporation and other publications
around then. Kissinger definitely raised the possibility of nuclear
warfighting in that book, which included discussion of tactical weapons.
A collection from the period is Klaus Knorr and Thornton Read (eds)
_Limited Strategic War_
destruction.
My recollection of Kahn's discussion of a doomsday machine was as a
reductio ad absurdum -- an extreme case to make people stop and look.
After one SAC targeting briefing, he is said to have commented "You
people don't have a war plan -- you have a wargasm." Indeed, one of the
rings of his 44-step ladder in _On Escalation_ is "spasm or insensate
war."
at all.
While there are very clear psychological questions whether combatants
would keep nuclear war limited, there certainly were steps to stabilize
the environment, more in war prevention. These included the original
"hot line", and the US giving Permissive Action Link technology to the
Soviets.
war.
I agree PD-59 was am extremely important document, but I wouldn't say it
specifically set a goal of victory. What it did do was create a wider
range of nuclear options, and, in particular, focused on survivable
command, control and communications during the transattack period.
As you probably know, that wasn't the early strategy. The first plans
had three major options, A, B and R. From memory, A targeted the Soviet
"atomic" infrastructure, B "blunted" conventional forces that could
attack Western Europe, and R "retarded" the economy by going after
industrial targets.
