Oudie and 302
Old October 31st 11, 12:19 AM posted to rec.aviation.soaring
Stephen[_3_]
Default Oudie and 302
Anyone using an Oudie with a CA302 ? Any comments on it? How do you
have it hooked up? Are you using the internal GPS or the 302 GPS?
Would you buy one now or wait?
Thanks, S9
Old October 31st 11, 02:02 AM posted to rec.aviation.soaring
Richard[_9_]
On Oct 30, 4:19*pm, Stephen wrote:
Anyone using an Oudie with a CA302 ? Any comments on it? *How do you
have it hooked up? * *Are you using the internal GPS or the 302 GPS?
Thanks, S9
Stephen,
The oudie works well with the CAI 302. The Oudie is powered with the
optional cable by the 302 . SeeYou is set up in the Hardware 302
screen and port is also set to COM 4 to use the CAI 302 GPS. This
will give you direct winds instead of the circling winds with the
internal GPS.
http://www.craggyaero.com/oudie.htm
http://www.craggyaero.com/CAI.htm
Richard
www.craggyaero.com
Old October 31st 11, 02:03 AM posted to rec.aviation.soaring
Paul Remde
Hi Stephen,
I'm biased since I sell both 302s and Oudies, but I think they make a great
combination. I flew with an Oudie connected to a 302A at a soaring contest
last year and was very happy with the pair. It would have been better to
have the Oudie connected to a 302 so it could receive vario, wind and
airspeed data from the 302. I used the Oudie and ConnectMe software to
download flight logs from the 302A to a microSD memory card. The Oudie can
also send task declarations to the 302 or 302A. I have tested it - it works
great.
The Oudie is supplied with a power/data cable that has an RJ45 connector,
and an RJ45 to DB-9 connector. The RJ45 to DB-9 connector can be configured
to work with the 302. It is a simple and free solution. The Oudie's
power/data cable must be powered with 12V.
Another option is the Oudie-PS5a-1 cable. It can be powered with 5V from
the 302 and also pass 5V power to the Oudie. You can see details he
http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1
I highly recommend connecting the 302 to the Oudie so the 302 can send
vario, wind and airspeed data to the Oudie. If the connect to the 302
fails, or the 302 fails, the Oudie will automatically switch over to using
its internal GPS. That makes for a nice, redundant system.
I've sold over 340 Oudies so far. Obviously there must be many happy
customers that are telling their friends about the Oudie.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Stephen" wrote in message
Thanks, S9
Old October 31st 11, 08:58 PM posted to rec.aviation.soaring
Stephen[_3_]
Curious ..
1) Does the Oudie create a separate .igc file even when using the 302
gps?
2) If the 302 gps fails and the Oudie switches to internal gps, will
the .igc file be intact?
S9
Old October 31st 11, 09:46 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Both the 302 and the Oudie log the flight in separate files. Only the 302
file is accepted for badges and records.
If the 302 fails the Oudie would still log the flight, but it couldn't be
used for badges or records.
Paul Remde
Curious ..
gps?
S9
Old November 1st 11, 07:27 PM posted to rec.aviation.soaring
Dan Marotta
....But it *could* be used for OLC. At least the file generated by my hacked
Mio running XCSoar was accepted in a test.
"Paul Remde" wrote in message
Hi,
Paul Remde
Curious ..
gps?
S9
Old November 1st 11, 07:32 PM posted to rec.aviation.soaring
Tony[_5_]
On Nov 1, 1:27*pm, "Dan Marotta" wrote:
...But it *could* be used for OLC. *At least the file generated by my hacked
Hi,
Both the 302 and the Oudie log the flight in separate files. *Only the 302
Paul Remde
Curious ..
gps?
S9
Oudie log file most definitely will be accepted by the OLC. Be
careful to exit SeeYou Mobile before powering down the Oudie or it
will result in an invalid IGC file giving the dreaded red circle of
doom.
Oudie logging its own separate file saved my butt on Day 1 of the
Region 10 contest when the SD Card on the Nano somehow popped out
during flight. I also had my FlywithCE running during the flight as a
third backup but didn't have to resort to that.
Old November 1st 11, 11:52 PM posted to rec.aviation.soaring
JohnDeRosa
and an RJ45 to DB-9 connector. *The RJ45 to DB-9 connector can be configured
to work with the 302. *It is a simple and free solution. *The Oudie's
Another option is the Oudie-PS5a-1 cable. *It can be powered with 5V from
the 302 and also pass 5V power to the Oudie. *You can see details hehttp://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1
Paul - How is the Oudie-PS5a-1 cable better than the supplied Naviter
cable in the box?
With the supplied Naviter cable you have this setup;
12VDC = 302 = Oudie supplied cable (serial) = Oudie
12VDC = same Oudie supplied cable (12VDC to 5VDC converter) = Oudie
With the Oudie-PS5a-1 cable you would have this setup;
12VDC = 302 = Oudie-PS5a-1 (serial + 5VDC) = Oudie
So the Oudie-PS5a-1 solution is cleaner/neater. Is it electrically
better? Better 12VDC to 5VDC conversion? Better RS-232 signal
converter?
Thanks, John
Old November 2nd 11, 12:21 AM posted to rec.aviation.soaring
Paul Remde
Hi John,
Please see my notes below.
Paul Remde
"JohnDeRosa" wrote in message
configured
cable in the box?
*** The Oudie's power/data cable must be powered with 12V. The
Oudie-PS5a-1 cable is powered with 5V from the 302. Once installed, there
are no functional differences that I'm aware of.
converter?
*** Good questions. The only advantage is the simple and clean setup. It
eliminates the need to connect the Oudie's power/data cable to 12V. The
Oudie-PS5a-1 cable has been quite popular. I guess many people prefer the
simple and clean approach.
Thanks, John
Old November 2nd 11, 06:07 AM posted to rec.aviation.soaring
Dave White
One other point I'd like to offer concerning the PS-5a-1 Cable. The
early models of the cable apparently were prone to breakage in the
mini-USB plug (Oudie end of the cable). Mine broke internally after
more than a year and Paul Remde and Goddard Electronics provided
excellent support and an updated cable in a very short time. I highly
commend and recommend them for their great customer service. The
cable costs more than a little, but it does work extremely well and is
a no-brainer to set up. Connect it to the serial port on the 302,
plug the other end into the Oudie, set up the Oudie communication
menu, and you're off to the races!
Oudie Steve Hunt Soaring 2 July 8th 11 01:19 AM
oudie Steve Hunt[_2_] Soaring 0 July 7th 11 09:58 AM
FS: Naviter Oudie Jonathan Hughes Soaring 2 May 26th 11 07:55 PM
Oudie with a LX 5000 Randy[_2_] Soaring 2 May 24th 10 11:48 AM
