#11
Ken,
Suggestion for you, start off by measuring the max thickness of each wing at say the root and 1meter increments and compare the two measurements. With that info in front of you, you will discover that gliders wings are not precision manufactured. The amount of work and money it would take to make two identical and correct to a speciific airfoil shape may be more than realistic. I would devote my time to making the leading edge correct and the remainder of the wing fair. Bob Fidler "F1" On Nov 1, 5:25*am, BruceGreeff wrote: The joys of ever advancing computer computational power. As things have become possible to calculate so the glider wings get more complex. The current crop of 18m ships are currently approaching thirty profiles over the ~8.7m of wing... To They generally blend the transition from one to the next, but you certainly can't measure a station and extrapolate further out or inboard. Yes they are not all made in CNC machined steel female mounds like the JS1 - and even there I am sure there is manufacturing variation, but you would have to think carefully before re-profiling significantly. Easy to disimprove things. On 2011/10/31 4:51 PM, Rick Walters wrote: On Oct 30, 3:40 pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Ken SH does not publish their airfoil data, or glide polars for that matter. The Ventus airfoil has changed in subtle ways since the 1981 a/b model introduction. The most notable changes have been a sharper leading edge and a thinner profile near the wingtip, which showed up on the V2a/b and C models. Take Bob's advice and sand, smooth, and polish. Rick -- Bruce Greeff T59D #1771 & Std Cirrus #57 |
On Nov 2, 11:46*am, Robert Fidler wrote:
Ken, Suggestion for you, start off by measuring the max thickness of each wing at say the root and 1meter increments and compare the two measurements. With that info in front of you, you will discover that gliders wings are not precision manufactured. The amount of work and money it would take to make two identical and correct to a speciific airfoil shape may be more than realistic. I would devote my time to making the leading edge correct and the remainder of the wing fair. Bob Fidler "F1" On Nov 1, 5:25*am, BruceGreeff wrote: The joys of ever advancing computer computational power. As things have become possible to calculate so the glider wings get more complex. The current crop of 18m ships are currently approaching thirty profiles over the ~8.7m of wing... To They generally blend the transition from one to the next, but you certainly can't measure a station and extrapolate further out or inboard. Yes they are not all made in CNC machined steel female mounds like the JS1 - and even there I am sure there is manufacturing variation, but you would have to think carefully before re-profiling significantly. Easy to disimprove things. On 2011/10/31 4:51 PM, Rick Walters wrote: On Oct 30, 3:40 pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Ken SH does not publish their airfoil data, or glide polars for that matter. The Ventus airfoil has changed in subtle ways since the 1981 a/b model introduction. The most notable changes have been a sharper leading edge and a thinner profile near the wingtip, which showed up on the V2a/b and C models. Take Bob's advice and sand, smooth, and polish. Rick -- Bruce Greeff T59D #1771 & Std Cirrus #57 Better use the time and $$ to fly and train rather than trying to achieve the utmost accuracy. One wrong thermal and you are a behind. |
On 11/2/2011 9:43 AM, wladkummer76 wrote:
Better use the time and $$ to fly and train rather than trying to achieve the utmost accuracy. One wrong thermal and you are a behind. You can do both: sand and paint in the Winter, and you can have a glider that climbs and glides better all the time. Fly in the summer, and learn to choose better thermals. If you do the work yourself, I don't think the cost is very high, and you'll get some of that back if you sell it, and enjoy looking at it and wiping down in the meantime. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Nov 2, 9:35*pm, Eric Greenwell wrote:
On 11/2/2011 9:43 AM, wladkummer76 wrote: Better use the time and $$ to fly and train rather than trying to achieve the utmost accuracy. One wrong thermal and you are a behind. You can do both: sand and paint in the Winter, and you can have a glider that climbs and glides better all the time. Fly in the summer, and learn to choose better thermals. If you do the work yourself, I don't think the cost is very high, and you'll get some of that back if you sell it, and enjoy looking at it and wiping down in the meantime. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) Sure..sand and paint is much less effort than sand, fill, measure, fill, measure, sand, measure, sand and finally paint. BTW my Ventus 1 is said to have a FX79-144K airfoil. I don't know what the V2 uses. Have you tried to contact S&H directly? They are usually very helpful. |
On Oct 30, 6:40*pm, wrote:
Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken I'm curious as to why you think you want/need to do this. The most it is likely to need is a bit of fill and smoothing of shrink areas. From my experience, if you aren't in the top 10 at the Nationals, you are wasting your time and money. Airfoil coordinates are proprietary and are not generally made available to customers or others. If you haven't done this before, you are more likely to make the glider worse instead of better. FWIW UH |
On Nov 3, 8:29*am, wrote:
On Oct 30, 6:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken I'm curious as to why you think you want/need to do this. The most it is likely to need is a bit of fill and smoothing of shrink areas. From my experience, if you aren't in the top 10 at the Nationals, you are wasting your time and money. Airfoil coordinates are proprietary and are not generally made available to customers or others. If you haven't done this before, you are more likely to make the glider worse instead of better. FWIW UH To satisfy your curiosity I will enlighten to my reasons for refinishing the Ventus. I SH gel-coat does not hold up well in Florida (or anywhere else where the sun shines). And even tho presently I'am not in the top 10 at the National doesn't mean I don't want to fly a sailplane that performs like a contender. The gel-coat is crazed and needs redone. Its A lot of work so I want to do the best I can. |
On Nov 3, 9:40*pm, wrote:
On Nov 3, 8:29*am, wrote: On Oct 30, 6:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken I'm curious as to why you think you want/need to do this. The most it is likely to need is a bit of fill and smoothing of shrink areas. From my experience, if you aren't in the top 10 at the Nationals, you are wasting your time and money. Airfoil coordinates are proprietary and are not generally made available to customers or others. If you haven't done this before, you are more likely to make the glider worse instead of better. FWIW UH To satisfy your curiosity I will enlighten to my reasons for refinishing the Ventus. *I SH gel-coat does not hold up well in Florida (or anywhere else where the sun shines). And even tho presently I'am not in the top 10 at the National doesn't mean I don't want to fly a sailplane that performs like a contender. The gel-coat is crazed and needs redone. Its A lot of work so I want to do the best I can.- Hide quoted text - - Show quoted text - So this is a "normal" mid life refinish. No templates needed for this if care is taken in sanding. If you are concerned with holding shape, pull templates off wings before refinishing. First 6 inches is plenty. Cut 1/2 think MDF to rough profile. Wax surface. Mix up body filler and spread on template. Slap in place and hold till cured. A template every 2 ft is enough. When sanding, only hand sand on leading edge area with block about 11 inches long. Beware, this is far more work than you think. BTDT too many times Good luck UH |
On Nov 3, 6:40*pm, wrote:
To satisfy your curiosity I will enlighten to my reasons for refinishing the Ventus. *I SH gel-coat does not hold up well in Florida (or anywhere else where the sun shines). And even tho presently I'am not in the top 10 at the National doesn't mean I don't want to fly a sailplane that performs like a contender. The gel-coat is crazed and needs redone. Its A lot of work so I want to do the best I can. If you have crazed gelcoat, that is obviously not a good thing. But making CNC templates for some mythical reference profile, and then adding a bunch of filler and work to make your wings match it, will likely introduce more problems than it solves. Your best bet is to profile only the first few inches of leading edge, and for the rest of it just concentrate on getting the waviness down to around .002". And given a choice between those, I'd ditch the profiling and concentrate on the waviness. I've done template checks on a variety of sailplanes, and I have stopped being surprised at how often the left wing profile has substantial variations from that of the right wing. And this isn't on dogmeat gliders, these are nationals-winning machines that go like stink and fly straight as arrows. The takeaway there is that absolute fidelity to profile is way down on the list of things you need. Much higher on the list is lack of waviness that prematurely trips laminar flow . Thanks, Bob K. www.hpaircraft.com/hp-24 (also search Facebook for "HP-24") |
On Nov 4, 1:42*pm, wrote:
On Nov 3, 9:40*pm, wrote: On Nov 3, 8:29*am, wrote: On Oct 30, 6:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken I'm curious as to why you think you want/need to do this. The most it is likely to need is a bit of fill and smoothing of shrink areas. From my experience, if you aren't in the top 10 at the Nationals, you are wasting your time and money. Airfoil coordinates are proprietary and are not generally made available to customers or others. If you haven't done this before, you are more likely to make the glider worse instead of better. FWIW UH To satisfy your curiosity I will enlighten to my reasons for refinishing the Ventus. *I SH gel-coat does not hold up well in Florida (or anywhere else where the sun shines). And even tho presently I'am not in the top 10 at the National doesn't mean I don't want to fly a sailplane that performs like a contender. The gel-coat is crazed and needs redone. Its A lot of work so I want to do the best I can.- Hide quoted text - - Show quoted text - So this is a "normal" mid life refinish. No templates needed for this if care is taken in sanding. If you are concerned with holding shape, pull templates off wings before refinishing. First 6 inches is plenty. Cut 1/2 think MDF to rough profile. Wax surface. Mix up body filler and spread on template. Slap in place and hold till cured. A template every 2 ft is enough. When sanding, only hand sand on leading edge area with block about 11 inches long. Beware, this is far more work than you think. BTDT too many times Good luck UH- Hide quoted text - - Show quoted text - Heinz's talked to the factory today, bottom line ,they are not willing to give up the data. I,ve been making templates off the orignal finish every 2 ft. and will use plan B. It's not more work than I think,it's more work than I would like to do. |
On Nov 4, 9:07*pm, Janet Goshorn wrote:
On Nov 4, 1:42*pm, wrote: On Nov 3, 9:40*pm, wrote: On Nov 3, 8:29*am, wrote: On Oct 30, 6:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken I'm curious as to why you think you want/need to do this. The most it is likely to need is a bit of fill and smoothing of shrink areas. From my experience, if you aren't in the top 10 at the Nationals, you are wasting your time and money. Airfoil coordinates are proprietary and are not generally made available to customers or others. If you haven't done this before, you are more likely to make the glider worse instead of better. FWIW UH To satisfy your curiosity I will enlighten to my reasons for refinishing the Ventus. *I SH gel-coat does not hold up well in Florida (or anywhere else where the sun shines). And even tho presently I'am not in the top 10 at the National doesn't mean I don't want to fly a sailplane that performs like a contender. The gel-coat is crazed and needs redone. Its A lot of work so I want to do the best I can.- Hide quoted text - - Show quoted text - So this is a "normal" mid life refinish. No templates needed for this if care is taken in sanding. If you are concerned with holding shape, pull templates off wings before refinishing. First 6 inches is plenty. Cut 1/2 think MDF to rough profile. Wax surface. Mix up body filler and spread on template. Slap in place and hold till cured. A template every 2 ft is enough. When sanding, only hand sand on leading edge area with block about 11 inches long. Beware, this is far more work than you think. BTDT too many times Good luck UH- Hide quoted text - - Show quoted text - Heinz's talked to the factory today, bottom line ,they are not willing to give up the data. I,ve been making templates off the orignal finish every 2 ft. and will use plan B. It's not more work than I think,it's more work than I would like to do. And be sure to seal it tight and put the the CG exactly the way it behaves the best (usually a personal taste, but does make a difference in thermals) |
| Thread Tools | |
| Display Modes | |
| Interesting biplane project... look at the wing profile | Bob Kuykendall | Home Built | 15 | December 5th 08 02:58 PM |
| Yet Another wing Refinishing question | shkdriver | Soaring | 5 | November 6th 08 12:41 AM |
| LS3A Wing Profile Data | Robert Fidler | Soaring | 14 | October 27th 08 10:59 PM |
| Wing Leading Edge Refinishing | Jan Eldem[_2_] | Soaring | 4 | June 17th 08 03:40 PM |
| ASW27 wing profile templates | basils27 | Soaring | 0 | June 29th 05 12:46 PM |
