Fine example of Tarver Engineering release for service
Old February 29th 04, 06:50 AM
Ralph Nesbitt
"Tarver Engineering" wrote in message
"Gord Beaman" wrote in message
Can you just imagine how long the tech course must be?...
A pitot tube is a fairly delicate instrument. There were artilce 15s for
those attepting to clean a pitot tube on our F-106 flightline. The pilots
did not apreciate having their displayed airspeed wrong.
What cleaning were they doing on pitot tubes on the flight line, "Using
Emory Cloth & Brasso to Polish the exterior of the tube"?
Ralph Nesbitt
Professional FD/CFR/ARFF Type
  #52
Old February 29th 04, 06:53 AM
Ralph Nesbitt
news
"Matthew S. Whiting" wrote in message
No, you have trouble writing things that make sense. What is unreliable
about a pitot tube? The heater is likely the least reliable part.
Which airplane(s) have pitot ports? I don't think I've seen one. What
makes them more reliable?
I have no interest in educating you, Whiting.
A typical Tarver response when querried for "Hard Data".
Ralph Nesbitt
  #53
Old February 29th 04, 06:57 AM
Ralph Nesbitt
Yes, I'm just a nice guy. :-)
You do have that going for you so far.
Your ignorance of pitot static systems is typical, however.
Yes, it seems to match yours, so I guess two of us makes it qualify as
typical. :-)
I thought you were disagreeing with me based on ignorance.
A prime example of the results of trying to do something you are not
qualified to do, "Like Thinking", IMHO.
Ralph Nesbitt
  #54
Old February 29th 04, 06:59 AM
Phil Miller
On Sun, 29 Feb 2004 05:50:27 GMT, "Ralph Nesbitt"
Internal cleaning with NSN 7215-66-3244-34 Pipe Cleaner, Removal, Mud
Bee. His section was out of jet wash, so the had to make do with rotor
wash from the helo flightline.
Phil
Great Tarverisms #1
The Air Speed Indicator (ASI) shows
You made that up, didn't you?
The IAS indicator says IAS, not ASI.
Why do you come here pretending to know something
when you don't even know the words?
John
  #55
Old February 29th 04, 06:16 PM
Ralph Nesbitt
"Phil Miller" wrote in message
for
pilots
Phil
Is "Prop Wash" an acceptable substitute for "Jet Wash" in this situation, or
is it necessary to use "Jet Wash" on Jet A/C 'Pitot Tubes", "Prop Wash" on
"Pitot Tubes" on A/C using "Propellers", & "Rotor Wash" on Pitot Tubes on
Helo's? TIA
Ralph Nesbitt
  #56
Old February 29th 04, 06:38 PM
Ralph Nesbitt
"JL Grasso" wrote in message
for
pilots
Ralph Nesbitt
They were likely just burnishing out Tarv's teeth marks...
Jerry
Would Tarver try to "Blow" any contaminates out of the "Pitot Tube".
Ralph Nesbitt
  #57
Old February 29th 04, 07:41 PM
running with scissors
"Tom Sixkiller" wrote in message ...
"running with scissors" wrote in
message om...
like your sobriety ?
And in the next message he shows what a brick brain you are.
mmm yeeees.
  #58
Old March 1st 04, 02:15 AM
The CO
"fudog50" wrote in message
snip
IIRC, the only indicator that had both pitot and static inputs
was the VSI/Rate of climb indicator and the internal bellows in the
gauge performed the differential action.
Ok, what they taught me was that the VSI ran on static pressure and
*metered* static pressure.
I'm not aware that pitot pressure (which is directly related to
airspeed) would be of use for a VSI.
Can you explain how that would be used in a VSI? I can't see any
connection.
The only time pitot pressure = static pressure is if the aircraft is
stationary and there is no wind.
The difference between static port pressure and static pressure that was
restricted as to the rate it
could alter (inside the VSI) by way of a port that is very small in
comparision to the main static port gives
the rate that pressure (and therefore altitude) is changing, giving you
a rate of climb or descent.
Airspeed has pitot inputs only.
ISTR that an ASI that can give you a TAS instead of an IAS had static
pressure and temp sensors
in addition to the pitot inputs, *or* it was in some way
coupled to the altimeter, so that it could show a corrected TAS based on
density
altitude, but I've never actually had one in my hand. IIRC, a PA28-180R
I used to fly out
of Broken Hill many years ago had a TAS meter fitted, but I wasn't aware
of exactly how it worked at the time.
Baro Alt. has static port input only.
Yup. An altimeter is basically an aneroid barometer.
Wish I could draw you a
diagram on here, it would explain everything.
It always helps.
The CO
  #59
Old March 1st 04, 03:24 AM
John R. Copeland
"The CO" wrote in message =
=20
snip
=20
=20
=20
connection.
=20
The only time pitot pressure =3D static pressure is if the aircraft is
=20
The difference between static port pressure and static pressure that =
was
the rate that pressure (and therefore altitude) is changing, giving =
you
=20
=20
coupled to the altimeter, so that it could show a corrected TAS based =
on
density
altitude, but I've never actually had one in my hand. IIRC, a =
PA28-180R
I used to fly out
of Broken Hill many years ago had a TAS meter fitted, but I wasn't =
aware
=20
=20
=20
=20
It always helps.
=20
The CO
=20
=20
You're just trying to be nice, aren't you, CO?
We all know the fudog's memory failed him this time.
One thing -- The pitot pressure isn't "directly related to airspeed",
(and we know you meant IAS, not TAS).
The differential pressure is really related to the airspeed *squared*.
---JRC---
  #60
Old March 2nd 04, 02:18 AM
The CO
"John R. Copeland" wrote in message
airspeed)
Well, I thought the bit about a VSI using pitot was a bit, um, well,
wrong.
One, sorry didn't mean 'directly' in the physics/math sense, only that
it
was the input for an ASI (compared to static pressure of course)
An airspeed indicator gives you Indicated Air Speed. Q.E.D.
(A TAS indicator can also give you a TAS readout as it can apply a
correction
for the density altitude, but IAS is what you base your flying on (as
opposed to nav).
Yes.
The CO
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 64 March 3rd 04 06:01 AM
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 7 February 28th 04 06:07 PM
To Tarver Engineering fudog50 Military Aviation 2 January 9th 04 08:15 PM
About death threats and other Usenet potpourri :-) Dudley Henriques Military Aviation 4 December 23rd 03 08:16 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 09:32 PM
