pitot tube down
Old March 2nd 04, 04:02 PM
Emilio
Default pitot tube down
A portion of thread from different news grope:
loss of a 757 a few years ago in which clogged pitot tubes
caused bad overspeed warnings; the Turkish crew pulled
back the power and stalled and crashed. It was later determined
that the A/C had sat for a month and insects had gotten into
uncovered pitot tubes.
With aircraft equipped with GPS that shows your true speed, can you fly by
it when pitot tube is down?
Emilio.
Old March 2nd 04, 04:43 PM
Keith Willshaw
"Emilio" wrote in message
Emilio.
There's a risk if you do. The GPS will give you the speed over ground
but the pitot gives you airspeed. If you were flying an aircraft
with a stalling speed of 120 mph downwind and the GPS
showed 150 you could stall if the tail wind was more than
30 mph
Keith
Old March 2nd 04, 04:46 PM
Tarver Engineering
The Captain's static port on the 757 had duct tape over it. The FO side was
working just fine, so there was not much excuse for crashing.
Old March 2nd 04, 05:01 PM
Mortimer Schnerd, RN
As I recall, the trim settings are the same for cruise and with full flaps. I
had a bug invade my pitot tube once in a Piper Lance and just muscled the
airplane from cruise until I had all the flaps set on approach. I never touched
the trim. I have no idea how close I was to target airspeed but the resulting
landing was quite normal. The airspeed indicator was dead the whole time.
http://www.mortimerschnerd.com
Old March 2nd 04, 07:01 PM
Tarver Engineering
"Mortimer Schnerd, RN" wrote in message
. com...
by
was
flaps. I
touched
resulting
Panic seems to be the reason people don't think their way out of these kind
of single point failures. I have to winder if the pilot didn't expect to
have to do more than raise the wheels and adjust the flaps.
Old March 2nd 04, 07:52 PM
Darrell
I wouldn't take off with an inoperative pitot tube and depend on my GPS
ground speed read out but....
if you're already inflight when you lose your IAS indicator it would be
really smart to pull out your GPS and use the ground speed read out as an
gross indication of your indicated airspeed. Maintain a large margin over
your desired IAS until you enter an area like landing where you want to be
somewhat near the correct speed. Check the headwind and add that to your
desired IAS on final. I'd maybe add 10 knots to that for safety.
B-58 Hustler History: http://members.cox.net/dschmidt1/
Emilio.
Old March 2nd 04, 08:54 PM
W. D. Allen Sr.
How did they even get the 757 off the ground?
WDA
end
Emilio.
Old March 3rd 04, 02:01 AM
C Knowles
Not that familiar with the 757 but GPS displays GS. Add or subtract winds to
get TAS, then correct for density (divide by SMOE) to get IAS?CAS. Heard it
suggested you could also depressurize and use the cabin altimeter for
altitude. Or, convert cabin altitude into aircraft altitude if the chart is
available.
Curt
Emilio.
Old March 3rd 04, 04:14 AM
Leadfoot
"C Knowles" wrote in message
news
to
it
is
available.
Curt
Multiple redundant systems on Commercial jets. Figure out which one is bad
and turn it off. The standby #3 system is analog and totally separate if
it's like a 747-400. The captain should have given control to the copilot
in the turkish aircraft incident.
by
Emilio.
Old March 3rd 04, 07:39 PM
Rick
One of your series connections is open circuit, Tarver,
As a congenital idiot who couldn't learn to fly an aircraft in a
thousand years your statment above pretty much defines the level of your
knowledge of aircraft operations ... zilch.
Rick
Pitot tube question Doc Font Home Built 2 January 24th 05 05:28 AM
Pitot tube prices B2431 Home Built 2 May 16th 04 09:13 PM
Rag and tube construction and computer models? BllFs6 Home Built 24 April 12th 04 01:20 PM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 04:04 PM
Chuck Yeager-pitot tube Ron Military Aviation 44 October 9th 03 04:13 AM
