Calculating Headwind/Tailwind component
Old March 14th 12, 06:34 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Calculating Headwind/Tailwind component
On Mar 14, 12:04*pm, Ramy wrote:
Not only it isn't meaningless, but it is very meaningful.
[snip]
I agree, perhaps I was just soft pedaling.
There's much to be improved in wind calculation using GPS and TAS even
without resorting to magnetic compass inputs. I've been working on
better algorithms, which I test using recorded nmea from actual
flying, including ridge, wave & thermals. I find that the 302
component wind works really well. It's robust, reliable and rapid.
The vector wind, well, not so much. I have an algorithm in manual
spreadsheet form that flat out eats the 302's lunch for vector wind
using the same nmea and I've promised (but not yet delivered) a brief
to JW on this (it's better than XCS' wind calculation too). If he
likes it, perhaps we can make some improvements in XCS.
Another thing that may happen sooner is using the component wind to
sanity check XCS' vector wind and report a figure of merit of some
sort.
-Evan Ludeman / T8
Old March 14th 12, 06:44 PM posted to rec.aviation.soaring
Roel Baardman
I recall seeing an OSTIV paper, by someone from New-Zealand if I'm correct, where
the wind vector was derived from just the pitot and GPS. Using multiple pitot/GPS
combinations, the most likely wind direction was estimated.
The paper used data from the perlan project as an example. The more deviations in
course, the better the result was. Appeared quite promising to me.
Roel
Old March 15th 12, 01:28 AM posted to rec.aviation.soaring
Ramy
Roel
Thanks for all the explanations and opinions. I understand that more complex math and data is required to calculate wind vectors precisely. However I am looking for a conclusion about the value of the simple math of TAS-GS, and why it is not suitable as a valuable information in a flight computer. I have been using this for years to determine if and by what magnitude the wind is helping my final glide and my arrival time, or working against me. No complex math, just common sense. Perhaps calling it head wind component is not accurate, so I am open for better definition. Regardless how we call it, I have no doubt it is very valuable, more accurate and more instantaneous then the often inaccurate calculated wind vector, and thus should be included in flight computers. I believe LK8000 calculates HW, I am curious to hear if it is derived from wind vector or TAS-GS.
Ramy
Old March 15th 12, 02:26 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Roel
Ramy
In a no-wind situation, TAS = GS, so TAS - GS = head (or tail wind)
component. What's the proplem? Remember that TAS will decrease as you
get lower and the GS is tied to the track you were making good at the
time you read your GS.
JJ
USAF Nav/bomb School 1960 & 1961
Help calculating Speed To Fly for headwind and tailwind Tim Taylor Soaring 23 June 2nd 10 06:52 PM
Stewart Headwind Copperhead144 Home Built 2 August 19th 08 01:58 AM
Headwind? What's that...? David Lesher Owning 6 January 4th 08 09:17 PM
Is this a Component of a WWll Ships Radar [email protected] Naval Aviation 1 April 22nd 05 07:44 AM
boy it's changed; tailwind [email protected] Piloting 8 February 8th 04 05:03 AM
