Power FLARM power
Old June 5th 12, 07:24 PM posted to rec.aviation.soaring
Andy[_1_]
Default Power FLARM power
Can anyone comment of why Power FLARM transmit power appears to be
much less than the transmit power allowed by FCC for this class of
FHSS device? (ref test report on file with FCC)
Is this a limitation of the RF module that was selected? Was it to
increase battery life? Was it expected that adequate range would be
achieved with a very low power level?
Does the brick have the same transmit power as the portable?
Andy
Old June 5th 12, 07:59 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Is this a limitation of the RF module that was selected? *Was it to
increase battery life? *Was it expected that adequate range would be
Andy
Link, please?
Old June 5th 12, 10:02 PM posted to rec.aviation.soaring
Andy[_1_]
On Jun 5, 10:59*am, Evan Ludeman wrote:
Link, please?
The direct link to the doc doesn't seem to work but you can find it by
going he
https://apps.fcc.gov/oetcf/eas/repor...ericSearch.cfm
Searching for grantee code ZKU
selecting DETAIL, then Test report.
Test data are included in appendix B
Andy
Old June 5th 12, 11:11 PM posted to rec.aviation.soaring
Andrzej Kobus
Link, please?
going he
Andy
This would explain a lot of the issues with PowerFlarm.
Old June 5th 12, 11:56 PM posted to rec.aviation.soaring
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
Did I read that correctly?
Frequency Hopping Devices with 50 or more channels are allowed a 1watt output, devices with 49 or less are allowed a .25 watt output?
And Powerflarm's output during the certification was:
At 902.2 MHz- .010 watt
At 915 MHz- .006 watt
At 927.8 MHz- .003 watt
Does seem well under the max allowed, but I guess what matters is it good enough?
Interesting, thanks for the link to the data.
Old June 6th 12, 12:03 AM posted to rec.aviation.soaring
Member
Forgot to add...PF has 65 channels, according to the test report.
Old June 6th 12, 12:11 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Andy
I see what you mean.... 10mW could not possibly have been the intended
result.
Experience at 15s showed many targets out to 6 nm in all directions
except my 6:00, where range was 1.5 - 2 nm. The range problem noted
previously appears to have been solved.
-Evan Ludeman / T8
Old June 6th 12, 12:37 AM posted to rec.aviation.soaring
Dave[_26_]
Link, please?
going he
Andy
Why? This is the same transmit power used by classic euro FLARMs. More than enough for advertised range.
-Dave
-Dave
Old June 6th 12, 01:33 AM posted to rec.aviation.soaring
Andy[_1_]
-Dave
Maybe you should take a look at this link to see what it was we
thought we were buying!
http://www.gliderpilot.org/FLARM-Comparisons
Note the following - "More powerful radio transmitter as needed for
USA operation"
and "Radio transmitter is not powerful enough for proper operation in
parts of the USA"
and also the comparison of "Double range dual antenna" with "Standard
range"
Also included in the text (What does it do) "The operating range is
very dependent upon the antenna installation in the aircraft. The
range of 'Classic' FLARM is about 2 km, but up to 5 km may be achieved
in individual cases. PowerFLARM will have twice the range. "
Andy
Old June 6th 12, 01:38 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Andy
result.
-Evan Ludeman / T8
Reading other info at that site indicates that 10mW was the design
power output. Hmmmm.
-T8
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 02:33 PM
Portable Power Flarm for sale [email protected] Soaring 1 June 2nd 12 02:14 AM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 05:28 AM
Power FLARM portable reports? Andy[_1_] Soaring 2 December 9th 11 04:58 PM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 03:44 AM
