Slingsby Dart
Old September 6th 12, 07:03 PM posted to rec.aviation.soaring
Default Slingsby Dart
Does anyone know where I can get a copy of Slingsby Technical Instruction (TI) No. 109/T51, Issue No. 2. It is the inspection requried to comply with the wing spar AD. I can find a copy of Issue No. 1 and Issue No. 3. The problem is that the US AD on the dart is against Issue No, 2 and I am having a hard time finding it on the internet.
Old September 6th 12, 11:06 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
If you find a complete Issue 3, is has the inspection required by Issue 2 included. As Issue 3 says you don't have to destroy the wings every 5 years if it is kept in good order.
How about going to the FAA and letting them know that the AD needs to be revised, as the certifying agency in the country of origin of the plane and the initial AD has revised its AD and the FAA is now 12 years behind the power curve on picking up this change. Of course, do it is a much more diplomatice fashion, and I bet they will make the change. Maybe not today, but they are aware they were behind, and if you get this on their radar, it will get worked.
Just a thought..
Steve Leonard
Slingsby T.38 Grasshopper XA310 Soaring 0 December 25th 08 09:25 AM
Slingsby Skylarks.... George Ballantyne[_2_] Soaring 23 December 25th 08 09:21 AM
Slingsby Skylarks.... Nyal Williams[_2_] Soaring 1 December 3rd 08 12:00 AM
Slingsby Dart 17r handling notes Phil Collin Soaring 0 May 9th 07 11:07 AM
Slingsby T-21 Nyal Williams Soaring 14 March 1st 07 09:28 AM
