Winch Clinic
Old October 3rd 12, 01:45 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Default Winch Clinic
Given that the winch we've been building is getting close to test
phase, I expect I'll be hearing a lot more about these accidents
soon...
Marc
Need a BIG glider to test with?? I have a Janus C with a CG hook....I'll be auto-towing it at the end of October.
Old October 3rd 12, 01:55 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Never mind.... I just noticed this is an OLD thread.
Old October 3rd 12, 04:39 PM posted to rec.aviation.soaring
Bill D
On Monday, January 23, 2012 8:26:31 PM UTC-7, Frank Whiteley wrote:
On Jan 23, 3:10*pm, Brad wrote:
On Jan 23, 12:51*pm, BobW wrote:
On 1/23/2012 12:01 PM, Frank Whiteley wrote:
On Jan 23, 11:13 am, *wrote:
On Jan 19, 7:16 pm, Frank *wrote:
As found on Barnstormers.com
GLIDER WINCH CLINIC IN SO CAL • $375 • EVENT ANNOUNCEMENT • YOU'RE
INVITED! • Instruction on flight and operations of winch launching
with a modern winch built by Roman Wrosz. Space limited. March 9-11,
2012. Fly-in or drive to Jacumba, CA (L78). The demonstration and
training flights performed in the beautiful Schweizer 2-33. Four hours
of ground instruction, followed by two days of flight school. •
Contact Bud Robinson - ASSOCIATED GLIDER CLUBS OF SOUTHERN CALIFORNIA,
Friend of Owner - located San Diego, CA USA • Telephone:619-436-8010begin_of_the_skype_highlighting * * * * * *619-436-8010
Excuse me for appearing stupid, but I was under the impression that
you needed a CG hook to winch launch and that a Schweizer hook was
especially bad to use because when the tow cable is approaches 90
degrees to the release arm, the bale (name? *thing the pilot actually
moves during a release) is under so much load that it cannot be pulled
aft. * * I'd like to know more. *Thanks, John
Snip...
I've winched launched 2-33's a lot from the nose hook with no
problems. *My greater concern is fouling the strop in the skid. *Not
aware of any that have failed to back release at the power cut that
I've launched, but the pilots always pull twice anyway. *Plan B is cut
the rope.
Frank Whiteley
"What Frank said." For several winters back in the (I think) 1990s various
SSB-ers used to winch launch our nose-hook-only-equipped 2-33. Other than
noticeable elevator separation/porpoising on the way up if one "over-pulled",
all was utterly straightforward. Of course we did "the usual pushover" at the
top of the arc, firmly/fully pulled the release twice, and visually verified
successful release before initiating any turn. Plan B was to chop the
(single-strand, well-logging) wire at the winch. Plan C was to circle to a
close-in-to-the-winch landing pointed at the winch.
Never had a hook-related/release issue of which I was aware. Plan A always
worked without drama.
Regards,
Bob W.
So.......................I could winch launch my glider using the nose
mounted Tost unit?
That would be great!
Brad
TOST nose hook won't back release, back to the drawing board you two!
The Lark Tost nose hook would back release. Probably just because they didn't want to stock different hooks at the factory.
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 12:45 PM
Winch launch clinic at Faribault, Minnesota Bill Daniels Soaring 16 May 25th 08 08:44 PM
Winch Clinic Southern Nevada November 11 and 12 [email protected] Soaring 0 October 31st 06 03:26 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
X-Country Clinic Andrew Parker Soaring 0 January 28th 04 08:26 PM
